Unusual Thread
Unusual Thread
  • #275789
    Tom Gullan
      @tomgullan59234
      Hello,
      I have been asked by a friend if I could cut a thread on my Myford Super 7. The diameter is 24.7 x 1.693 pitch. This job is for a nut for a collet on a Schaublin lathe.
      If this is not possible, I would appreciate any information on how to go about this task.
      My Super 7 is imperial but I do have a full set of metric gears.
      Tom
      #32868
      Tom Gullan
        @tomgullan59234
        #275797
        JohnF
          @johnf59703
          I would check your measurements looks more like 5/8 x 43 tpi ? How did you measure it ?  It also could be 25 x 1,7 its not very likely to be obscure dimensions.
          Edited By JohnF on 04/01/2017 22:28:46
          #275799
          Roderick Jenkins
            @roderickjenkins93242
            Tom,
            1.693mm pitch looks to be 15 tpi. Not a thread much used and not in the Myford thread tables but we should be able to find a combination of gears to get you close enough.
            HTH,
            Rod
            #275800
              Have a look here, Tom **LINK**
              http://www.practicalmachinist.com/vb/schaublin-cazeneuve-weiler-graziano-mori-seiki-lathes/beauty-schaublin-w20-collets-321515/
              … It seems to confirm my suspicion that the thread is actually 15 tpi
              … see post #7
              P.S. … I presume you are aware that it's a buttress thread-form
              Edited By Michael Gilligan on 04/01/2017 22:49:01
              #275802
              Tom Gullan
                @tomgullan59234
                John,
                The sizes come from the collet Chuck manual page 11
                Tom
                #275805
                Mark C
                  @markc
                  Rod, Michael, I did the check as well (having just finished watching the news) and got to 15 tpi as well (25.4/15=1.6933) which makes sense from a design point of view – we do like round numbers!
                  Mark
                  #275808
                  Tom Gullan
                    @tomgullan59234
                    Gentlemen,
                    Thank you very much for your quick response to my question. Is it possible to cut this thread on my Super 7?
                    Tom
                    #275812
                      Posted by Mark C on 04/01/2017 22:53:37:
                      Mark
                      … and on the W20 collets [which I have] the pitch is 1.666mm
                      Nice; introducing thirds into a 'metric' system dont know
                      John Stevenson 1
                        @johnstevenson1
                        Change the 24 tooth driver to a 32 and select 20 tpi on the box.
                        Which works out to 15 tpi or 1.69 mm
                        Edited By John Stevenson on 04/01/2017 23:40:42
                        #275816
                        Roderick Jenkins
                          If you don't have a Norton box, there are loads of options. A couple of likely looking ones:
                          Drivers 20 21 60 Driven 30 35 45
                          or
                          Drivers 20 40 63 Driven 35 45 60
                          Rod
                          #275819
                          John Stevenson 1
                            @johnstevenson1
                            Or with no gearbox and just two gears, 40 driving 75 are two standard gears.
                            We don't need no skeenking compounds. wink
                            Rod, You realise we have beaten all the armchair warriors working to microns ?
                            wink  wink
                            Edited By John Stevenson on 05/01/2017 00:11:03
                            #275822
                            Roderick Jenkins
                              I won't have any idlers in my workshop, every gear has to work. wink
                              Rod
                              #275889
                                Posted by John Stevenson on 05/01/2017 00:08:00:
                                ….Rod, You realise we have beaten all the armchair warriors
                                John,
                                Are we to understand that you dictated that ^^^ from your Treadmill [which powers the LED lighting that supercedes the 'midnight oil'] whilst using the Welder in one hand & the Angle Grinder in t'other question
                                  Posted by Roderick Jenkins on 05/01/2017 00:37:19:
                                  Rod
                                  Get your coat!
                                  JohnF
                                    @johnf59703
                                    Posted by JohnF on 04/01/2017 22:26:39:
                                    Oh dear don't know where those numbers came from !!!! past my bedtime so apologies !!!!indecision
