Good Old British Weather?
Home › Forums › The Tea Room › Good Old British Weather?
  • #36198
    Anonymous
      Humidity issues.
      #513738
      Martin Connelly
        @martinconnelly55370
        Don't heat, de-humidify. Uses a lot less power with much better efficiency. The power needed to raise the temperature enough to reduce relative humidity to the point where it is not an issue is much greater than the power needed to reduce the humidity to the point where it is not an issue. When heating you have to heat everything which in a workshop can mean a lot of mass in machines. When dehumidifying you are just taking out a small amount of water in the atmosphere. It is also useful to note that, like a lot of chemical processes, rusting proceeds faster at higher temperatures.
        Martin C
        #513739
        Dave Wootton
          @davewootton
          Don't know if it would help with the styrene fumes, but I live very close to the sea and everything rusts if it can, costs me a fortune in brake discs and pads. in the workshop I have a cheap B&Q dehumidifier that does keep rust at bay from the machines and materials, which are kept well oiled ,I also use ACF50 on the machines, about four applications a year seem to do the trick.
          The dehumidifier cuts in and out on it's humidity sensor and doesn't seem to make much difference to the electricity bill.
          Martin is much quicker at typing than me!
          Edited By Dave Wootton on 16/12/2020 08:51:05
          #513741
          DiogenesII
            @diogenesii
            The weather-pattern of the last few weeks has been particularly bad for condensation – cold dry northerly air has been displaced by warn wet southerly air in repeated sequences of fronts passing through.. Last Sunday, in my unheated & draughty shed, everything was dry in the morning, but by lunchtime was quite literally running with condensation.
            It's vitally important not to let any fabric coverings lie directly on the bed / shears / table / any machined surface, because they absorb moisture from the atmosphere and then hold it in direct contact with the metal as it evaporates, causing corrosion.
            I keep everything oiled, throw a light sheet loosely over the machines to keep the dust and animal-poop off, and try to twiddle the handles / rack the saddle / raise and lower the head, etc. as & when I'm in the shed for any purpose..
            Oh yes, and of course any freshly cut surfaces develop surface rust, and all my free-cutting steel gains a patina.. ..c'est la vie..
            Edited By DiogenesII on 16/12/2020 09:09:08
            #513746
              Chief suspect is the paraffin heating! Does it have a chimney? If not, the heater is a potent source of warm wet air, slightly acid because of Carbon Dioxide.
              Condensation occurs whenever damp air meets a colder surface. Heat alone is unlikely to fix it, and applying warmth at the wrong time and in the wrong place will cause rather than prevent condensation.
              For example consider a cold workshop with high winter humidity. No problem because metal tools are at the same temperature as the air. Then the moist owner arrives and lights up a paraffin heater which dumps water into the air and quickly lifts the air temperature. Meanwhile the lathe stays cold because it's a large lump of metal insulated with towels. Water condenses on the machine because towelling doesn't stop wet air getting through the fabric. In this example, towels are a mistake, plastic sheet is better.
              Be aware the causes of condensation are local : what works for me may not do for you. General principles: stop water getting in and encourage damp air to leave. Dehumidify. Avoid temperature changes or slow them down as much as possible. Insulate! As warm wet air is more corrosive than cold wet air, cool damp air is better than warm and wet – put on a jumper!
              If heat is applied, aim to maintain a continuous steady temperature all the time. Don't switch heat on and off, and don't make wet heat by burning. Usually cheaper to keep machines just above air temperature with black heaters than to heat the whole workshop,
              If money is no object, apply professional methods. Double-skinned workshop with well insulated watertight roof and fully effective DPC and membrane. Air-conditioning left running continually, providing dehumidified air kept on the cool side at 17 or 18°C. Much harder for condensation to form when workshop and contents are all at the same temperature.
              not done it yet
                @notdoneityet
                If you dehumidify, draughts are your enemy, as you will be trying to dehumidify the whole world!
