plumbing a Pansy
plumbing a Pansy
Home Forums General Questions plumbing a Pansy
  • #168434
    wendy jackson
      @wendyjackson
      Hi chaps.help needed. How is the hand pump plumbed from the l/h tank.and to which cleck valve. What are the reasons for the right hand tank to have a waterr outlet underneath and top upper side, what fits onto these two outlets.thanks.michael
      Edited By Diane Carney on 03/11/2014 16:40:11
      #23564
      wendy jackson
        @wendyjackson
        #168474
        Bazyle
          @bazyle
          Each tank has an outlet at the bottom towards the front for a balance pipe to join them together. Have a think about how you are going to be able to join these two flexibly when the tanks are fitted. i suggest inventing a Y joint and flexible rubber pipe with the base of the Y going to the rear buffer for a) draining tanks after use, and b) pumping water into the tanks from an extension tank on your driver trolley.
          Next there is an outlet to a simple cock that feeds the injector with warm water so it may not work anyway. Better to have a feed from the trolley again.
          Then there is a feed to the axle pump.
          There is also an exit needed for the hand pump water pipe and finally an entry for the bypass water to get back into the tank taken to a point just under one of the filler caps so excess water can be seen coming out for you and the boiler inspector to see the axle pump works.
          I'm not usre what's on the drawings and if it is one of LBSC's occasions when he left it to the builder then every one is likely to be a bit different. I'll check out mine when I get home. My hand pump is in the RHS tank.
          Edited By Diane Carney on 03/11/2014 16:41:00
          #168476
            perhaps a Moderator would be so kind as to edit the title,
            Edited By Diane Carney on 03/11/2014 16:41:34
            #168487
            Diane Carney
              @dianecarney30678
              Terry, Ian, Michael
              I have edited the title, Michael, and edited the thread by deleting some posts. Sorry chaps.
              Carry on….
              Diane
              #168489
              Nick Moody
                @nickmoody91191
                Excellently edited Diane, very diplomatic! Well done.
                #168496
                  Thanks, Diane
                  Ian P
                    @ianp
                    I knew spell and grammar checkers existed but you cant beat good old fashioned common sense, Thanks Diane
                    IanP
                    #168508
                    Bazyle
                      @bazyle
                      The hand pump feeds the backhead clack and the the injector and axle pump go to the top front.
