Materials from scrap yards in West Yorkshire
Home › Forums › Beginners questions › Materials from scrap yards in West Yorkshire
Viewing 25 posts - 1 through 25 (of 30 total)
  • #104517
    richard3267
      @richardrogalewski21509
      I am a beginner. I need some mild steel tubing 1 1/2" OD and the wall thickness from 2 – 3mm.
      The first port of call I think of is calling at a local scrap-yard.
      I'm near Wakefield in West Yorkshire and wonder if anyone can recommend a scrapyard where I might get things like mild steel tubing, bar and plate and such things.
      Sure a lot of scrap-yards, but mostly car scrap. I don't think I'm going to get engineering materials at such places. Thanks.
      #6454
      richard3267
        #104892
        richard3267
          I might be beeter going to Dunkerely Steels. Not far from me.
          #104893
            Try this e-bay seller I've used them in the past for tube.
            #104898
            keithmart
              @keithmart
              Hi
              You could try these:
              http://www.metalsupermarkets.com/
              They are next to the roundabout at morley/bradford road.
              They do quite a big range, but I am not sure about steel tube. it could be worth a phone call.
              Keith
              Leeds UK
              #104907
              KevinW
                @kevinw
                Richard,
                You could try Blackgates Engineering. They are at Shaw Cross Business Park in Dewsbury.
                http://www.blackgates.co.uk/
                Kevin
                #104914
                Robin teslar
                  @robinteslar
                  RR
                  What about some scrap scaffold tube, that is 1.5ins NPS, appox 3mm wt
                  Robin
                  #104915
                  Steambuff
                    @steambuff
                    Richard,
                    What are you using it for (What are you building)?
                    I would be wary of anything from a scrap yard (or scrap bin for that matter), you don't know what you are getting …. for some things it does not matter but for others it does.
                      Scaffold tube is about 1 3/4 (44mm) OD not the 1 1/2 that the OP wants.
                      J
                      #104925
                      Andyf
                        @andyf
                        You could try M-Machine . 10SWG = 3.25mm, 14SWG = 3.25mm.
                        Andy
                        #105000
                        richard3267
                          I'm making home-made acros out of scaffolding tube. The distance between floor and celing is 2.4m. Scaffolding tube is 2.1m. Each end of scaffolding tube will have 1.5" pipe, 3mm wall thickness. I think scaffolding I have is about 48.3mm OD and about 32mm ID.
                          Dunkerley Steels don't sell 38.1mm tube as it's not a standard size.
                          I contacted Eric France, but they don't sell the tubing.
                          I see 38.1mm tubing on Ebay. But, I'm trying to pick up locally.
                          Edited By Richard Rogalewski on 29/11/2012 12:14:10
                          Edited By Richard Rogalewski on 29/11/2012 12:28:54
                          #105001
                          richard3267
                            Posted by JasonB on 28/11/2012 12:49:15:
                            Yep, at the moment I'm likely to get tubing from Ebay. Thought I might be able to source from local scrap-yard, but no joy on that front.
                            #105002
                            richard3267
                              Posted by Robin teslar on 28/11/2012 16:55:24:
                              RR
                              Robin
                              Oh, is that a smaller size of scaffolding tube that is 1.5" OD?
                              Answer: No, standard size of scaffolding is 48.3mm OD and is I think 1.5 NPS.
                              But, there is I think scaffolding pipe that is smaller than 48.3mm OD.  But, I'm probably wrong about that.
                              Edited By Richard Rogalewski on 29/11/2012 12:31:07
                              Edited By Richard Rogalewski on 29/11/2012 12:39:10
                              #105003
                              Martin W
                                @martinw
                                RR
                                If you are making acros, then depending on the load you intend to support, I would suggest you need to know the type and characteristics of the metal you will be using. If you go to a scrapyard then you will have no idea of the type of metal nor its history. Could be in the extreme a recipe for disaster.
                                Martin
                                PS
                                Does really fall into the remit of model engineering?    dont know
                                Edited By Martin W on 29/11/2012 12:38:24
                                #105004
                                richard3267
                                  Posted by Martin W on 29/11/2012 12:35:09:
                                  RR
                                  Martin
                                  PS
                                  Probably not, but the question was about materials from scrap yards.
