Not just one mystery item, but HUNDREDS!
Home › Forums › Help and Assistance! (Offered or Wanted) › Not just one mystery item, but HUNDREDS!
Viewing 25 posts - 1 through 25 (of 25 total)
  • #818356
    Martin King 2
      @martinking2
      Hi All,
      Just got back from an auction with this weeks haul, one of those times when you have to take loads of junk in order to get the things you want.
      Started sorting through one lot with some nice stuff then came across these, scattered all over the place! Obviously very well made parts for something or other but why do they all have different numbers?
      In the same lot were boxes of Hoffman ball bearings so that may be a clue? Any help or ideas will be, as usual, most welcome! Cheers, Martin
      brassbits 2brassbits 1
      #818359
      DC31k
        @dc31k
        Perhaps that is the serial number for the finished item.
        Clutching at straws, there is a possibility that the 74 prefix is the year (making 74,000 of something seems less probable somehow).
        #818360
        Diogenes
          @diogenes
          ..it’s been a long time, and the memory could be tricksy, but ‘petrol pump’ springs immediately to mind – I mean the retail forecourt kind..
          #818362
          not done it yet
            @notdoneityet
            Go/no-go guages
            #818377
              I guess gauges too.  What’s the hole diameter?   Be nice if it was about 0.74″!
              A possible bearing connection is that it’s important that the balls in each individual bearing all be the same size.  The race is less critical.  Expensive bearings contain closely matched balls, so maybe these are selecting gauges.  Used to sort a large batch of balls of nominal size 0.7467″ into near match groups before assembly.
              My worry is that tenths of a tenth is unrealistically precise.  Many practical difficulties making and using them.
              If they are tenths of tenths differences, then compare 75583 with 74758, hopefully finding an 8 thou difference between the extremes.
              Another possibility is they are individually numbered gauges, each issued with it’s own calibration chart.
              Peter Cook 6
                @petercook6
                In Martin’s second photo, comparing the clearance between the edge of the main hole and the edges of the countersunk holes does suggest differing main hole sizes. Would be interesting to know what the numbers were on those two.
                #818386
                Clive Brown 1
                  @clivebrown1
                  Strange to make such finely graduated gauges from what looks like yellow metal. Also the closeness of countersunk holes to the measuring faces doesn’t suggest ultra precision.
                  #818389
                  Chris Gunn
                    @chrisgunn36534
                    Weigh them in!!
                    CG
                    #818399
                    Charles Lamont
                      @charleslamont71117
                      Are they brass, phosphated or anodised (or something else)?
                      Part of a lock – hence key numbers?
                      #818406
                      cogdobbler
                        @cogdobbler
                        Could be aircraft parts, numbered for purposes of source of origin?
                        As the numbers are sequential, unlikely to relate to size etc.
                        #818407
                        peter1972
                          @peter1972
                          I agree with DC31k: they are a part of a production item that includes the serial number. I guess they were left over after the end of a production run.
                          They are certainly not gauges in my view!
                          #818415
                          howardb
                            @howardb
                            “..it’s been a long time, and the memory could be tricksy, but ‘petrol pump’ springs immediately to mind – I mean the retail forecourt kind..”
                            and
                            “Strange to make such finely graduated gauges from what looks like yellow metal”
                            Tools/gauges for use in the vicinity of petrol or petrol fumes are made of brass/bronze – it’s non sparking.
                            Maybe a connection there.
                            #818416
                            Nigel Graham 2
                              @nigelgraham2
                              The bearings and these brass thingummyjigs may be related only as being components in the same finished product. Whatever that was.
                              Seems a bit odd serial numbering these, even if the number is of the complete machine. I’d have thought a small partt like this would more likely bear a part-number, perhaps comprising some reference to the entire entity, but the same number on every one of them. The numbers look machine-stamped or engraved, too.
                              “Made in England” stamped on each. (We need more of that!) I wonder why? It suggests these brass plates were visible to the user, part of an outer casing perhaps, not just to the assembly staff.
                              #818441
                              not done it yet
                                @notdoneityet
                                Absolute precision is not required, so much as the differences, for matching sizes for high-precision bearings.
                                #818448
                                Diogenes
                                  @diogenes
                                  ..a unique identifier is desirable on any metering equipment requiring calibration/certification isn’t it?
                                  ..and likely ‘essential’ on one subject to scrutiny by revenue authorities..?
                                  #818460
                                  Bo’sun
                                    @bosun58570
                                    Very unlikely I think to be any sort of gauge, because why all the holes?  The csk holes certainly suggest they would be secured to something.  As already alluded to, the serial numbers suggest a component that requires traceability.  Possibly military, aerospace or nuclear, etc.
                                    #818470
                                    Martin King 2
                                      @martinking2
                                      Wow! There’s food for thought!
