What Did You Do Today 2026
Home › Forums › The Tea Room › What Did You Do Today 2026
Viewing 25 posts - 1 through 25 (of 257 total)
  • #833763
      Time for a new thread, even if a bit late.
      #833706
      bernard towers
        @bernardtowers37738
        As the last entry was Boxing Day I thought I’d let you know that I dusted off the shaper today and prepped the castings for hemingways filing machine. Looking at the finish I am reminded why I keep it. Maybe some photos tomorrow it’s too cold out there now.
        #833741
        Speedy Builder5
          @speedybuilder5
          Today I replaced the extractor fan in the downstairs toilet.  It has a timer, selected by sucessive pressing of a push switch. The delay off timer starts when exiting the WC. – settings are 30 seconds, 5 minutes, 10, 20,30mins.  All very clever, but I would have liked a variable resistor so that I could choose anywhere between zero to 30 mins.  Surely that would have been cheaper than the logic, eerom and an LED array to show what you had selected.
          Is it a case of over engineering ??
          Bob
          #833750
          Joseph Noci 1
            @josephnoci1
            On JasonB Said:
            I went old shcool today and broke out the vertical slide just to illustrate that a mill is not needed for my V-Twin build. The small rear bearing block was all done on the vertical slide and seems to have gone together OK and a nice fit on some silversteel.
            20251113_150520
            Old post, but I just came across it – that’s a Unimat vise I believe? Have one in my draw!
            Joe
            #833765
              Yes and a Unimat3 Chuck. The vice does not get a lot of use on machines these days but spends most of it’s time screwed to a piece of 16mm square bar so it is easy to hold in the bench vice when I want something to hold smaller work with.
              #834112
              Diogenes
                @diogenes
                Finished servicing my three-wheel 14″ bandsaw (a ‘Draper’ BS355, but they went all over the world under a host of different badges) – they work better than they ought to, and are better built than any current saw that one could cheaply replace it with.
                Wasn’t a cheap fix (it wasn’t intended to be), but it has stopped shrieking/vibrating and feels and cuts ‘as new’ – I expect it to see me out without further attention.
                For anyone interested…
                6 new wheel bearings – 6202-ZZ NSK Shielded Ball Bearing 15mm x 35mm x 11mm
                2 new guide bearings – 629-ZZ Dunlop Shielded Miniature Ball Bearing 9mm x 26mm x 8mm
                (Bearing Boys – £42.95 incl. UK shipping & tax)
                3 new tyres – Flat Urethane 165mm x 12.7mm x 2.4mm
                (BandsawParts – £36.95 incl. UK shipping & tax)
                New blades – 1785mm (70 1/4″) x 6mm (1/4″) x 0.35mm (14 thou)*
                (Tuffsaws, about a tenner each)
                #834170
                bernard towers
                  @bernardtowers37738
                  Bit of a delay but castings cleaned up and nice and square ready for detail work.IMG_4018
                  #834173
                  Diogenes
                    @diogenes
                    Looking good, nice to see a bit of shaper work..
                    #834438
                    Diogenes
                      @diogenes
                      Odd piece of random uselessness by the internet..
                      Screenshot jpeg
                      #836225
                      bernard towers
                        @bernardtowers37738
                        A little bit more done and mechanism now on lathe being testedIMG_4040
                        #836932
                        Nicholas Farr
                          @nicholasfarr14254
                          Hi, a few weeks ago, one of my sisters lent me a load of paperwork that he did during his time in the RAF during WW2, he was a Leading Aircraftman, and was posted in Iceland. So I’ve been scanning some now and again, and found this small note that may interest some.
                          SALTBATH
                          I’ve no idea if you can get any of these salts these days, or if anyone would do such an exercise, but it might be interesting to know if it is.
                          Regards Nick.
