Should also read "Don't push your luck!"
I thought of putting this in the "Hints and Tips" thread too.
Anyway, as some of you know I haven't been having much luck lately, well I have – but it has all been bad!
After the toothache fiasco (I will put that down to typical "Bloke" behaviour) then my dog ate the picture frame and a few other disasters I thought I was out of the woods.
Except yesterday the linisher bit me and removed the top of the fingernail from my Index Finger. Do you have any idea how difficult it is to shoot a competition with a Mr Bump plaster on your index pinkie? Well it isn't easy. So today passed – by and large – without incident and I thought I would do a bit of catching up. I am well behind with a few things. One of the first things I did this morning was set the Donkey (Saw to everyone else) to cutting some disks of Titanium. I needed four disks sawn 12mm thick from a piece of 40mm bar stock. Anyone who has done this knows it is going to take a while. Took up most of the day to be honest.
So anyway, I started to turn them up to the correct thickness, the first one passed without incident but setting the second one up in the chuck I (clumsy Oaf) clipped the chuck with the insert and chipped it. As it was only a small chip(?) I decided it would do for the next cut.
There are certain things you learn when working with Titanium and one of those things is to keep all the trays clear of Swarf. DO NOT allow it to accumulate. Why? Because if (when) you have the swarf light up because you are using too much pressure on a cut that is too big for the chipped tool you are hell bent on getting your full value from, you won't destroy the machine. It is just not possible to put a Titanium burn out with any sort of home extinguisher. I know of one person lost a Bridgeport
This is the bit that lit up coming off the tool, it was definitely one of those "Full Pucker" moments:
And this is the swarf I had just cleared from the tray:
It could have ended in tears. Instead I decided to turn the lights off and go make some tea. Far less risk.
graham.
