More reliable connectors
Home › Forums › General Questions › More reliable connectors
Viewing 23 posts - 1 through 23 (of 23 total)
  • #178657
    Eric Cox
      @ericcox50497
      In Postbag ME 4501 p254, Phil. Bellamy advocates using a metal sleeve on wiring connections. For those interested they are known as Bootlace Ferrules and can be obtained from RS Components. They are colour coded for size in relation to the thickness of the wire. White being the smallest and black the largest.
      When used the bare wire is located in the metal sleeve and the insulation into the coloured part. It should be crimped onto the wire before inserting into the connection. Don't rely on the securing screw in the connection to crimp the ferrule.
      #23705
      Eric Cox
        @ericcox50497
        #178664
        Muzzer
          @muzzer
          Bootlace ferrules make for a neat installation, prevent strands of wire getting where they shouldn't and stop the screws of some connectors from damaging the strands. They are a great idea if you have some, although sometimes the plastic barrel can get in the way if you are inserting more than one into a single connector. I see that CPC also stock them. And Maplin.
          Another means of terminating stranded wires is the pin crimp or flat blade crimp if you prefer the red/blue/yellow system.
          On the subject of stranded wires and compression terminals, don't ever be tempted to tidy up stranded wires by solder tinning them before inserting them into screw terminals. It all looks neat and tidy when you finish the job but unfortunately, solder is prone to "cold flow", whereby the solder flows due to the applied pressure over weeks or months. The result is a loose connection, no matter how hard you originally tightened it. This in turn can lead to intermittent connections and more importantly, the risk of fire if the wiring is passing high voltage and current.
          As this is a well-recognised problem, it's now unusual to see tinned wires in new products. However, I have seen one or two in recent years. They should be cut off and reterminated.
          Murray
          #178668
          martin perman 1
            @martinperman1
            Gentlemen,
            I use bootlace ferrules in my everyday job and agree with what has been said but it should be made aware that the ferrules are cheap but a good crimping tool can be expensive, I use another tool to do the crimping but dare not tell you what for fear of the backlash wink
            Martin P
            #178680
            Muzzer
              @muzzer
              Yeh, what's wrong with pliers or the heel of a shoe?!
              #178683
              frank brown
                @frankbrown22225
                Ref. Crimping, years ago I was working in electronics where I had to check out 140 units that produced an alarm signal, in the end I found 38 units ware "alarming". It turned out that the bootlace crimps had been done with a proper tool but with the wrong dies fitted so the wire had been severely "over" crimped and in some cases it was only the PVC sleeving that held the wire in place.
                I once had to crimp 48 wire together (in pairs) at home, I used a £4 tool which was very painful on the hands and had to replaced afterwards. I then bought a proper one (red,blue and yellow crimps) for £25, best thing I did. Comparatively, its a joy to use.
                If you buy the proper tool you feel the pain when you buy it. If you buy a cheap tool, you feel the pain every time you use it.. (Practical Machinist)
                Frank
                #178691
                Eric Cox
                  @ericcox50497
                  The pin crimp and flat blade crimp mentioned above are secured by crimping the coloured section. Boot lace ferrules are secured by crimping the metal section.
                  The pin and flat connectors use a crimping tool whilst the boot lace ferrules can be secured using a pair of wire cutters, not your teeth that Martin P probably uses
                  #178693
                  martin perman 1
                    @martinperman1
                    I actually use wire cutters but thought that might not go down to well, you have to remember not to squeeze to hard though wink my teeth aren't up to lots of wires.
                    Martin P
                    #178769
                      An interesting point that is often not appreciated is that a really good crimp connection will actually result in cold welding of the wires to the connector.
                      Michael Briggs
                        @michaelbriggs82422
                        Hello all,
                        In the industrial environment I work in we took the decision about 30 years ago to standardise on bootlace terminations. We considered that they had a significant advantage over the red/blue/yellow type because the bootlace crimp is generally held in a terminal which exerts pressure on it so if the crimp is not as good as it might be the clamping action of the terminal will help maintain integrity. On the other hand with the red/blue/yellow pin crimps are such that if not properly formed will be a bad termination because the terminal grips the pin.
                        However bootlace terminations are no good for a stud termination, very good for clamp terminals but not much else – the r/b/y type are available in many forms, eye, fork, faston etc. The use of bootlace terminations is now standard across all our suppliers for clamp terminal interfaces, not because we insist but because they prefer to use them.
                        Back to the workshop, for lower scale installations I can recommend stripping the end of the cable, twisting it and then tin it with solder, simple but very effective.
                        Michael
                        #178781
                        Ian L2
                          @ianl2
                          Posted by martin perman on 06/02/2015 12:01:37:
                          Martin P
                          I would have been sacked for crimping your way.
                          #178793
                          John Shepherd
                            @johnshepherd38883
                            So far:
                            It's good practice to use a ferrul when terminating a wire in a terminal. Agreed
                            Its ok to crimp with wire cutters! I don't think so. I hope Martin does't work in the aircraft, automotive or medical industry for example.
                            Contradictory advice re soldering the ends of wires – it sounds good but the reason not to do it given by Muzzer is sound advice. Also there is increased risk of a fracture where the non soldered/soldered point meets.
                            There's a lot I don't know about crimping but I do know that the crimp and the wire must match and the only tool to use is one of the ratchet types designed for the crimp in use. Otherwise it's a disaster.
                            A grey area for me is use of crimps on solid wires and the voltage ratings of crimps. Can any one give some sound authorative advice on the subject of crimping please.
