Another “What is it”
Home Forums Workshop Tools and Tooling Another “What is it”
  • #19557
    Manofkent
      @manofkent
      #441203
      Manofkent
        @manofkent
        Hello all.
        I recently agreed to help a friend clear his workshop.
        I have come across an odd measuring tool.
        It is made by Sigma and says "based on NPL design" and is obviously a measuring tool. When the end is gently pressed a needle marker moves in the window.
        It may have been inserted into a sort of enormous micrometer fitting I have also found.
        Picture here or if that fails on the next post!
        Any ideas
        #441204
        Manofkent
          @manofkent
          #441211
            It’s exactly what you’ve assumed … a precision indicator for the enormous micrometer.
            ‘ere we go :
            https://collection.sciencemuseumgroup.org.uk/objects/co59510/0-2-bench-micrometer-micrometer
            Edited By Michael Gilligan on 11/12/2019 13:44:36
            #441220
            JohnF
              @johnf59703
              Michael is spot on they and similar devices are or were used on many, mainly inspection grade tools and indeed precision machines, one of the Newall jig borer's I worked on used them in conjunction with a micrometer head and their roller measuring system
              Manofkent
                @manofkent
                Thanks Michael & John. The link showed exactly the enormous micrometer.
                Would this be intended to ensure a consistent pressure when measuring?
                John MC
                  @johnmc39344
                  it's a fiducial indicator, used to ensure consistent readings with, most likely, micrometers used for inspection.
                  Oily Rag
                    @oilyrag
                    NPL refers to the National Physics Laboratory – the go to place for anything to do with measuring, based I seem to remember around Glasgow. Sigma was based in Letchworth and were a well respected instrument maker.
                    Edited By Oily Rag on 11/12/2019 15:16:34
                    #441231
                    Ex contributor
                      @mgnbuk
                      NPL is in Teddington. The National Engineering Laboratory was / is based at East Kilbride outside Glasgow.
                      Nigel B
                      #441233
                      alan ord 2
                        @alanord2
                        It's a fiducial indicator as explained by John. It is used with micrometers in place of an anvil to ensure a consistent reading. The mic is turned / closed until the needle reads zero and as the pressure used is always the same it does not matter who operates the device you will always get a consistent reading.
                        Alan.
                        #441239
                        Paul Rhodes
                          @paulrhodes20292
                          My first posting is to comment on the number of smart cookies posting here. I will have to hang about the shadows to keep my ignorance hidden.
                          #441244
                            This may be of interest: **LINK**
                            http://resource.npl.co.uk/docs/science_technology/dimensional/moy-scmi/moy-scmi-82-print.pdf
                            A ‘variation on the theme’ but it gives us a sense of the standards to which the NPL operates.
                            Edit: This is the one I was looking for:
                            http://resource.npl.co.uk/docs/science_technology/dimensional/moy-scmi/moy-scmi-29-print.pdf
                            Edited By Michael Gilligan on 11/12/2019 16:38:18
