Inverter problem
Inverter problem
Viewing 25 posts - 1 through 25 (of 29 total)
  • #294234
    Rod Ashton
      @rodashton53132
      Could anyone advise please on the inverter/motor setup I just fitted to my Myford S7. All is working perfectly well but the inverter (ABB ACS300) cuts out on load. I can skim and face no problem. But it cuts out under load when drilling holes 5mm+. The motor is an ABB 0.55 kw,50hz,220/240D. I have set MAX FREQ to 50hz and MAX VOLTS to 230. Could it be that I need to set MAX VOLTS to 440 to match the output.
      Any thoughts on where to go, much appreciated.
      #32953
      Rod Ashton
        @rodashton53132
        #294243
        Andy Holdaway
          @andyholdaway
          Rod, Have you put in all of the motor parameters from the motor plate into the inverter?
          Also, Max Volts should be set to the motor voltage i.e. 230v.
          Is the motor connected in Delta?
          I'm not over familiar with ABB drives, but there will also be a parameter for setting torque boost. This may need setting to suit.
          The first thing to do is check that the motor is wired correctly, and that you have the correct motor parameters in the drive. You can then look at tweaking parameters to improve what you've got.
          Andy
          #294245
          Mike Crossfield
            @mikecrossfield92481
            Something very obvious, but I'll mention it anyway. Which version acs300 do you have? Is it rated for a 550W motor?
            #294261
            Rod Ashton
              @rodashton53132
              Richard – I have put in 230 as MAX VOLTS. It is connected in Delta. Looking through parameters now but not finding any torque references. – Mike ACS300 is rated 0.55 to11 kw. It was wired by a qualified sparky, but he has no practical inverter experience. – Bit baffled?
              #294263
              martin perman 1
                @martinperman1
                Rod, the inverter maybe rated .55 to 11kw but have you told it what motor it’s driving, where i work we use Siemens units driving submersible pumps and occasionally we change a pump to a slightly higher rated unit and if we don’t change the parameters they soon shut down.
                Martin P
                #294264
                John Rudd
                  @johnrudd16576
                  Rod,
                  What is parameter code 205 set to?
                  This is the current limit function setting, the default is 1.5.
                  Have you input the motor parameters as suggested previously?
                  Any error codes displayed?
                  Edited By John Rudd on 20/04/2017 16:45:27
                  #294267
                  Mike Crossfield
                    Rod
                    "ACS300" covers a family of different inverters covering .375 to 11kW. There is no single unit covering this range. What is the full ACS code number on the plate on the unit you have? You might only have the 1/2 hp version.
                    #294268
                    Rod Ashton
                      @rodashton53132
                      Sorry Andrew (not Richard)
                      I found a parameter called IR COMP which allows extra torque at speeds between 0.1hz and the nominal motor speed. Was set to off. So took the "automatic" option. This had no effect, inverter still stalled/cutout.
                      #294275
                      Rod Ashton
                        @rodashton53132
                        Mike – Unit plate gives :- ACS311-Ip6-1 – INPUT 208-240V 8.9A 48/63HZ – OUTPUT O-U1in – 4.3A – 0/500HZ.
                        #294276
                        Rod Ashton
                          @rodashton53132
                          Mike – The unit is capable of 0.75Kw and my motor is 0.55Kw.
                          #294278
                          Rod Ashton
                            @rodashton53132
                            John – Parameter 205 I LIMIT is currentlyset at 6.5A. Manual says 0.5-1.5 x Ln. Rated output current Ln is 4.3A. So I presume that 1.5 x 4.3 = 6.45 makes that correct?
                            #294279
                            Rod Ashton
                              @rodashton53132
                              John – Sorry, no error codes displayed. Unit just shuts down with a quiet click!
                              #294281
                              John Rudd
                                @johnrudd16576
                                Posted by Rod Ashton on 20/04/2017 18:47:48:
                                Ok,
                                What about parameter 222? This is for thermal protection for the motor and is current related……….