                                  But, yes, maybe I ought to buy new.
                                  Edited By Richard Rogalewski on 29/11/2012 12:44:27
                                  #105007
                                    I'd be worried that the 38mm tube is too thin unless you go for thick wall. Accrows have the inner part the same size as scaffold tube and the outer larger. Also make sure you allow a good overlap.
                                    #105008
                                    richard3267
                                      Posted by JasonB on 29/11/2012 13:07:55:
                                      So, professionally made acros have it wider at the ends. Noted. Given the job I have to hand, I think 3mm thick-wall will probably do. Tubing at one end affixed. Top end made adjustable just a bit. I was thinking no less than 200mm overlap at top with a 500mm tube. So, there would be 300mm variation possible on top tube, although that might not be neccesary. I am going to chock-up the acro with wooden chocks at the bottom.
                                      Without acros, the ceiling would probably not fall anyway, (that has been established in general), but I ought to err on the side of caution.
                                      Edited By Richard Rogalewski on 29/11/2012 13:33:13
                                      #105010
                                      Keith Long
                                        @keithlong89920
                                        Richard
                                        is it really worth the time and effort as well as cost to make Acrows when you can hire them for about £7-£10 a week?
                                        I know which I'd prefer to do.
                                        Keith
                                        #105011
                                        Martin W
                                          @martinw
                                          RR
                                          If the load is as light as you are suggesting then why not use wooden supports to secure the ceiling. These will be lighter, quick and easy to cut to length, simple to chock into place and probably cheaper than steel/scaff bar. Might even be able to use it later on another project i.e. wall studding wink 2.
                                          Martin
                                          #105013
                                          Robin teslar
                                            @robinteslar
                                            Yup, thats what I did. Bit of 4×2 and I drilled a hole in 13mm hole in one end to take a 1/2w bolt/washer nut. the bolt was 6in long and the hole was 3in deep so fine tuning for loading was easy. I only had to support the floor above a bay window, i used 2 and the load was <100kg each
                                            OBTW I nailed the bottom to the floorcheeky
                                            No probs
                                            Robin
                                            #105015
                                            richard3267
                                              Yep, the more I think about it, the more I feel I ought to buy some 100mm x 100mm x 2.4m reclaimed timber. Cheaper that way, and when done I have timber I can use.
                                              #105017
                                              Terryd
                                                @terryd72465
                                                Hi,
                                                Why not 4×4 fence posts, you should allow for 2×4 or 2×6 long spreaders at top and bottom. Folding wedges at bottom will adjust accurately – nail wedges into spreaders when loaded. You could use the fence posts afterwards for a new fence or sell them on.
                                                Terry
                                                #105020
                                                Martin W
                                                  @martinw
                                                  Terry
                                                  Hey that's getting into heavy engineering wood wise smile o but at least if the job takes a time, super moist conditions etc they won't rot. Mind you if they come from the usual merchants they will have been in the open and will weigh very heavy.
                                                  Cheers
                                                  Martin
                                                  #105029
                                                  Andyf
                                                    @andyf
                                                    Is this just a domestic ceiling? If so, it shouldn't take too much holding up. Wooden posts. a bit shorter than the floor to ceiling distance, the shortness to allow for the thickness of a loose plywood or similar spreader pad at the top, and for a bit of wooden shimming under the foot. Hold the pad up against the ceiling with the pole, and add shims beneath until the post starts jamming when it's a couple of degrees away from vertical. Then whack the foot with a lump hammer until the post does reach vertical, lifting the ceiling fractionally as it jams in place.
                                                    I used this technique when single-handedly cladding my workshop ceiling joists from beneath with heavy 8×4' sheets of 12mm chipboard, and it should work just as well to support a whole ceiling, if you use enough props. My old Machinery's Handbook quotes 550lbs per sq inch of cross section for low-quality pine in compression along the grain, so if you use 4×4" (100x100mm) timber, each post should be good for about 4 tons. 1×1" posts would be OK in theory, but in practice they would probably bend.
                                                    Andy
                                                    #105030
                                                    Springbok
                                                      @springbok
                                                      acroprops cheap to hire
                                                      Bob