                          #836943
                          Speedy Builder5
                            @speedybuilder5
                            “We” used to anneal, precipitate and normalise aluminium alloys at Vickers A/c in the 1960s – big baths about 12 foot long and 6 foot deep for annealing and big ovens for the other processes.  I don’t know what the salts were, but they looked pretty crusty around the top edge.
                            For case hardening, there were the cyanide baths, can’t remember what the Nitriding process was – a bit of brain fade!
                            Bob
                            #836949
                            Andrew Crow
                              @andrewcrow91475
                              SALTBATH
                              Regards Nick.
                              Don’t think you would be able to buy sodium nitrate or potassium nitrate without a special licence these days as both can be used to make gunpowder and other explosives.
                              #836953
                              Andrew Crow
                                @andrewcrow91475
                                Bob
                                Bob
                                I seem to recall that nitriding was done in a low oxygen high nitrogen gas oven at quite a high temperature but well below red heat. I don’t know the chemical created but it was very hard and only tenths of a thou thick, you did need a special steel EN40B.
                                Other similar processes have superceded it like Sursulf and Tuftriding where you don’t need special steels.
                                #836981
                                Nicholas Farr
                                  @nicholasfarr14254
                                  Hi, well Nitriding can be done on low carbon steels, as well as a few other metals. It is in fact a case hardening process. I remember seeing a film about it during my tech college lectures, where they were doing a large gear ring, there were a number of gas burners around the ring, playing flames onto it, and when it reached the required temperature, Nitrogen gas in the most part was applied to to it.
                                  Nitriding process
                                  Regards Nick.
                                  #836986
                                  Andrew Crow
                                    @andrewcrow91475
                                    Thanks for that link Nick, very informative, I think the two processes I mentioned above are trade names for the same process.
                                    I remember at the company I worked at the crankshafts were S G cast iron, the journals were all finish ground and then hardened by this processes as there was no distortion caused. The final process involved polishing with fine emery bands in a specially made machine.
                                    An extremely hard surface was produced, even after years of use engines would return into the remanufacturing system and would only normally require new shell bearings to be fitted.
                                    #837040
                                    Nigel Bennett
                                      @nigelbennett69913
                                      I have just finished one of those “Please can you fix this?” jobs. My sister’s trolley affair that she uses for shopping – one of those things with rotatably-mounted groups of three wheels each side – had broken where one of the axles had smashed through the plastic fork on one side. I wasn’t too difficult to cut off the axle (Dremel), and turn up a new stainless steel axle that fitted the much-enlarged hole on one side of the forks. The wheel was reamed 7/32″ too, to suit the new axle. Rather than riveting it up as per the others, I shoved on an M5 thread and fitted a Nyloc nut and washer.
                                      Job done? Perhaps not… those other wheels were all rather wobbly and as a result, the tyres had begun to cut through the forks. Better open up the axle holes in the wheels and fit larger axles, a nice fit on the wheel to cure the wobble. It didn’t take too long. At least they all look alike now with Nyloc nuts!
                                      I should have left it at that. My biggest blunder was to then start shaking my head at the wobbliness of the 3-wheel assemblies on their central axle. Surely I could remove them and re-bush them? I wish I hadn’t. There was a bop-on plastic hubcap securing the assembly, which did eventually yield to persuasion and came off, fortunately undamaged. With the sub-assembly of three wheels in my hands, I thought I’d remove the steel bush affair on the inside of the thing. I tried to remove it, but too late I discovered that it wasn’t a bush but an extremely scabby, worn and ill-fitting ball bearing. By this time I’d wrecked it even as a scabby bearing, so it had to come out. It wasn’t easy; I eventually got the inner race and balls out, then found that the outer race seemed to be moulded into the plastic fork. No way could it simply be pulled or driven out! Fortunately I had a suitable bearing in stock, so I bored the plastic wheel and also removed the remains of the outer race to fit the new bearing. I fitted a brass bush as an outer wheel bearing, a good fit on the existing axle and then fitted it all together. Result!
                                      No, I am leaving the other wheel sub-assembly firmly alone – they’re wobbly, but they can stay that way!
