Bonding brass hubs to steel
Home › Forums › Beginners questions › Bonding brass hubs to steel
  • #856079
    mikemunson
      @mikemunson
      i am planning the assembly of the control gear for a a Cornish Cycle beam engine model. This wiil involve arbors 3mm diameter with a number of levers and interlocks fastened to them. I could bond these with something like Loctite but are there suitable capillary spray or drop that would allow assembly before applying the bonding agent?
      #856088
        It may not be marketed as such, but [reading between the lines] this should do nicely:
        https://datasheetonline.s3.eu-west-2.amazonaws.com/GO/TDS/HEAN50022-tds.pdf
          I believe 290 is the wicking one not 270 as per Michaels link.
          Though both are thread lockers and not retainers so may not have as much strength for bonding cylindrical surfaces.
          https://datasheets.tdx.henkel.com/LOCTITE-290-en_GL.pdf
          #856146
            Oh bother !!
            … I picked-up that TDS from
            https://www.glueonline.co.uk/loctite-290-10ml
            vintagengineer
              @vintagengineer
              Why not press fit them?
              #856452
              bernard towers
                @bernardtowers37738
                Please don’t use abbreviations without the full spelling first
                #856457
                  Or you could click on the earlier links and see they take you to the Technical Data Sheet for the product.
                  #856464
                  Diogenes
                    @diogenes
                    technical data sheet!
