New lathe next week
New lathe next week
Home › Forums › Workshop Tools and Tooling › New lathe next week
  • #435550
    Nick M0NPH
      @nickm0nph
      Good evening all
      Having bought a new Chester DB10 at the show its being delivered next Tuesday and having the week off work to play !!
      My question is never having had a DRO on a machine could you all give me some advice as to whether i should get one or not are they worth having i am thinking that they are at least easy to reed
      some advice please
      Nick
      #19508
      Nick M0NPH
        @nickm0nph
        #435551
        Andrew Evans
          @andrewevans67134
          Get one
          #435552
            I can think of a lot of things you will need for the lathe before a DRO, if it were a mill I would be more tempted to fit a DRO sooner rather than later but not such a need on a lathe.
            #435555
            Stuart Bridger
              @stuartbridger82290
              I agree, I wouldn't be without a DRO on the mill, but quite happy without on the lathe. I can see the benefits, but not top of the list.
              #435556
              Oldiron
                @oldiron
                Congrats on the new lathe.
                A DRO is nice but not really as essential as it is on a mill. I would spend the money on some really good tools before a DRO. ie Collet holder + collets, a decent tool holder & tooling, dial test indicator, the list goes on & on.
                regards
                #435560
                not done it yet
                  @notdoneityet
                  ‘Many a slip twixt cup and lip’.
                  Personally, I would not have booked off the play time until it had been delivered (and installed). Good luck and I hope Chester see this post.smiley
                  #435564
                  old mart
                    @oldmart
                    DRO,s are nice on a lathe, but not vital, I would spend the money on tooling. On a mill, not having a DRO is a great disadvantage.
                    #435586
                    Ron Laden
                      @ronladen17547
                      Best thing I ever did was fit the mill with DRO,s but I dont feel the need to do the same with the lathe.
                      #435589
                      Ian Skeldon 2
                        @ianskeldon2
                        I hope you enjoy playing with your new DB10, I have had one for a few years now and although it has done little work it does cut accurately (now) without a DRO.
                        There is some backlash in carriage and cross slide but not enough to cause any concern. I would suggest that you spend a bit of time making sure that it cuts absolutely parallel as it took me a couple of days to eliminate a very small taper, I also had to shim the compound slide as it was running downhill. All niggles that I put right and was then satisfied with the machines accuracy.
                        #435603
                        Hollowpoint
                          @hollowpoint
                          Oh dear, I wouldn't have booked time off work if I was you. Chester don't keep their promises when it comes to delivery.
                          Anyway on a lighter note, I couldnt image using my mill without a DRO now. They are one of those items that after using you wonder how you ever did without.
                          #435622
                          David George 1
                            @davidgeorge1
                            I have had no problem with delivery from Chester. Both the Mill and the band saw ordered at different times 18 months apart, came when they said they would. In fact the mill came at about 8.00 am when I wasn't expecting it till a little later. In fact i mentioned that the motor was running hot on the band saw at the midlands show and he said ring support on Monday which I did and on Tuesday arrived a new motor. Any way as for a DRO on your lathe if you can afford it get one but if it means you scrimp on tooling and toolholding get that first I havn't got a DRO on my lathe at home evan after having one on the one I used when I was I gainful employment.
                            David
                            Edited By David George 1 on 02/11/2019 08:08:14
                            #435623
                            Gray62
                              @gray62
                              I put a DRO on both my lathes several years ago and wouldn't be without, although I do have a problem reading the handwheel dials due a vision problem so the big numbers on a DRO head are an absolute necessity for accurate work. If they are within budget and justifiable, then get one.
                              Gray
                              #435795
                              mechman48
                                @mechman48
                                If you have the means for a lathe set up then get one; but as said in other posts not a necessity on the lathe, on the mill 'a super yes'. I use a couple of digital tyre gauges on my WM250V-F for saddle & X feed travel plus the tailstock travel, all using neodymium magnets to secure to machine.
                                George.
                                #436047
                                Howard Lewis
                                  @howardlewis46836
                                  Climbing aboard my hobby horse, when you have the lathe in place, adjust the level from front to back at Headstock and tailstock ends to eliminate any twist in the bed.
                                  Either use a sensitive level, or use the Myford method, (spelled out in Pages 27 and 28 of The Amateurs Workshop by Ian BrdleyL and similar books ) If the bed is twisted, long work is likely to be tapered.
                                  Time spent in positioning and setting up the lathe will be amply repaid in the future.
                                  ENJOY!
                                  #436151
                                  Nick M0NPH
                                    @nickm0nph
                                    Well as promised my new lathe arrived today will get it set up tomorrow and put up some photos
                                    so far could not have had any better service from Chester machine tools top marks
                                    Nick
                                    Edited By Nick Holden 1 on 05/11/2019 20:14:31
                                    #436154
                                    martin perman 1
                                      @martinperman1
                                      Well done that man, no more rugby to distract you, shame we lost, all you need now is something to make or repair like a Stationary engine.
                                      Martin P
                                      #436156
                                      Nick M0NPH
                                        @nickm0nph
                                        Yes Martin your right about the rugby
                                        and i have a few things to make for my radio antenna mast like a rotator and a few other things to keep me going through the winter just until i pluck up courage to get myself an engine from the engineers emporium !!
                                        Nick
                                        #436159
                                        martin perman 1
                                          @martinperman1
                                          Nick,
                                          I will PM my email to you for the odd chat.
                                          Martin P