                            #178804
                            David Colwill
                              @davidcolwill19261
                              I too use bootlace ferrules at work. I mainly use the uninsulated type but do use the others. Don't get to fixed on the colours as the french (I think) have a slightly different colour scheme and they often get mixed up. Also worth noting is the fact that you can get a twin version of the insulated crimps that will take two wires.
                              I bit the bullet and bought a proper pair of crimps, which are a joy to use and well worth looking out for on ebay etc.
                              Regards.
                              David.
                              #178806
                              Geoff Theasby
                                @geofftheasby
                                When I worked in satellite communications, we often used coaxial cables and had to fit connectors on the ends. The connectors were several pounds each, but much cheaper as a crimped version. The correct tool for crimping them on was about £125. However, my chief engineer didn't approve, he said he couldn't take them apart to see how well they had been assembled!
                                Geoff
                                #178809
                                OuBallie
                                  @ouballie
                                  Is it just me that detests the plastic shielded crimps?
                                  Once crimped they look ugly, so I strip the plastic off and use heat shrink tube where necessary.
                                  Agree with Frank's last sentence/quote and David about using the proper tool as it makes crimping a pleasure, so much so, that I'm actually looking forward to re-wiring the Austin Seven.
                                  Cannot believe I used those blade crimping tools in the past – abomination are they after using the 'proper' ones.
                                  Geoff – Waiting for Workshop to heat up.
                                  Edited By OuBallie on 07/02/2015 09:45:04
                                  #178810
                                    I agree, using crimp connectors makes wiring up something like a motor or inverter easier and safer (less worry about loose strands). A bit like discovering the joy of push-fit plumbing when you have a long, complicated run of pipe in inaccessible spaces!
                                    S.D.L.
                                      @s-d-l
                                      Posted by John Shepherd on 07/02/2015 07:28:30:
                                      We use both bootlace crimps and the RYB eyelets, fork and blade crimps at work on lamp circuits that run at 950V 4A and have a strike voltage up to 2KV. this arrangement passes both UL and CE low voltage directive via independent test house in UK, so that should give some idea. They do insist on the correct ratchet tools that have to do a pull test on a sample every year or 6 months depending on use.
                                      As others have said soldering ends of wires going into clamp terminals is a no no now days however neat it looks.
                                      Best connection is the spring clamps found on many terminals and increasing numbers of components, gets rid of the screws working loose during shipping.
                                      Steve
                                      #178816
                                      Gordon W
                                        @gordonw
                                        Many years ago we had to do a survey on different wire connections, this was for building an enduro bike. I worked in aerospace at the time so had a lot of info. The best connector electrically is a twisted joint, next crimped . Do not solder the ends, this causes stress raisers and for a dynamic situation is the worst possible. Neil- push fit plumbing is the invention of the devil, Just wait until you have a little dribble in one of those inaccessible places.
                                        #178892
                                        Michael Briggs
                                          @michaelbriggs82422
                                          If you properly tin the cable end the solder flows up into the insulation providing stress relief with the support of the insulation. My suggestions have been to help a model engineer who has a few cables to terminate without the outlay to buy crimps and the expense of the crimping tool.
                                          Of course a correct crimp termination is better, some time ago I was involved in a project where the customer questioned the integrity of the installation because no crimps were used, the terminal supplier, Klippon now known as Weidmuller replied that their terminals are designed for bare wires. I would not advocate that but just wish to make the forum members aware.
                                          Michael
                                          #178894
                                          Emgee
                                            @emgee
                                            As Michael says Weidmuller terminals are designed for bare wire, they are clamp type, the screw operates a clamping plate, not to be confused with more widely used screw connectors where the screw end can if overtightened cut through multi stranded cable and indeed solid conductors.
                                            Emgee
                                            #178899
                                            Mike Poole
                                              @mikepoole82104
                                              I think the most important point is to use the cable termination that is suited to the terminal on the device you are connecting to, bootlace ferrules do indeed make a neat and reliable connection but can prevent full insertion into some terminals, they can also crowd some relay terminals where two wires are required but intended for bare wire connection. For speed of installation many control devices use spring terminals designed for bare wire, the time taken to strip fit and crimp ferrules costs money. Insulation displacement connectors are now very popular on much equipment especially communication type wiring for telephone and ethernet cables. Ribbon cable would be a nightmare to have to strip and solder compared to the speed and reliability of IDC systems. Even some power wiring systems use IDC termination now. The trouble with many termination systems is the are very specific for the cable and connector, use the wrong ones and the mismatch will give a poor electrical and mechanical termination.
                                              #178902
                                              Ed Duffner
                                                @edduffner79357
                                                I used to work with a guy who was a general builder, built like an Ox and a good laugh. One day I had some cables to crimp and couldn't find my ratchet crimping tool so had to resort to the backup stamped plate type that also strips wires and shears small screws. The crimps were slightly larger than the crimper could handle, 10mm² I think, so I said to him, here can you crush this for me. He caught hold of my crimping tool and not only did he crimp the wire but bent the tool handles as well. Lesson learned. smiley
                                                #178921
                                                HughE
                                                  @hughe
                                                  Crimptool for bootlaces ferrules available from banggood at 13GBP. I purchased a set a while back thet are well made and do good job. Never looked back since.
                                                  As mentioned previously its important to select the correct one for the guage being used. Sets of ferrules are available from various suppliers such as CPC and RS. They are also available with various pin lengths.
                                                  I have just had to rewire a tractor were most terminations were faulty. all the faulty ones had been soldered by the past owner. Crimping was quick and made reassembly a doddle.
                                                  When using these bootlace ferulles check you have enough space for the stainrelief on the end to fit in the terminal block
