A tales of two lathes
Home Forums Manual machine tools A tales of two lathes
  • #442482
    Stephen Rowley 1
      @stephenrowley1
      My local hackspace has been offered a Kerry Model A.G. Mk. 3 for a very very good price 😎 that appears in good condition.
      And at the same time we've offered a http://www.lathes.co.uk/viceroy/ mk1 for £200 not sure of its history yet.
      Anyone got any experience with either of the lathes?
      I suspect there both better than our current worn out 6" Sphere lathe.
      #13733
      Stephen Rowley 1
        @stephenrowley1
        Which lathe to choose
        #442487
        Robert Atkinson 2
          @robertatkinson2
          Two similar lathes so condition and included accessories are probably the deciding factor. Manuals are available for the Kerry, not sure about the Viceroy and this can be important with lots of users.
          Robert G8RPI.
          #442490
          Brian H
            @brianh50089
            I agree with Robert regarding condition and accessories.
            Manuals are available for the Viceroy from Lathes.co.uk .
            #442491
            Pete Rimmer
              @peterimmer30576
              I would have the Kerry before the Denford Viceroy all other things being equal. The Kerry is a better-built machine all round with a stout bed and nice gearbox. Hard to say what a "Viceroy mk1" is as there were quite a few variants from plain-turning to full screwcutting to wood turning and even a wood and metal turning model for schools. I've had a couple of them and they are not without their problems.
              Ultimately, it would depend on what attachments came with the machine. You're not going to find steady or follow rests for either. What chucks do they come with? The early Denford had a screw-on chuck similar to Boxfords. Later ones had camlock d1-3. The Kerry probably has L00 taper chucks or possibly a threaded spindle.
              Either would be much better than your Sphere, which is a copy of the bendy old Atlas lathe. I'd still go for the Kerry.
              #442492
              thaiguzzi
                @thaiguzzi
                Those Kerry's are very nice lathes, IMO a better lathe than a Viceroy which is basically a posh Boxford.
                As others have said, comes down to equipment, accessories and condition.
                All things being equal, the Kerry every time.
                a proud Boxford VSL owner.
                #442496
                Brian Wood
                  @brianwood45127
                  If you can afford it, why not have them both? I have found that two lathes of different capacities in my workshop complement each other in ways I had not expected when I acquired the second.
                  If that is not a viable option, go for the heavier build of the Kerry
                  #442497
                  Stephen Rowley 1
                    @stephenrowley1
                    Both would be great, not quite sure we've got the room
                    #442508
                    Clive Foster
                      @clivefoster55965
                      As ever its condition, condition, condition that rules.
                      Although the Kerry is a better built, and generally stronger machine than the Viceroy in practice the difference isn't terribly significant until you get to the later versions with the angled tailstock drive. These have the L series chuck mount and a good deal of general beefing up in various places. The topslide in particular is much heftier.
                      As far as I'm aware all the straight drive tailstock versions have threaded spindles. One weakness to be aware of is endfloat in the clutch shaft bearing mounting. The standard retention system on the the Mk 3 I worked on was a simple domed plug expanded into the bearing bore. Effective and inexpensive when new it had lost grip over many years so the baraing could float back and forth in a somewhat random manner when operating the clutch. Previous owners had resorted to playing with the adjustment which probably made things worse. A T shape cap held on with three screws made so as to push the bearing into the correct place taught the thing manners. Excellent clutch by the way.
                      If you have an L series spindle do make sure its been looked after with both chuck and taper cleaned properly before mating. Brutal, dirty users can wreck the system by jamming it together with swarf entrained. Hard to do but possible.
                      Edited By Clive Foster on 20/12/2019 10:45:07
