Rotary Table
Rotary Table
Home Forums Workshop Tools and Tooling Rotary Table
  • #19556
    ChrisB
      @chrisb35596
      What make is it?
      #440889
      ChrisB
        @chrisb35596
        Hi, I have been after a 6" rotary table for quite a while, looking at ebay for a good deal on an HV6 or similar but all the time I was out bid.
        Finally I managed to win an auction on a 6" rotary table and tailstock which were in a new never used condition. The table had some surface rust which went away with some scotchbrite, the tailstock was still in its plastic packaging and storage grease.
        I disassembled the table and cleaned it from the grease and re-lubricated it. Looks fine to me.
        The table has got no markings on it, no manufacture's data plate etc, and it's shape is not like any I have seen, such as a Vertex or Soba. It does not not even look like it's a casting – more like a machined block of steel (do not take my word for that)
        My guess is it's a Chinese import – anyone knows what type of rotary table is this and if it's any good? I paid £200 for the table and tailstock, the price of a new HV6.
        #440892
        Clive Brown 1
          @clivebrown1
          Looks like those sold by ArcEuroTrade? A good buy.
          #440897
          Bill Davies 2
            @billdavies2
            Here is a 6 inch rotary table:
            ArcEuroTrade rotary table
            #440900
              In case you missed it the 0-360deg ring around the edge of the table also moves and can be set to zero but is a good fit which is why it looks like you did not remove it.
              As said above looks like the ones ARC sell which I think are made by Sieg or based on them.
              I've been using one for a while and they ar ea nice table.
              #440902
              ChrisB
                @chrisb35596
                Posted by JasonB on 09/12/2019 15:43:20:
                Yes missed that Jason, don't have it's instructions manual. I will give it some penetrating oil and free it up. I thought it was some sort of Bison clone, but looking at the link above to the ARC website it looks identical – would never have thought it was that expensive!
                Edited By ChrisB on 09/12/2019 15:53:54
                #440904
                Ron Laden
                  @ronladen17547
                  At £200 for the table and tailstock that is a very good buy, it certainly looks to be the ArcEuro one and I have only heard good things about it.
                  #440918
                  old mart
                    @oldmart
                    I notice that ARC sell the set of dividing plates to fit your table.
                    #440930
                      Posted by old mart on 09/12/2019 17:02:47:
                      But do check that they would fit – before ordering. Not all dividing plates are the same and, sensibly, all above have said ‘it looks like…’.
                      #440937
                      ChrisB
                        @chrisb35596
                        Posted by not done it yet on 09/12/2019 17:51:48:
                        Yes, I'm missing the dividing plates. The one on the ARC site has a 1:72 gear ratio so if I count the teeth on the worm gear and it's 72, then the dividing plates should fit right?
                        Alternatively I could fit a stepper motor to it, would be a nice project!
                        #440940
                          You need to check the hole in the middle of the plate and the screw mounting holes, I'll measure mine tomorrow for you and dig out the instructions that list what divisions are possible.
                          #440941
                          Alan Vos
                            @alanvos39612
                            I have the 4 inch version. That 0-360deg ring looks like it might move, but I have never managed to shift it. Is there a trick? Maybe the 4 inch does not have this.
                            #440944
                              I don’t think the number of turns per full revolution has much bearing on whether it will fit. 15 holes, or 47, holes just means that number of holes for a full revolution of the disc, nothing more. JB has the right dimensions to check. Any Indian or Chinese maker (or any other, for that matter) can choose the screw pitch circle and centre hole size.
                              #440946
                                Posted by Alan Vos on 09/12/2019 18:31:05:
                                loosen the small locking grub screw just to the side of "0" I found leaving the key in the screw made a good lever to turn the ring with. If you still have some of the very thick packing chicken fat on it that may need cleaning up first as it is rather sticky.
