Chemical Sharpening Of Tools
Home › Forums › General Questions › Chemical Sharpening Of Tools
  • #173718
    Danny M2Z
      @dannym2z
      #23637
      Danny M2Z
        @dannym2z
        Why are fish-hooks so sharp?
        #173719
        Danny M2Z
          @dannym2z
          G'day. Christmas here in Australia is usually hot and humid. Plenty of thunderstorms about so I like to catch a few native fish (Golden Perch 'Yellowbelly' …)  near where I live as they thrive in the conditions and my neighbour loves them (in his fish-smoker).
          When I was casting a lure I got thinking about the sharpness of my Mustad and Gamakatsu chemically sharpened hooks.
          They are seriously sharp .. enough to pierce one's skin if dropped onto an exposed toe.
          So, as one does when waiting for a bite, I pondered about lathe cutting tools, hunting knives and sharpness in general.
          As I discovered many years ago whilst following one of Harold Hall's excellent books (Tool and Cutter Sharpening – Workshop Practice Series #38) – Sharp tools work!
          This led me to ponder about the possibility of chemical sharpening of lathe tools.
          Research led me to a few patents, mostly involving electro-chemical sharpening (fishhooks again), but some mentioned cutting tools for lathe and mill such as **LINK**
          and **LINK**
          Any thoughts from the forum.?
          * Danny M *
          Edited By Danny M2Z on 27/12/2014 07:38:36
          Edited By Danny M2Z on 27/12/2014 07:56:07
          #173726
          Les Jones 1
            @lesjones1
            Hi Danny,
            It has been discussed as a way of sharpening files here.
            Les.
            #173735
            Danny M2Z
              @dannym2z
              Thanks Les.
              I knew it was always lurkling in the back of my mind, something always drags me back to chemical sharpening as a viable technique but most people remain silent about the matter. Sorry that I raised the topic again.
              Moderators – please delete his thread
              * Danny M *
              #173748
                Why?
                Clive Foster
                  @clivefoster55965
                  Although this has been previously discussed and known to work under the right conditions the whole concept has always been considered something of a black art as none of the usual sources give any real details as to why and how things should work. At our level I suspect that most of the original sources are third or forth hand anyway and mostly of the "this recipe worked for me" type.
                  I found this statement from the second patent in the first link interesting:-
                  "Applicant discovered that with a certain composition of electrolyte bath, and if the electric potential was used at low levels, that even erosion would occur across the side surfaces of a cutting edge. No concentration of the erosion would occur at any given point. The net effect is that with a dull edge, which is where the sharpened edge has assumed a slightly rounded configuration, the side surfaces of the edge will be eroded away evenly substantially eliminating the rounded cutting edge and reproducing the initially established sharp edge. The initial geometry of the side surfaces of the cutting edges are maintained."
                  Which neatly summarises the whole problem. Left to its own devices erosion preferentially occurs at the sharp(er) points. Which is why chemical polishing works so well, the rough bits are sharper than the smooth ones and so get eroded first. The files dipped in acid version works because the shape of the teeth shields the back side and point so the flat erodes preferentially. Neither case applies to the general run of lathe and milling tools. Unfortunately sharp is not purely defined in geometrical terms. There are a also electro-chemical aspects so impurities, cracks or even stress can be "seen" as being electro-chemically sharp so erosion can occur in the middle of a flat surface. Think rust pitting and the various chemical methods to make material structures visible under a lab microscope.
                  Assuming a suitable composition of electrode bath is able to effectively alleviate such geometric effects the big question is how reliable is it over the normal range of material compositions. My guess is that proper operation would be pretty material specific needing, hopefully small, adjustments when the material composition varies outside a fairly narrow range. Makes the concept impractical unless you know exactly what the material is. Shame really as it would be so nice to just dunk your tools in the sharpener bath when you knock off for the night and come back to razor sharp cutters next day.
                  If it really did work reliably the toolmakers would surely have latched on to it as an effective way of locking in their customers by supplying a bath unit and electrolyte suitable for their special materials but no good for brand X, Y & Z. Naturally brands X, Y and Z would have their own specials to lock in their customers. In pre-carbide and pre-insert days sharpening HSS tooling was a major issue for larger companies who would have specialist departments with lots of skilled operatives and T&C grinders. Samller companies would rely on skilled men (& women) doing their own. Either way a just dunk it device would have been pretty attractive. Lots less messy too.
