Colchester Triumph 2000 but you must find a good one. Great help to identify where its spent most of its life.
For many years new price and capabilities was attractive enough to sell into manual lathe production shops, training schools, tool rooms, experimental /prototype and maintenance shops. The production ones will be all used up as being well worth destroying for the value of what they made. Toolroom ones will have been worked well but looked after, maintenance shop ones will usually have considerably lower hours but may have been abused. Training school ones probably lowest hours but almost certainly had oopsies. Experimental / prototype shop cast off are the ones to go for, relatively low hours and looked after. Colchesters are not, in practice, economically re-buildable / re-furbishable and generally repairs will only be squeezing out a bit more life from a machine well past its prime. Although not exactly in "wonderful one horse shay, that ran for a hundred years and a day" territory once one important part is worn out most of the rest isn't far behind. Fixing serious neglect or abuse, intentional or accident, being a different matter of course.
You have to think like a businessman with machines of this ilk. Will it do the job? How much capability for how much money for how long? Hobby guy, get it cheap and fix it up as I go thinking, may work for your Myford, Boxford, Drummond, SounthBend and Super Adepts but you will be in a world of hurt and serious trouble with the domestic authorities if you try that with a Triumph 2000. Can do very well by carefully purchasing one with a known fault if the price is right but … you gotta be sure.
A good test for heavily used and / or unskilled finger-pokened machines is the run up time. Manual gives specifications for time to run up to speed with a chuck on. Any serious deviation means either worn or maladjusted clutch. Even if a lathe has clearly been well used a properly adjusted clutch suggests its been looked after. Adjustment isn't especially hard to do but has to be done by the book so if its wrong you have to wonder what else is lurking.
Check carefully if its obviously been used with coolant. Aprons do collect it and should be drained periodically when used wet. Quite possible to find one that has been run with an apron full of suds for years and still sort of working!
Clive.
