On
13 July 2026 at 15:35 Vic Said:
Fitting a QCTP to a small lathe isn’t going to help with rigidity and I’ve saved quite a few quid not buying tool holders.
I wonder how much the rigidity/stiffness of a lathe is dependent on whether you have a QCTP installed and how much on the rigidity/stiffness of other parts, like your compound slide. I’ve put locks on my carriage, cross-slide and compound slide, and I can’t detect any loss of stiffness when using my 250-000 QCTP as opposed to using any of the 3 four-way toolposts I have (which I do still use, incidentally).
Shimming or epoxying on of riser blocks for every different tool wouldn’t be my favourite past-time*, but I am interested in trying your tangential tooling set-up, Vic.
*How do you decide where along the shank to epoxy on the riser block when, on a lot of tools, you would ideally have different lengths of tool stick-out for different jobs? If instead you are epoxying the riser block to the toolpost itself, this is arguably even more limiting, though in a different way.
