Warco 250V Inverter Drive Lathe
Home › Forums › Workshop Tools and Tooling › Warco 250V Inverter Drive Lathe
  • #18457
    Ian Westlake
      @ianwestlake17243
      #289261
      Ian Westlake
        @ianwestlake17243
        I've searched extensively on here and found many threads on the non inverter 250V lathe, but not this one.
        Is the inverter lathe worth the extra £300? I know inverter motors should produce more torque, but is it much of a difference? And the non inverter lathe now has an 1100W motor, so does that help with the low speed torque?
        This is my first lathe, and I don't know what it will eventually be used for, however I have the money to buy either machine, I don't want a smaller machine (I have the space for this lathe), so it's really down to whether the inverter really is worth the money.
        Thanks
        Ian
        #289264
        John Stevenson 1
          @johnstevenson1
          Yes
          #289266
          John Rudd
            @johnrudd16576
            I would concur with the honourable gentleman too….but I would qualify my statement in that if the motor or controller on the WM250 failed after the warranty period, the repair isnt cheap….the vfd version is more robust, having a 3 ph motor, it is less likely to fail than its dc counter part…There are threads on the forum whereby owners have replaced the original setup with an inverter/3ph motor.
            Edited By John Rudd on 17/03/2017 19:11:02
            #289273
            John Haine
              @johnhaine32865
              A 3 phase motor is practically bullet proof, if the inverter failed a new one will cost about £130 in today's money, a no brainer imho.
              #289276
              Gray62
                @gray62
                Have owned a WM250V for about 18 months, having used DC variable speed based lathes in the past I can confidently say it was worth the bit extra for the inverter drive model, bags of torque, and good quality motor and inverter so no worries about it letting out the magic smoke if you work it a bit hard (which I do often)
                #289277
                Ian Westlake
                  @ianwestlake17243
                  Thanks all (and thanks John – I do like your straight talking approach )
                  #289281
                  Brian Oldford
                    @brianoldford70365
                    In researching the best way to fit a variable speed drive on any machine I've never know anyone consider a DC option better than a vfd. . . . . . . Says it all really.
