Miller Machine –
Miller Machine –
Home › Forums › Workshop Tools and Tooling › Miller Machine –
  • #452852
    JOn Hirst 1
      @jonhirst1
      Please could anyone tell me the brand of this milling machine? I’ve looked everywhere… the first line of the switch instructions are in German.
      I have uploaded the image here on
      Edited By Neil Wyatt on 18/02/2020 14:08:49
      #19631
      JOn Hirst 1
        @jonhirst1
        Which machine is this?
        #452870
        Gray62
          @gray62
          Has many similarities to an Emco FB2 however there are also many clones around have a look here
          #452873
          Joseph Noci 1
            @josephnoci1
            Mirror of an EMCO-FB2 – If as you say there is German text, ( or rather Austrian?), then it could be a genuine FB2 , but fitted to a different base – the base is NOT EMCO FB-2 at all. The column and head were also supplied as a milling accessory for the EMCO lathes – Super 11 , V13, etc, and folk would fit that head to an aftermarket base to use as a stand alone mill. Rather confusing though…The mill table looks like the genuine thing, but could not exist on its own – the dovetails are part of the base.
            Must admit, if it is a clone, it seems a 'good' one!
            Also, the side covers on the gearbox normally had the EMCO name cast in on the genuine FB2
            The part of the base where the column enters – is it separate to the actual base itself – bolts to the base from the rear – or is it all cast with the base?
            A pic of one of my FB-2's – I have a few..
            Joe
            #452880
            Clive Foster
              @clivefoster55965
              Looks incredibly similar to the Warco Clone version of the FB2, especially the base.
              Quite likely that the same machine was also supplied to a German dealer with appropriate language markings.
              #452888
              Bob Rodgerson
                @bobrodgerson97362
                I had an Axminster round column mill that was very much like that.
                #452901
                Baz
                  @baz89810
                  It is a Warco clone of the Emco FB2. Warco dropped it from their range at least ten years ago.
                  #452909
                  Georg49
                    @georg49
                    I had one, sold as a Rong Fu. Good copy of the FB2, but the makers 'improved' on the FB2 by adding an extra inch on the spindle and providing it with male Myford thread. The only thing they forgot was to lengthen the drawbar by an inch …
                    #452910
                    JOn Hirst 1
                      @jonhirst1
                      Thanks for clearing this up and for sharing your knowledge! I am very surprised too how similar they look not mention they do look a quality built machine. Based on the link Gray shared the base gives it way. I am shifting a few machines which I have inherited. I'll stick it on eBay later if anyone is interested in it.
                      Thanks in advance!