                                #294295
                                  Posted by Rod Ashton on 20/04/2017 18:54:21:
                                  Isn't that what happens when the power input browns out?
                                  If the lathe is on the end of a long cable or an extension lead, the line voltage may be dipping enough to trip the Inverter when a cut is taken.
                                  daveb
                                    @daveb17630
                                    If it only happens when you are drilling it may be worth checking the front bearing adjustment, if the thrust bearings are not correctly adjusted the spindle could be locking when the drill pushes it back. Some inverters have a fault log,may be worth viewing. Some inverters can display the current drawn whilst the motor is running, if the current increases beyond the motor max current when you are drilling, suspect front bearing as above. Dave
                                    #294325
                                    Rod Ashton
                                      @rodashton53132
                                      John – Parameter 222 was at 4.5A, so increased to 6.4 (max.) No change.
                                      Dave – I do have quite a long mains connection. Need to move the lathe nearer to the mains box. This was in the todo box but will expedite that today. Thanks!
                                      Daveb – Front bearing "seem`s" OK but will get the meter on it later today for load test.
                                      Very much appreciate the help and advice you guys are giving me.
                                      #294344
                                      John Rudd
                                        @johnrudd16576
                                        Posted by SillyOldDuffer on 20/04/2017 20:20:43:
                                        I would have expected the inverter to log a fault if an undervolts condition is detected…..but who knows?
                                        Rod, is the inverter new or secondhand? ( my gut is telling me its a discontinued model..) if its second hand, did it work fine for the previous owner?
                                        What about measuring the motor phase current, got a clamp on ammeter handy?
                                        #294348
                                        David Jupp
                                          @davidjupp51506
                                          I'd maybe check parameter 219 – make sure it is set to anything other than Square (used for centrifugal pumps etc.).
                                          Chapter 8 of the manual covers fault finding, including accessing the fault memory.
                                          #294355
                                            Posted by John Rudd on 21/04/2017 10:31:37:
                                            Hi John,
                                            What caught my eye in the manual was this on Page 73, last sentence:
                                            "Note! Undervoltage fault is stored in FAULT MEMORY if the fault occurs and automatic restart (RESTART #) is off. If the automatic restart is on, the undervoltage fault is not stored in the FAULT MEMORY unless the fault persists after restart."
                                            I thought it strange that Rod's unit shuts down without reporting an error but then found a note in the manual describing a situation in which just that occurs.
                                            Rod can disprove the under-voltage suggestion by checking his automatic restart setting. If it's already OFF, then the brown-out idea is wrong. If automatic restart is already ON, then turning it OFF should record an UNDERVOLTAGE error when the unit trips, provided brown-out really is causing the fault. It would be very helpful to get an error message out of the unit.
                                            I may be talking complete rollocks from my armchair: I've never had to debug an inverter.
                                            Rod Ashton
                                              @rodashton53132
                                              Apologies for delay. Much testing. Finally put the inverter onto another system and it is, with all the settings you guys have given, working OK. It appears that the problem is in the overload relay in the starter box. Just waiting for an uprated relay, as in the other system. Sorry if I got you chasing the wrong fox.
                                              #295177
                                              John Rudd
                                                @johnrudd16576
                                                Good to hear you got it sorted……wrong fox notwithstanding….
                                                Remind me not to take you hunting…..cheeky
                                                #295185
                                                Andy Holdaway
                                                  @andyholdaway
                                                  At least now you know the inverter IS set correctly!!
                                                  #295198
                                                    Thanks for reporting back Rod, I would never have thought of that and now I know! Well done you for fixing it.
                                                    #295202
                                                    Muzzer
                                                      @muzzer
                                                      That's the first mention of an overload relay – do you mean a DOL motor starter between the inverter and motor? If so, it's not clear why you have one of these. The motor should be wired directly to the inverter output which does a much better job of protecting the motor. And many inverters will get upset if you disconnect the motor under load.
                                                      Murray