                If you use a compressor dehumidifier, efficiency will decrease rapidly below 20 Celsius and not a lot of good at all below 10 Celsius. Desiccator types are far preferred at these lower temperatures, but running costs are higher than compressor types (although that extra energy used might help to warm the workshop – it does with mine).
                Those using paraffin have the worst situation as the heaters produce lots of extra water and need good ventilation. The truck/caravan heaters are good as the exhaust is carried outside the workshop – but they need about 120W while operating, I believe.
                I’ve recently extended my workshop and am still boarding it out. Some door insulation needs to be refitted and there are still a few leaks. It has recorded a low 6 Celsius this last month (just briefly) but with good humidity levels – apart from this morning, as the humidifier didn’t run last night and I had taken in a full sheet of wet ply. After an hour and a half run the temp is up to11-12 Celsius and humidity is below 70% this morning. That 1 1/2h cost me nearly as much as a 3h run during the night.🙁
                #513753
                Frank Gorse
                  @frankgorse
                  According to Wikipedia-yes, I know- burning 1 gallon of kerosene produces 10 pints of water. Even if the figures are not exact surely that tells us all we need to know.
                  #513803
                  Steviegtr
                    @steviegtr
                    I used to use a propane type matrix heater. Too much condensation, so now only Electric heating.
                    Steve.
                    #513816
                    Clive Hartland
                      @clivehartland94829
                      This is more than likely caused by the Dew point. When I go to bed the cement path is dry, no rain, but in the motning it is all wet. The path is colder than the air and the dew condenses on the paths so the air must be full of moisture.This no doubt also gets into your workshop to condense on the cold machinery.
                      Luckily, I have a spur radiator in the garage and it keeps the garage dry, It was in tere when I bought the house and have never had any rust problems. It comes on with the central heating each year.
                      #513825
                      Henry Brown
                        @henrybrown95529
                        I was having problems with damp causing rusting but a bit of attention to the drafts and a dessicant dehumifier has sorted it. I put the dehumifier on for an hour when I go in first thing and it gives a bit of heat too, I keep a eye on the humidity level display on a cheap led display, if it starts creeping up then the dehumifier goes on for another hour. The machined surfaces on the lathe and mill always always have a wipe over with an oily rag.
                        #513840
                        Dave Halford
                          @davehalford22513
                          Having seen how soldering with gas and small amounts of a non acid flux still promotes rusting within 4" of the joint after a day and noticeable rust 2ft away on bare steel after 2 days (steel out of range stayed clean) I would suspect the fumes. More so if you had the paraffin stove on at the same time.
                          #513877
                          Bazyle
                            @bazyle
                            You haven't mentioned where you are. It has been a wet year in the west since about the first of July. there is a huge difference bwtween the west country or up norht and say London.
                            #513883
                            Richard S2
                              @richards2
                              I suppose I'm lucky, as my workshop is the ground floor integral garage. Unheated, it never suffers from condensation, or the rusting of machines. I presume it is because of very slow temperature variation and quite well sealed. It does get cold in there, so I don't stay down there for long.
                              I have had the challenge trying to complete the etch priming stage of my models with the high humidity and lower temperatures over the last 3 months down here in S/East England., but nearly finished that part now.
                              #513931
                              not done it yet
                                @notdoneityet
                                So I think I will buy a dehumidifier. Seal up the shop and pump away. Just have to watch fumes from paints and resins. According to the charts I probably need a 20litre version for the size and conditions.
                                I have bought meaco 8dl (or something like that) which are rated at 8l per day @~750W setting. All second hand basket cases or not running. They are generally easy to fix and cheaper to buy several than one new one. I have three (out of four purchased) which are serviceable.
                                I am currently running one for three hours each night on the lower power setting. Although they may well be more efficient running at full power/speed running them for longer may help during very cold periods. Humidity (likely still from the sheet of ply) was still high at 72% this am.