                                #440950
                                ChrisB
                                  @chrisb35596
                                  Jason, is the indexing dial ring on the handwheel stiff to turn on your table? It is quite stiff on mine, I took the handwheel apart and cleaned the ring and the small leaf spring, greased and assembled everything but it is still quite stiff. Must be the spring as without it the ring turns freely.
                                  #440952
                                    Probably a bit stiffer than the ones on the mills and definately more than the lathe ones which can be a bit too loose at times But at least there is no risk of it slipping or being turned by accident.
                                    #441093
                                      Sizes that you need to match if you are going to use an ARC dividing plate etc are.
                                      approx 38mm spigot for plate to fit onto.
                                      approx 10mm shaft for handle to fit onto
                                      Approx 54mm over the two M5 fixings = 49mm ctrs
                                      Edited By JasonB on 10/12/2019 19:24:10
                                      #441117
                                      Alan Vos
                                        @alanvos39612
                                        Posted by JasonB on 09/12/2019 18:49:37:
                                        Thanks. I had not considered using the grub screw as a lever. I will persevere.
                                        #441120
                                          Have you a chart giving the Turns and Holes for the various numbers of divisions with your Rotary Table?
                                          If the gear ratio is 72:1, then the chart should call for one turn of the handle for each of 72 divisions.
                                          If it is not 72:1, then whatever number of divisions that calls for one turn of the handle will be the gear ratio.
                                          As an example; a Vertex HV6, calls for 1 turn for 90 divisions, so has a 90:1 ratio.
                                          Otherwise, you will need to count how many turns of the handle are needed to rotate then table by a set number of degrees, such 90 degrees., and multiply by 4.
                                          22.5 turns for a quarter turn means 90:1. 18 turns would mean 72:1, and so on. To be absolutely certain, keep counting the turns until the Zero graduation returns to the datum point. Bit of a PITA, but necessary to find the ratio. The higher the ratio the greater then resolution.
                                          Mounting a set of division plates meant for a table with one ratio, onto one with a different ratio will mean that the chart supplied with the table will not apply, and a calculator or a spreadsheet will be needed, to arrive at the turns / holes for a given number of divisions. It can be done. When errors were evident in the Vertex HV6 chart, a spreadsheet brought to light other errors and omissions, so in the end it was time well spent.
                                          #441142
                                            Far simpler way than Howard's is to look how many degrees on the handwheel, you are likely to find it is 5deg
                                            360/5 =72 Simples.
                                            #441153
                                              Posted by ChrisB on 09/12/2019 14:43:35:
                                              Gear Ratio ?? … Mmm
                                              Counting the teeth is [would have been?] another easy option.
                                              angel MichaelG.
                                              #441271
                                              ChrisB
                                                @chrisb35596
                                                Posted by JasonB on 10/12/2019 19:23:43:
                                                Thanks for that Jason. Measured my table and the dimensions are the same as those in your photos – so most probably it's the same as yours from Arc
                                                #441303
                                                  Posted by ChrisB on 11/12/2019 19:41:42:
                                                  How ‘same’.smiley
                                                  It could have been supplied by Arc, but just as easily by some other supplier. So the quality may not be identical. But if it does what you require, no need to worry too much…
                                                  Remember, halving the tolerances likely doubles the price – the law of diminishing returns and all that.smiley
                                                  #441403
                                                  Alan Vos
                                                    @alanvos39612
                                                    I tried using a hex key to rotate the 0-360deg ring. It worked, just. I could only move the ring a small distance by hand. I was able to get it the whole way round by wedging the hex key on a clamp bolt (no clamp) and using the handwheel for some mechanical advantage.
                                                    If anybody knows a way to get some lubrication in there without talking the table apart, please advise. Other than this ring, it works very nicely out of the box. I am reluctant to risk disturbing that.
                                                    #441409
                                                    KEITH BEAUMONT
                                                      @keithbeaumont45476
                                                      You can download a guide for this rotary table from the Arc site
                                                      Keith
