Milling machine & Shaper query
Home › Forums › Workshop Tools and Tooling › Milling machine & Shaper query
Viewing 25 posts - 1 through 25 (of 33 total)
  • #19606
    swood1
      @swood1
      #449276
      swood1
        @swood1
        Hi all,
        I have always fancied owning a shaper machine; I like the simplicity of the machine and have a few projects that I could see would suit it better than my Mill. But I already have a small mill, I was wondering do some of you out there actually have both machines and more importantly do you actually use them?
        Would the shaper be a waste of already lacking space…
        Kind Regards
        Steven
        #449283
        mgnbuk
          @mgnbuk
          I have a Boxford 8" shaper and a small milling machine (Emco FB2 clone). I got the shaper first, because it was available first at a price that suited my budget.
          I tend to use the shaper to hog off metal before moving over to the mill, as it can shift metal more quickly with inexpensive & easily hand ground tools than the 2MT spindle milling machine. But there is also the "fun" factor – it is rather satisfying to use. It is doubtless capable of much more than I have done with it to date.
          Would I have bought it if I had found the milling machine first ? Probably, just for the "fun" factor alone. But, while I am getting pushed for space, I don't yet feel it is taking up a corner that I would rather use for something else.
          Nigel B.
          #449294
          Brian Wood
            @brianwood45127
            Steven
            I had made my Dore Westbury mill when I bought the shaper, an Elliott 10. . It has done some useful work as mgmbuk has described and I am fortunate enough to have the space available.
            Mine has the satisfying sound of a washing machine when it is running and just making a flat surface is almost mesmeric. It might be a luxury if your space is tight, but for doing the grunt work on a casting for example it is hard to beat.
            Regards Brian
            #449308
            Howard Lewis
              @howardlewis46836
              With a hand powered Shaper, like the Adept No.2, you won't hog off large bits of metal.
              It is a small machine, and very low powered. But it can do things that a Mill cannot, such as cutting internal keyways, or even internal splines or gears.
              It will generate flat surfaces because the end result is the combination of the tool moving in two different planes as it cuts. A mill that is even slightly out of true will generate one or more shallow hollow grooves.
              Sharpening the tool is far easier than trying to sharpen an End Mill. It is just like a Lathe tool, so can be a form tool, capable of easy modification, if so needed.
              A vertical Mill is the machine for producing a slot, or keyway, with a radius at the end..
              Horses for courses again
              #449319
              Ady1
                @ady1
                I have finally, in the last day or so, got my milling attachment for my lathe up and running
                (will put pics up if I can ever find my wee camera)
                Initial testing is looking really good compared to a milling slide and accuracy looks exceptional for a bespoke Ady item
                Using it has also reminded me why I detest milling and would much rather use the shaper for doing a job if I have a choice, my biggest gripe being your reliance upon complicated and expensive cutting bits to carry out even the most basic simple jobs
                A shaper can hog a job virtually for free, it sounds great as it shaves metal away, and they have good accuracy
                but of course every now and then you will be forced to take the milling route, plus a decent mill makes a good drill too
                GL
                #449320
                not done it yet
                  @notdoneityet
                  Agree entirely with Howard. I like my handraulic shaper for the things it can do – like internal keyways. But it is never going to compete with a powered machine.
                  For most things I do, a larger shaper would be good but I don’t think it will happen. I might progress to a small powered machine as another ‘toy’.
                  I use my lathe, both mills and the Drummond shaper. Not universally because the particular machine is the best/easiest to get the job done.
                  If milling attachments were so good for everyone, mills would not have become so popular. People use what they have and modellers will make models according to the size of machines they have – although smaller models can be made on a larger machine, but not so easy the other way round. Only you would know the answer to your question.
                  I might like to add a surface grinder, but it would not get much use. But that would not necessarily stop me if a suitable one came up for sale.🙂
                  #449321
                  IanT
                    @iant
                    Posted by Steven Woodward on 27/01/2020 16:05:59:
                    Would the shaper be a waste of already lacking space.
                    Seems a simple enough question Steven
                    Well, I have two shapers and two mills (all four of which I use) so I seem qualified to answer your question.
                    Logically, the answer is that you do not need a Shaper – especially if you are tight on space. With a mill and a lathe you can already do (almost) everything that you can do with a shaper.
                    However, the reason I use my shapers (quite apart from the great finish and simple tooling) is that I enjoy doing so. They are somewhat addictive and I often find myself 'shaping' when I probably (logically) shouldn't be.
                    So the answer is that whilst you don't need a Shaper – it sounds like you simply want one (which is an entirely different matter!).