                                      The perils of trying to repair things that clearly are not meant to be taken apart! Ah, well; I’ll have earned some Brownie points from my sister – but what will she have me mending next?
                                      #837109
                                      bernard towers
                                        @bernardtowers37738
                                        Be careful she may have you do a hip job!
                                        #837151
                                        duncan webster 1
                                          @duncanwebster1
                                          Not engineering related, but I feel the need for a grouch. Got dragged to IKEA, fully intending to buy a bathroom cabinet. Long before I’d tramped round and round to get to that bit I’d lost the will to live,  so I just found  short cut to the exit. I’ll pay a bit more in a normal shop where I can just go straight to what I want.
                                          Same problem with supermarkets who move stuff around in the hope you’ll impulse buy something in your search. No if I can’t find it where it used to be I’ll manage without. Told the manager at my local Sainsbury’s but he didn’t seem interested. No wonder Internet shopping is taking over.
                                          #837206
                                          Nigel Bennett
                                            @nigelbennett69913
                                            Short cut to the exit in IKEA? Please tell me it’s a thing… Reveal all… I’ve heard that folk have been lost in IKEA for years…
                                            #837226
                                            howardb
                                              @howardb
                                              SALTBATH
                                              Regards Nick.
                                              Potassium nitrate is available from Amazon.co.uk
                                              #837229
                                              Jouke van der Veen
                                                @joukevanderveen72935
                                                Potassium nitrate is a well known fertilizer and available for that application. How pure that is? The same for sodium nitrate.
                                                #837673
                                                Nigel Graham 2
                                                  @nigelgraham2
                                                  Well, a bit of a few “Todays”…..
                                                  Two workshop equipment projects under way:
                                                  1) I built the overhead-crane “crab” (the cross-travel truck carrying the hoist itself) with a cross-bar held in keyhole slots in two parallel plates, to suspend a commercial chain-hoist – but also so the cross-bar alone could form the static axle for the top sheaves of a rope block-and-tackle. So it is easy to lift out to thread the pulleys on.
                                                  Chain hoists are great for risking yards of hefty steel chain clattering about all over the work, catching on fittings, chipping paintwork, bending things…
                                                  Also my workshop is of very limited headroom. It’s only a glorified garden shed, albeit built of concrete blocks, with a gently-sloping roof and ceiling.
                                                  So after a little finishing work, the crab will also have a smaller version of the chain-block suspension, for the upper of a pair of 2-sheave blocks (“Screwfix” items) taking 6mm cord, giving a 4-fall rope tackle that will handle the bulk of the crane’s duties.
                                                  The blocks being small and their mounting in the frame higher, will also increase the headroom by some inches, at full height – i.e. “chock-a-block”. (Yes, that is the colloquialism’s original, maritime meaning.)
                                                  2) A trip to Bridport, no not to the Foundry but to Townsend Bearings at t’other end of town; to purchase pillow-blocks and a pulley for the belt drive for the Denbigh horizontal mill undergoing re-commissioning. These plus other parts are now on a picnic-table in the dining-room so I can “design” the framing to hold it all.
                                                  I have two fairly “powerful” worm-gears that were candidates for the massive speed reduction necessary, around 1350 : 70 rpm, but experimenting showed this route not really viable.
                                                  #837684
                                                  duncan webster 1
                                                    @duncanwebster1
                                                    I have a Tractel 250 kg chain block, what my mate called a jewellers chain block. Very compact and can be lifted with one hand. It runs on a trolley supported by unistrut
                                                    #837762
                                                    Speedy Builder5
                                                      @speedybuilder5
                                                      First stab at a replacement tray for 1/4″- 3/8″ socket set.  Big print head crash after about 7 hours of printing.  The printer lost the “Z” reference and no amount of resetting would sort it out.  Finished by doing a reset to Factory setting.
                                                      It needs a few dimension changes and will have another go perhaps tomorrow.
                                                      SocketSet
