Metalworking carriage on a woodworking lathe?
Home › Forums › Beginners questions › Metalworking carriage on a woodworking lathe?
  • #104008
    Graham Rounce
      @grahamrounce14492
      For my gyroscope project, I’ve obtained some metal rings (pipe “slices”) about 6″ diameter and say 1cm x 1cm in cross-section. (I’ve put a pic in my Album – is it visible?)
      Now they just need a little trueing up
      As I don’t have the money or the room for a whole lathe, I was wondering… If I bolted just the carriage to my wood lathe, is there any reason why it shouldn’t work? I’d have to adjust the feed position by moving the carriage manually and re-bolting, but the X and Y tool movement should be ok?
      Among my worries are Vibration (only do small cuts), Inappropriate speed, and Affordability of even a 2nd-hand or surplus carriage.
      Is there any point in even thinking about this?
      Thanks,
      #6448
      Graham Rounce
        @grahamrounce14492
        #104019
        NJH
          @njh
          Hi Graham
          In principle it could work. You will need some secure way of holding the rings and a very much slower speed than is usually available on the wood lathe.
          Using a compound slide on a wood lathe is not a new idea see HERE
          It might be safer and quicker to seek the services of a friendly model engineer though!
          Good luck
          Norman
          #104043
          Jeff Dayman
            @jeffdayman43397
            The spindle speed on a wood lathe (usually 500-2500 rpm for hobby lathes) is far too high for metal cutting especially a large dia piece as you describe. Unless the cutting speed is about 150 surface feet per minute for steel, you will burn up the tools. A 6" diameter is 1.57 feet in circumference. At 150 sfpm this is around 95 rpm (slower than that will work too).
            JD
            #104058
            Ian S C
              @iansc
              I'v got the "Popular Mechanics do it yourself Encyclopedia", and vol 13 has a build artical for a compound rest for a wood lathe. From what I can see at a glance, the only machine needed (you could proberbly do without), is a drill press. It does suggest a jack shaft to drop the speed to something usable for metal turning. It's one of many articals from the Popular Mechanics mag of the 1940s to the 1960s. Ian S C
              #104063
              Terryd
                @terryd72465
                Hi ian,
                Do you have the original publication details for the article as the Popular Mechanics magazines are published on Google Books
                Terry
                #104065
                KWIL
                  @kwil
                  The Myford ML8 woodworking lathe used to have as an optional accessory, a compound slide.
                  #104067
                  MICHAEL WILLIAMS
                    @michaelwilliams41215
                    Graham ,
                    You could certainly rig up a compound slide but its probably not nescessary for this one task . If you can get lathe to turn reasonably slowly you can true small errors in the rings with a file using a block of wood as a support and guide .
                    I've done this sort of thing using a power drill in the vice as the only 'lathe' available and succeeded in making adequate small steam engine parts .
                    Before even that I and a friend of mine made simple model railway parts using a hand drill and needle files
                    I never came to any harm but please take great care if you are not used to using power tools .
                    Actually given the rough and ready nature of the proposed construction you could true up the rings just by hand filing – no lathe needed at all .
                    Regards ,
                    Michael Williams .
                    #104076
                    NJH
                      @njh
                      Graham
                      If you decide to persue the wood lathe option…….
                      Does your lathe have the option for fitting a faceplate to the left hand end of the mandrel? If so you could fit this and make a handle from a piece of broomstick and screw this such that it is at right angles to the plate. Disconnect the drive belts and enlist the services of a willing (?) volunteer to wind the handle slowly, in the manner of a barrel organ operator, whilst you operate the tool slide. You will then have what many of us wish for – a variable speed drive for free! ( Although I guess it may have some hidden costs later in terms of favours or beers owed )
                      I still favour the path of finding a willing ME friend!
                      Norman
                      #104102
                      Springbok
                        @springbok
                        Graham
                        Where are you if in west country welcome to come and use my workshop
                        Bob
                        #104123
                        Ian S C
                          @iansc
                          Terry, I'v got the "Popular Mechanics DIY Encyclopedia", my dad had it, so I just hung on to it as there are some useful bits in it. I imagine all this stuf is on line, under Popular Mechanics. The artical covers 6 pages, including 2 pages of drawings. Ian S C
                          #104283
                          Graham Rounce
                            @grahamrounce14492
                            Sorry I’ve been absent, but thanks for all that info & suggestions (and the offer, Bob, but unfort I’m in Bethnal Green, London).
                            I’ll post pix (eventually) when it’s done.
                            Cheers again,
                            #104302
                            Dunc
                              @dunc
                              While this video deals with wood machining the idea of a metal-working tool approach is evident
                              Don't know if these reference the same article above but Popular Mechanics Feb 1959 shows a home-built lathe. Might get some ideas there.
                              Last (& not least), I have noted references "on the net" to building small lathes in old issues of ME but I have no further data.