                    Please also note that (in my view) a hand shaper is a different beast to a powered one – and in my case I use them for very different kinds of work. As Howard says, you will not be able to (quckly/easily) remove large amounts of metal with a hand shaper, although you can certainly do good/accurate/delicate work on smaller parts with one. You really need a powered shaper to make any sensible comparisons with a milling machine. I generally use my hand shaper in preference to hand tools – as I'm simply not good enough with 'saw & file' for some things….
                    IanT
                    #449322
                    Andrew Evans
                      @andrewevans67134
                      I would say get the shaper if you fancy it. I had a Boxford shaper and a milling machine in the past and did use it. It is a nice machine to use, quite quiet and sort of peaceful – there is something mesmerising about watching it work. However when I moved house and now have a smaller workshop I chose to keep the milling machine and sell the shaper.
                      #449325
                      peak4
                        @peak4
                        Last year I bought an 8" Boxford shaper to accompany by Dore Westbury and Centec 2B mills.
                        It does get used now, and it will get used more as and when I get more workshop time.
                        Tooling is cheap and easily re-sharpened.
                        I know of an Elliott 10M which might be coming up for sale, though I don't thing it's been used for a year or two.
                        I guess that would depend on your budget and locality.
                        If you're any where near Buxton, you're welcome to drop in and have a look round my Boxford, though it's certainly not for sale.
                        Bill
                        p.s. Hello and welcome by the way.
                        Edited By peak4 on 27/01/2020 19:51:38
                        #449333
                        Peter Simpson 1
                          @petersimpson1
                          I to have a Boxford 8" shaping machine and Tom Senior milling machine, I usually use the shaping machine to reduce bar stock to the correct usable size. It gives a fabulous finish and is very enjoyable to use, It will remove 0.5mm cuts on BMS with ease, although I saw somebody on here a while ago stating his could cut 2.0mm cuts on BMS,,,,,,not hope in hell.
                          When I was an apprentice at ICI Billingham many years ago I watched a large Shaping machine in the mill wrights shop throw huge red hot cuttings all over the workshop. Happy days.
                          #449338
                          Plasma
                            @plasma
                            I have vertical and horizontal mills and an Elliott 10M shaper.
                            Each gets used regularly depending on the job in hand.
                            I bought the shaper as we were not allowed near the ones at school due to their inherent danger. I always said I'd get one and learn to use it.
                            The finish beats milling and is the ideal precursor to surface grinding.
                            Buy one and enjoy a cuppa as it cuts with that previously described washing machine sound.
                            Mick
                            #449340
                            IanT
                              @iant
                              My Acorntools (Atlas) 7" can rough up to about 20thou (0.5mm) using a fine feed without sounding too uncomfortable Peter – so very similar to your 8" Boxford I think.
                              A 24" stroke Hydraulic would be very nice to peel metal back with (it wouldn't even break a sweat with 2mm) but I think it would probably create a black-hole in the floor of my Shed and then promptly disappear into it….
                              IanT
                              #449423
                              swood1
                                @swood1
                                Some interesting feedback here, I think the general consensus is that if you can afford it and you have a use and room for it then go for it. The idea of just sharpening a bit of HSS and using this for cutting metal sounds ideal to me..
                                Now I need to measure my garage workshop…. I am thinking I could fit it in the end by the garage door but I was trying to avoid blocking this entrance up (although I hardly use it).
                                We shall see.
                                Steve
                                #449433
                                Ady1
                                  @ady1
                                  Use the fancy HSS if you have it, like M35 cobalt HSS
                                  Fancy HSS is great for slow speed stuff and holds its edge much better with slow speed cutting
                                  both for lathe turning and shaping jobs
                                  GL
                                  #449441
                                  Another JohnS
                                    @anotherjohns
                                    Steven;
                                    Like IanT's wants vs. needs; I've had two shapers in my workshop. Now I have none.
                                    The last to go was a Drummond hand shaper. Another shaper came past my nose, and I turned it down.
                                    My reason is that, in my limited workshop time, milling machines make so much more sense, especially when one considers the space taken.
                                    I sat down and wondered: "What do I want to do – use random bits of machinery for it's own sake, or use machinery to make things?"
                                    I also built a Worden T&C grinder from Hemingway, which works well for sharpening everything from milling cutters to drill bits to lathe tools.
                                    Like everything, it's all what you are happiest doing!
                                    #449446
                                    Saxalby
                                      @saxalby
                                      I have a Boxford shaper and a Tom Senior Mill. Use the shaper a lot for key slots in gears and pulleys etc. Also love the very fine finish that you can get on steel, almost a ground finish.
