chipmaster gibbs adjusting
Home › Forums › Beginners questions › chipmaster gibbs adjusting
Viewing 23 posts - 1 through 23 (of 23 total)
  • #106775
    garrygun
      @garrygun
      Hi guys,at work i have access to a colchester chipmaster which has play in the cross&tool slide, i have tried adjusting both, but the cap heads screw into the gibbs making it unadjustable as the holes for the capheads are not elongated, am i looking at this wrong???? any help appreciated.
      Thanks Garry.
      #6485
      garrygun
        @garrygun
        #106784
        Nobby
          @nobby
          Hi
          The cap heads may be bottoming on the shoulder. . Or you could turn the heads down a. the c/bores dont need elongateing
          Nobby
          #106785
          KWIL
            @kwil
            Is the gib so worn that you need excessive movement beyond the "slop" in the cap head holes/counterbores when you tighten the grub screws?
            #106793
            garrygun
              @garrygun
              Posted by KWIL on 19/12/2012 23:13:30:
              Thanks for the replys, i think the gibs may be worn to excess, i thought there might have been elongated screw &caphead holes as there doesnt seem to be much adjustment at all, do you think it would be safe to open out the drillings? this machine is old & the company wont pay out for repairs so i would like to try and get most of the play ou,t mainly for my own use at work.
              #106794
              Billy Mills
                @billymills
                The Chipmaster pictures on lathes.co.uk have grub screws (not cap screws) for gib adjustment. How MUCH play ? has someone nicked the gibs and fitted long cap screws? If the gibs are there then you might be able to move them along as the grubs go into depressions in the gibs or fit longer screws. That would need a fantastic amount of wear to take BOTH gibs down that much- don't sound likely.
                Billy.
                Edited By Billy Mills on 20/12/2012 10:50:56
                #106795
                Nobby
                  @nobby
                  Hi Again
                  Why not use longer screws , so the heads dont bottom . or grub screws .A photo may help us see the problem better
                  Nobby
                  #106796
                  Nobby
                    @nobby
                    Billy's right use grub screws . He beat me by 1 second
                    Nobby
                    #106818
                    Peter Tucker
                      @petertucker86088
                      Hi Garry,
                      Have you taken the cap head screws out and looked in the scrw holes? Someone may have put the cap heads in to lock grub screws in position. Just a thought.
                      Peter.
                      #106819
                      Nobby
                        @nobby
                        Good thinking Peter
                        Nobby
                        #106822
                        garrygun
                          @garrygun
                          Hi guys,lokking at the cross feed gib it is held in position by capheads from the top and the gib is threaded to accept the caphead that locks it into position& the side grub adjusters have no locking screws on top of them, the tool slide has the capheads opposite way round the gib is counterbored and slide is threaded, my guess is ive run out of adjustment. any options i could take? trying to ad some piccys**LINK**
                          #106823
                          garrygun
                            @garrygun
                            Hope this one works.
                            #106824
                            KWIL
                              @kwil
                              Thanks Garrygun, that is what I suggested.yes
                              #106827
                              Nobby
                                @nobby
                                Hi Guys
                                A picture / photo is better than a hundred words .
                                Nobby
                                #106835
                                Ian S C
                                  @iansc
                                  Should the (grub) screws have nuts on them to lock them? I thought that was the normal method, I wonder if cap head screws were put in at some stage, so that a larger Allen key could be used. Ian S C
                                  #106845
                                  KWIL
                                    @kwil
                                    It is a common practice on some makes to use two grub screws per hole, one to lock the other Bit more of a fiddle to set up because the locking screw takes out the backlash of the first screw.
                                    #106847
                                    Les Jones 1
                                      @lesjones1
                                      Hi Ian,
                                      From the links to the pictures of the gib on Garry's lathe it looks like it is totally different to the normal gib strip which is about 4 mm thick. The gib on Garry's lathe is solid piece of metal which is held in place by cap screws. Once the grub screws have been used to adjust the gib and the cap screws tightened it does not matter if the grub screws move. I have not seen this arrangement before. As Nobby says "A picture / photo is better than a hundred words"
                                      Les.
                                      #106848
                                      KWIL
                                        @kwil
                                        Les, not seen this arrangement before? Look at a Myford Super 7
                                        #106851
                                        Nobby
                                          @nobby
                                          Hi Guys & Kwil
                                          On my super seven the cap screws are on top of x slide adjustment is on the side using 2ba grub screws . On the Exe lathe I am working on has square locking nuts as Ian mentioned. Drifting away from original thread sorry
                                          Nobby
                                          #106870
                                          KWIL
                                            @kwil
                                            yesyes
                                            #106877
                                            Billy Mills
                                              @billymills
                                              Take out the gib strips and epoxy shims on the worn sides. Blue the shims and the dovetails so that when re-fitted you can see where the wear is.
                                              Billy.
                                              #106904
                                              garrygun
                                                @garrygun
                                                Nobby & kwil
                                                i have now had this completely apart, it looks to me that the locking capheads have been replaced as they are very tight in the counterbores,this seems to be the problem,i will turn the capheads down a few thou hopefully this will give enough to tweak it slightly, as i said its very old machine and needs a lot of time and patience. will keep you posted on my progress.
                                                Thanks Garry.
                                                #106911
                                                Nobby
                                                  @nobby
                                                  Hi Guys
                                                  Somebody may have Put M6 ACS in a I/4 BSF C/ Bore Metric heads are much bigger . Yes M6 will screw into I/4 BSF
                                                  Nobby
