Dickson Toolpost – Tool Holder Rack
Home Forums Workshop Tools and Tooling Dickson Toolpost – Tool Holder Rack
  • #18347
    Steve Addy
      @steveaddy35670
      Has anyone made a tool holder storage rack?
      #275707
      Steve Addy
        @steveaddy35670
        Hi everyone.
        I have just treated my lathe to a New Year clean and was thus moving and cleaning Dickson tool holders. I really have too many for them to be kicking about in the swarf tray and it set me wondering if there was an existing design for a storage rack.
        An Internet search has only found aluminium ones for the dovetail type beloved of the Americans.
        I was thinking of a few laser cut blades to slot them on. Stainless would be nice as it would remove the need for paint which would scrape off in use anyway.
        Steve
        #275716
        Peter Spink
          @peterspink21088
          I seem to remember Model Engineers Laser did a kit but it's not on their website. I would like one too.
          Peter
          #275721
          Jez
            @jez
            Hi Steve,
            I've made two, both to the same basic design – a flat bar with a series of pins let into the bar perpendicular to it, one at each end of the tee slot in the back of the toolholder, if that makes sense.
            The first I made of wood and used dowel glued in (for T2 size holders), the second I made from steel with 6mm rod "puddle" welded from the back side (for S1 size holders).
            HTH!
            Jez.
            #275722
            mechman48
              @mechman48
              I have used clip in shelf brackets screwed to the back shelving…
              ​George.
              #275729
              Steve Addy
                @steveaddy35670
                Thanks guys. That was quick.
                I know Malcolm of ME Laser, so I could ask him.
                The two pins make sense and I was thinking of mounting them upright as they are used. Now I'll have to have a look to see if they are better as in George's pictures as I hadn't thought of that. Should be better for storing ones with large boring tools
                I have a serious shortage of feline swinging room!
                Steve
                #275734
                Nick Wheeler
                  @nickwheeler
                  Mine is made from ten pieces of 25x1mm steel strap 70mm long with a roughly 30degree bend in them. These are welded to a length of 25x3mm steel left over from a previous project, and the whole thing is screwed to the cupboard wall next to the lathe.
                  and
                  That's about 30minutes work, which includes the 'design', and about a fiver in materials.
                  #275740
                  Gray62
                    @gray62
                    If you have access to the magazine archive, there is a photo in MEW84 of Barry Jordans Carousel tool holder and in MEW 183 there is an article on construction of a similar design as shown below:
                    #275778
                    Steve Addy
                      @steveaddy35670
                      Thanks folks, Some food for thought there.
                      #276366
                      Nigel Bennett
                        @nigelbennett69913
                        I screwed two No.8 round-head wood screws into a board; these are spaced and stick out so that a toolholder will slide over them and the Tee section will slip under the heads and be retained by them. A short length of thin hardwood is screwed beneath the round-head screws to act as a stop for the toolholder. Pretty inexpensive – four screws and a short piece of wood per holder.
                        I made up a jig – two "tapping size" holes accurately spaced in a piece of steel bar – to ensure repeatability of drilling for the RH screws.
                        #282495
                        Antony Price
                          @antonyprice56876
                          It has been a busy month, so I’m only just catching up with the Forum!
                          I can’t take credit for the idea. I stumbled across it on Pinterest.
                          The aluminium angle was an off-cut from when I relocated the leisure batteries in the mobile home.
                          The DIN rail was left over from when I rewired the milling machine. The screw slots in the DIN rail, made putting it all together very easy, and the design can be scaled
                          I did make a Lantern Chuck to size the screws, but that has already proved useful for other projects
                          #283642
                          thaiguzzi
                            @thaiguzzi
                            Edited By thaiguzzi on 11/02/2017 14:04:15
                            #283645
                            thaiguzzi
                              @thaiguzzi
                              Perspex shelf.
                              #283711
                              Gordon A
                                @gordona
                                Offcut of mdf architrave, (top half slopes back at about 10 degrees) + offcuts of 1" (25mm) aluminium angle cut to length to fit slot of toolholder.
                                Dickson Toolpost - Tool Holder Rack
                                #283714
                                Steve Addy
                                  @steveaddy35670
                                  Thanks for all the replies, not made anything for a couple of weeks, lathe still clean. I'm down with the lurgy!
                                  Steve
                                  #284965
                                  thaiguzzi
                                    @thaiguzzi
                                    Posted by Gordon A on 11/02/2017 21:02:48:
                                    I like the cutting fluid bottle rack. Neat idea.
