Optical chucks
Optical chucks
Home › Forums › Workshop Tools and Tooling › Optical chucks
  • #281246
    hawkeyefxr
      @hawkeyefxr
      Back in the dark ages (1964) i was into my apprenticeship, at this time i was in the toolroom. It was just a small toolroom with myself and 'arry'.
      Anyway we had a bench pillar drill that had an optical chuck, you viewed through an optic and could see down to your work piece and see you scratch lines from the vertical vernier. You line the cross hairs up and used a centre drill for quite accurate drilling.
      No a patch on todays CNC machining i know.
      My question is are these still made, are there IR deices that do the same. I have looked but cannot find anything even resembling what i am looking for. I don't even know if Optical chuck is the right name for them.
      I need to drill eight holes fairly accuratley, hoping someone can help me or maybe just tell me i am completley mad.
      Edited By hawkeyefxr on 30/01/2017 13:53:48
      #18389
      hawkeyefxr
        @hawkeyefxr
        #281254
        Nick_G
          @nick_g
          Posted by hawkeyefxr on 30/01/2017 13:52:52:
          If they do still exist I would imagine a decent quality one would be many times the price of a DRO system.
          Nick
          #281255
          davidk
            @davidk
            Something similar was discussed back in 2015:
            David
            #281262
            KWIL
              @kwil
              What do you mean by "fairly accurate"? Define the problem and layout.
              #281269
              Roderick Jenkins
                @roderickjenkins93242
                Perhaps something like this **LINK**
                Rod
                #281284
                hawkeyefxr
                  @hawkeyefxr
                  Nick
                  Whats a DRO system?
                  By fairly accurate i mean 2 to 4 thou max
                  I have looked at the links but they deal more with description. I realise time has moved on but i thought i would find some kind of lead.
                  I have a wood turning chuck, it's similar to an engineering one except where the jaws on an engineering chuck hold the work piece on a wood chuck there are different secondary jaw sets that bolt to the jaws that run on the scroll.
                  i want some jaws that fit my particular chuck that allow me to mount a piece of ply where by i can machine the ply to hold a bowl.
                  Basically a 5in dia x 1/2 flat disk, it's then cut into four quarter each with two holes in to locate to the chuck jaws.
                  #281289
                  Nick_G
                    @nick_g
                    Posted by hawkeyefxr on 30/01/2017 16:35:50:
                    Nick
                    Whats a DRO system?
                    A 'Digital Read-Out' system.
                    But having been now seen the link kindly provided by Rod it may seem that I was wrong about the costing.
                    But you would of course then have to make the optical device linked. And it's accuracy for ever more would depend on how accurate you made it in the first place. smiley
                    Nick
                    #281295
                    Journeyman
                      @journeyman
                      This web article describes a home build centre finder using the inards of a cheap web cam, might be of use. Issue 121 of MEW
                      Edited By Journeyman on 30/01/2017 16:52:38
                      #281304
                      AJW
                        @ajw
                        I used to deal with an old time toolmaker who used something like you describe, don’t know what it was called but it was basically a clear plastic block with a hole in it. Across the underneath face it had two lines engraved/scribed, these lines were lined up vidually on your marked out work and a close fitting centre punch dropped into the hole and tapped.
                        This guy could work to close tolerances using it!
                        Alan
                        #281309
                        Rik Shaw
                          @rikshaw
                          Alan – That would be an optical centre punch. I have one made by Mr.Dankroy and very good it is to. I use all the while.
                          Rik
                          #281311
                          Cornish Jack
                            @cornishjack
                            The very first issue of MEW carried just such a device – home brewed, of course and very simple – it must have been 'cos I made one and it worked!smiley It may still be lurking in the chaotic shambles of my workshop but more likely went to the skip with the other debris from the 'surge'. I also had a much rarer beast – a drill chuck on a 2MT taper which had a built-in centring viewer!! Clever idea but a bit short on practicality, as you had to place your eye against the chuck body to view the centre!sad If not available elsewhere, I may be able to send you a copy of the MEW article, assuming Neil and his paymasters don't object.wink
                            rgds
                            Bill
                            #281315
                            Tractor man
                              @tractorman
                              Centre scope but a costly item to ensure accuracy as a one off. Mick
                              #281386
                                Posted by Cornish Jack on 30/01/2017 17:48:39:
                                rgds
                                Bill
                                Tell you what, send me a scan of it and I'll put it up on the website
                                #281396
                                SteveM
                                  @stevem36008
                                  Stefan Gotteswinter shared an excellent video on YouTube about the design and construction of an optical microscope. Like all his videos it's very interesting and well worth watching.
                                  Centering Microscope
                                  #281402
                                  JohnF
                                    @johnf59703
                                    Hawkeye you are not mad they were in regular use in the 60's bothe before and after that time they were called Optical Centre finders as far as I recall, used them many times.
                                    Both Roderik and Steve M are spot on but the ones I used the eye piece was at 45 deg so easier to view than the 90 deg ones shown but you would need a prism for this. Never seen a S/H one for sale but guess they must come up now and then.
                                    #281407
                                    Cornish Jack
                                      @cornishjack
                                      Neil – scans sent as 4 .jpgs – hope they are OK
                                      John F – The above item incorporates a home made prism and could, therefore be to any angle required.
                                      rgds
                                      Bill
                                      Edited By Cornish Jack on 30/01/2017 23:44:47
                                      #281408
                                        This is a very good place to buy prisms: **LINK**
                                        http://surplusshed.com/search.cfm
                                        Just put prism in the search box and have a browse.
                                        Postal charges a very honest too [although USPS costs increased quite dramatically last year]
                                          Optical finder article now here:
                                          http://www.model-engineer.co.uk/OpticalFinder
                                          Thanks Bill.
                                          Reg Rossiter
                                            @regrossiter24538
                                            #281643
                                            Peter Spink
                                              @peterspink21088
                                              Posted by Journeyman on 30/01/2017 16:49:47:
                                              I built one of these three or four years ago. It's mounted on a 2MT arbour and the fiddly bit was getting the camera lined up with the axis of the mill. In conjunction with the DRO it is one of the most useful things in my workshop for edge finding, centring and measuring etc.
                                              Even though the software is still available on the site, the chap that wrote the software is no longer supporting it.
                                              Presumably an alternative would be the camera plug in on the Mach 3 software?
                                              #281649
                                              John Stevenson 1
                                                @johnstevenson1
                                                Or look at something like an App similar to Camerfi that works on a mobile phone but you will need a USB to Micro USB converter for the cable.
