Ornamental Turning
Ornamental Turning
Home › Forums › Workshop Tools and Tooling › Ornamental Turning
  • #437606
    James A
      @jamesalford67616
      I am asking purely out of curiosity as I do not envisage ever doing any ornamental turning: is it possible to make an attachment to use on a standard lathe so that it can do ornamental turning? I am thinking more of the engine turning and jewelling than the finish with overlapping burnished circles.
      Jamie.
      #19531
      James A
        @jamesalford67616
        #437611
        Bazyle
          @bazyle
          Yes. AS a start all you need is a way of indexing the spindle – eg use your change wheels, and a small spindle to mount on the toolpost – eg a dremel drill.
          Plenty of examples on the internet.
          #437613
          Frank Gorse
            @frankgorse
            “Ornamental Turning” by T.D.Walshaw (the proper Tubal Cain,not the American one) has a chapter called ’Ornamental Turning on the Engineer’s lathe’ and is essential reading for anyone who is interested in the subject.
            #437614
            John Haine
              @johnhaine32865
              Or of course you can do it on a CNC mill …
              #437617
              Vic
                @vic
                Google Rose Engine Jamie. Here’s a link for one hit.
                ega
                  @ega
                  The Quick Step Mill or device with similar function will do some kinds of ornamental turning. The maker John Payne used to demonstrate this at exhibitions.
                  #437642
                  V8Eng
                    @v8eng
                    There is a Society of Ornamental Turners who have a stand at some ME Exhibitions.
                    Work seems to go from jewellery size up to large objects and watching the machinery is fascinating especially as some of it looks very old.
                    I have put a link to the SOT Website here as it might have information on modding lathes:-
                    SOT
                    Edited By V8Eng on 17/11/2019 11:22:42
                    #437643
                    Dalboy
                      @dalboy
                      I have a set of PDF on making a simple Rose engine if interested PM me your e mail and I will send them to you. It is designed more for the woodturner but may still be of use.
                      #437644
                      Russell Eberhardt
                        @russelleberhardt48058
                        You might be interested in this clickspring video. He uses a mill but the same thing could be done on a lathe with a dividing head mounted on the cross slide.
                        Russell
                        #437653
                        Martin Connelly
                          @martinconnelly55370
                          J. H. Evans wrote Ornamental Turning in 1886. This is now available in paperback form (1993) so you may be able to find a copy.
                          Martin C
                          #437716
                          James A
                            @jamesalford67616
                            Thank you for all of the book suggestions and the links, which I shall look at. I had done some searching already, but mostly found references to purpose-built machines, rather than modifications for a standard lathe. The Tubal Cain book sounds particulalry promising.
                            Jamie.
                            #437731
                            Ian Welford
                              @ianwelford58739
                              drop mark baker at GMC publications a line as they had a series showing how to adapt a rotary table, chuck and compound table to fit on a wood working lathe and convert it into a basic ornamental turning set up. I have the articles some where as I bought the equipment. last year to do just that but then events so far have prevented me achieving it
                              regards Ian