                                As they only hold 2 litres in the collector, I run two – each for a shorter time each day – if we go away in the winter. That avoids one filling (and switching off) or the possibility of one stopping working (they are not the most reliable machines.🙂 Now my workshop is about 30 cubic metres, I may find I need a bit more heat/drying time in the depths of winter. A small price to pay to protect several thousands of pounds of machines, tooling and equipment.
                                I have previously collected only about 2l per week, but I expect a little more – but not much more, once I get it sealed to my satisfaction.
                                Edited By not done it yet on 17/12/2020 08:03:21
                                #513950
                                  Posted by Ian B. on 16/12/2020 21:04:57:
                                  Thanks all for the replies. There is much to mull over. Whilst the parafin heater is held up as a significant problem IT DID NOT HAPPEN LAST WINTER. …
                                  Don't draw any conclusions from that! Without measuring what goes on in Ian's workshop we can only guess, but I suggest last winter was luck. Condensation mainly depends on how combinations of temperature and humidity change over time. Air pressure is involved too, but the effect is smaller. Common sense doesn't apply – you have to draw graphs.
                                  One simple principle stands – dry air can't cause condensation. Removing water is good, anything that adds it is bad.
                                  An ordinary paraffin heater is a device for covering cold tools in hot acidic water droplets! At minimum, fit a chimney. My advice – get rid of it.
                                  I couldn't find anything linking Styrene to rust. Possibly some of the other resins being used release acid fumes? Consult product Safety Datasheet. If they do, the paraffin heater may be making them worse too, the flame isn't hot enough to destroy, but it will warm acid air, and might convert fumes into something corrosive.
                                  Adrian R2
                                    @adrianr2
                                    Has anyone tried a heat pump? In theory 4x output for a given electrical input, they don't make a lot of heat hence all the discussions around problems retrofitting houses but for a workshop might be OK? I've toyed with the idea but as they are still £££ to buy then thinking is as far as it has got.
                                    Air conditioning was mentioned earlier, I have seen bidirectional units that will both heat and cool, but again, I've not tried it.
                                    #513959
                                    Ramon Wilson
                                      @ramonwilson3
                                      Hello Ian B,
                                      I have a 14 x 14ft wooden workshop that is insulated much as your own. It has a 14 x 8 ft extension on one side with access from the main workshop. Although there is an air gap below I did not insulate the floor – something I wish I had done. Originally I had two 3ft long tubular greenhouse heaters permanently on but these had no thermostat. These would be boosted by secondary heating used as and when. I accepted the cost as part of my hobby.
                                      I experienced no rusting on machine surfaces over this time but the odd piece of stock would sometimes acquire a slight patina.
                                      I replaced all with a seven fin oil filled 3Kilowatt radiator in each side set on the one kilowatt setting. The two or three Kw settings have never been used. Save for the very warmest months these are also on permanently but of course thermostatically controlled. My wife, who keeps a wary eye on such things – assured me that the extra cost of not having to reheat the workshop on each use was hardly noticeable so it has worked like that for years now.
                                      None of my equipment is covered other than when I am taking a break from machining – lathe has its original Myford cover and one mill a cover made from an old sheet. The other mill and all other tooling is left uncovered. It is a permanently warm place to walk into but ready for instant use without having to wait until things warm up. FWIW I have no rust issues whatsoever with this set up.
                                      I spend a lot of time in there so the cost, as said, is considered part of the hobby – we've just this last week had a smart meter fitted. Last night as we retired my wife remarked we were spending 4p per hour at that point – not bad she said for two 1Kw heaters and two fish tanks plus an outside pond pump as well as the lighting.
                                      Never ever having had to deal with condensation in the workshop I can't comment on de-humidifying but if you can prevent the temperature deviation in the first place (and do away with that paraffin heater) I'm you'd find you soon make a huge improvement given the insulation you have installed already.
                                      Regards – Ramon (Tug)
                                      #513961
                                      Ramon Wilson
                                        @ramonwilson3
                                        Hello Ian B,