                                      They are made of brass; I do not have anything to measure the diameter of the holes to anything like that sort of precision, although funnily enough in another lot is a complete set of really nice MERCER internal hole micrometers with standards, but nothing that small.
                                      The time and trouble to engrave each of these plus Made in England speaks to something of quality I think.
                                      Pretty sure these will go in the brass scrap bin, what a shame!
                                      Thanks to all for the input, much appreciated as always.
                                      Cheers, Martin
                                      #818473
                                        Also if the item is worth stealing!  Serial numbers are for traceability, though this series could be measurements.
                                        They look ordinary, but probably aren’t.  I suspect gauge in the widest sense, perhaps fitted inside a dispensing machine: chemicals, food-processing, pharmaceuticals, fuel management, x-rays, or something taxable like a petrol pump (see Howard’s post).  Not a production or workshop gauge.
                                        Corrosion resistance might mean an expensive alloy, return to store!  Or nuclear : radioactive after use requiring special disposal.
                                        Clues:
                                        • Came jumbled with Hoffman ball-bearings in an auction lot.  Coincidence?
                                        • I guess the big hole is the important feature.
                                        • The 3 counter-sunk holes suggest the item was screwed to a plate.
                                        • The 4 small threaded holes suggest a cover
                                        • The 2 larger threaded holes suggest a gizmo fixed inside the cover.  Thermostat, switch, or sensor maybe.
                                        • It’s special : individual numbering is expensive, rarely applied to off-the-shelf parts, and there’s no Part Number, so these were obvious to the owner or supplied in a kit.
                                        • “Made in England” means it was exported.  (Country of origin markings are rarely flag waving guarantees of quality. They’re required when an export destination applies import controls to boost their local industry.)
                                        • The finish suggests corrosion resistance.
                                        Ches Green UK
                                          @chesgreenuk
                                          I found a look-alike on eBay….  https://www.ebay.co.uk/itm/295618385626   The description doesn’t give much away.
                                          Similar items in this ‘image lookup’ result …. https://www.google.com/search?vsrid=CKuAib_V2e358AEQAhgBIiRhY2MzZTMzNS04NWVmLTQ1ZmQtYjRiYS02M2Y2MDZjNWE2ZTQyBiICd2UoEzia_ZKK5oeQAw&vsint=CAIqDAoCCAcSAggKGAEgATojChYNAAAAPxUAAAA_HQAAgD8lAACAPzABEJ8GGO0FJQAAgD8&udm=26&lns_mode=un&source=lns.web.gisbubu&vsdim=799,749&gsessionid=iR0erd9KLg_gxjgE0n6sFw9QhmZdhyJL5UwgQWmS5crNrDIX-mhgVQ&lsessionid=GMjT88VoZaVVZE48Por7Fqx9BJvIDh3yNF59f9Duxh5SrsK45BOqSw&lns_surface=26&lns_vfs=e&qsubts=1759486522314&biw=1600&bih=850&hl=en-GB&sei=PKLfaOWjGvzZ7M8Ps_u24A8
                                          I haven’t sifted through these yet. Might be something in there?
                                          Ches
                                          Edit. Martin, I take it there isn’t a tapped hole on the bottom straight face of those parts? Ah, I see from your first image there likely is not.
                                          #819093
                                          old mart
                                            @oldmart
                                            Are they brass or titanium nitride coated? The size varies by only 0.00001″, I think they are gauges for ball bearings. Try a file to one if you think they are brass.
                                            #819230
                                            Speedy Builder5
                                              @speedybuilder5
                                              #819231
                                              Speedy Builder5
                                                @speedybuilder5
                                                Also these serial numbered plates appear in the other ebay link but with what looks like a bush in the larger round hole, an adjusting screw on its edge and elongated smaller holes.
                                                bob
                                                #819239
                                                Clive Brown 1
                                                  @clivebrown1
                                                  The discussion has progressed since my earlier post, but the reason that I drew attention to the countersunk holes was that the mere act of tightening countersunk fasteners in such close proximity to a sub-micron gauge surface would be likely to distort the measurement. Not good practice in my view.
                                                  #819240
                                                    […] but the reason that I drew attention to the countersunk holes was that the mere act of tightening countersunk fasteners in such close proximity to a sub-micron gauge surface would be likely to distort the measurement. Not good practice in my view.
                                                    Dare one ask ?
                                                    Has Martin actually measured the bores … or is it just a working assumption regarding the numbering ?
                                                    Robert Atkinson 2
                                                      @robertatkinson2
                                                      The ebay items by seller Apex engineering are parts from a linear slide unit. Specifically the end blocks supporting the lead/ball screw or guide rod and the one similar to the OP’s is the support for the travelling nut.
                                                      But the OP’s could be anything. Brass does suggest an instrument of some sort though anodised aluminium is more comm these days. possibly a mount for a optical coponent with an integral flange.
                                                      Robert.