                                      Would never part with the shaper.
                                      #449447
                                      Buffer
                                        @buffer
                                        Mine shoots swarf across the garage that leaves a very satisfying trail of smoke lingering in the air like shooting stars. Apart from this its a bit of a pain to set up as I find it much quicker and easier to use a spinning edge finder on the mill. And a decent fly cutter on my mill using a lathe tool seems to make a flat surface just as well but in a fraction of the time.
                                        #449461
                                        Baz
                                          @baz89810
                                          Spent a few very enjoyable hours yesterday playing with my Perfecto 7 inch shaper, bought it new back in the seventies and apart from a repaint into a Myford grey colour it is absolutely original. The job this time was a pair of steam chests for a 2.5 gauge loco, they only had about fifty thou on each face to come off so a roughing cut all round of about thirty thou and then two finishing cuts, no time wasted because while shaper was doing its thing I was sharpening a few milling cutters. For larger jobs I also have an Elliott 10m, gives a beautiful finish for port faces etc, it’s got a three phase motor but runs beautifully on a transwave converter.
                                          #449521
                                          swood1
                                            @swood1
                                            It sounds like people like their shaper machines….
                                            Out of interest what is the sort of footprint required for an 8" shaper like a Boxford and how heavy are they?
                                            Steven
                                            #449550
                                            thaiguzzi
                                              @thaiguzzi
                                              +1 on "most" of the comments above.
                                              A mill even with a fly cutter can never replicate the finish a shaper can achieve with the right ground tool, especially a shear tool taking a final couple of thou off.
                                              Internal keyways and gear cutting are also a boon with the shaper.
                                              It may often be slower vs a mill on certain procedures, but it is a helluva lot more fun.
                                              I get immense enjoyment from operating the lathe and the shaper, but a mill is always a "do i have to?", "i suppose i must", type job, i find a lot of common, simple milling operations almost boring. The lathe and shaper – never.
                                              I note there are a lot of Tom Senior mill and Boxford shaper owners above, great minds think alike, perhaps we should start a society/club?
                                              #449551
                                              thaiguzzi
                                                @thaiguzzi
                                                Posted by Peter Simpson 1 on 27/01/2020 20:13:52:
                                                Sigh.
                                                I presume you meant me. Again. Here's some proof. Boxford 8" with a 3/4hp motor, single phase. Even the owners manual states it will rip 3mm DOC off.
                                                My suggestion is don't baby the machine or learn some proper tool grinds.
                                                The above were 1.5mm cuts minimum (0.060&quot, maybe 2mm (0.80&quot, can't remember, but the steel was nasty flame cut no-name. Stroke was the full 8" and slowest speed with a light feed.
                                                Note the flame/oxy cut billet below.
                                                Same stuff finished off with a shear tool. Notice the difference in swarf with pic no. 1 above.
                                                #449605
                                                peak4
                                                  @peak4
                                                  Posted by Steven Woodward on 28/01/2020 22:42:07:
                                                  Steven
                                                  Steven, the Boxford chip tray is 18 ½" x 34", obviously that's a bit bigger than the cabinet floor footprint.
                                                  On the long side, the ram needs a further 7" beyond the tray as it slides back and forth.
                                                  The manual doesn't seem to give a weight, but I moved one myself in a van.
                                                  It was already partially stripped down, also separated from the cabinet, and I had a hand to load up.
                                                  Unloaded OK on my own, but I do have an elevating hydraulic table/trolley on wheels.
                                                  Reassembled OK alone, and added a VFD in the main cabinet. I retained the original mains push buttons, but removed the contact breaker behind them and replaced with microswitches to control the VFD.
                                                  N.B. make sure the motor runs in the correct direction; the cutting stroke should be slower than the return stroke.
                                                  Bill
                                                  #449608
                                                  Andrew Tinsley
                                                    @andrewtinsley63637
                                                    If you have room for both mill and shaper, then go for the shaper. All the advantages enumerated above and much easier to cut dovetails than with a mill!
                                                    Andrew.
                                                    #449616
                                                    Peter Simpson 1
                                                      @petersimpson1
                                                      Well just to check I set a 2" square by 6" long piece of BMS up today. Selected the lowest pulley speed. VSD at 50Hz and had a go with a 2mm DOC. As soon as the cutting tool got to its full 2mm cut the machine stalled ? God knows what an 3mm DOC would have achieved. I would be interested to see how your cutting tool was ground. I may not have the correct tool shape. More than willing to have another go with a different cutting tool.
