Home Made Rear Toolpost Issue
Home › Forums › Workshop Tools and Tooling › Home Made Rear Toolpost Issue
Viewing 11 posts - 151 through 161 (of 161 total)
  • #538302
    John Baron
      @johnbaron31275
      Posted by Dr_GMJN on 05/04/2021 23:32:05:
      This is a top view of the lathe showing the front toolpost, and rear post. The front post is usually angled a bit, and the tool not extended as much, which makes the relative clearances shown fairly representative. You can see that there is not much room with the rear post in place, and it’s far less risky and stressful to simply remove it:
      Hi Dr GMJN,
      I agree with your comment about completely removing the rear TP when not needed. I don't remove mine, but then I have the extended cross slide.
      However looking at your second picture and putting a rule across between the two tools, there is a definite height difference between them ! I assume that you are going to make a tool height setting gauge. If so you will be able to instantly see which is right.
      While I think about it, the height given it the drawing that I posted needs to be adjusted to suit your centre height. I did mention how I did it on mine. I really don't understand why it should be so difficult to get and set the tool height.
      I made and use the "Norman Patent" tool posts on both front and back of my cross slide ! No shims needed and always dead on height. Actually I think that making one is a very good turning and boring exercise.
      #538317
        Posted by Howard Lewis on 06/04/2021 07:20:18:
        Horrified at thought of PVA on slips!
        NO Brillo pad. NO olistone / diamond lap. PVA is water soluble, so soak it off. If the slips won't wring together, it is too late. But they should still be the most accurate piece of equipment for measuring that you have, so take care of them…
        I'm with Dr_GMJN on this one! Gauge blocks exist to produce precision measurements by stacking, and an un-calibrated second-hand set fails at the first hurdle because used blocks cannot be trusted. They might as well be used as weights and shims.
        What exactly are Gauge Blocks for in a home workshop? Bought for their feel-good factor rather than practical use maybe? (If so, I've no objection to pride of ownership, but it's not engineering!)
        Model Engineering and most repair work is done using fit by comparison techniques rather than being made within carefully measured tolerances as part of an industrial process set up specifically to make interchangeable parts. Not many model-engineers justify their Gauge Block purchases by making precision jigs, fixtures and Go – NoGo gauges!
        More common to hear of Gauge Blocks being used to validate digital calipers and micrometers, the idea being that even in poor condition, slips should be more accurate than the tool being tested. Well, maybe, but does the absolute accuracy of a micrometer matter much either when the owner is a fitter? My cynical streak suspect these things are all toys for boys.
        Just for fun I experimented with the sort of turning methods used before Micrometers and other precision workshop metrology was generally available. Ordinary spring calipers work remarkably well, the main problem being the need to develop a 'feel', and the extra time it takes. Have a go and see what you think.
        Put it this way, if all Gauge Blocks were confiscated by Duffer's ultra-radical enforcers, what exactly would model engineers be unable to make in their workshops? Be honest!
        smiley
        Edited By SillyOldDuffer on 06/04/2021 10:45:04
        #538321
        not done it yet
          @notdoneityet
          I’m with you there, Dave! (The boxes are heavy to lift as well 🙂 )
          I have a set and have used them occasionally – but they are better than my machining capability in general. I need to be using the surface grinder to justify using them in routine machining.
          #538323
          Circlip
            @circlip
            Heresy, Slips are a must have, just as a Mifford is the only ME tool to have. Used a slip gauge set many years ago when I was a prentice toolmaker, a micro screw jack and mics substitute for the "Adjustable packings" housed in either a wooden or plastic case.
            Regards Ian.
            #538328
              Posted by SillyOldDuffer on 06/04/2021 10:42:24:
              yes
              ‘Down-cycling’ is a worthy tradition : **LINK**
              https://www.hemmings.com/stories/2013/03/06/theres-a-coupe-joke-in-this-im-sure
              Hopper
                @hopper
                Posted by Dr_GMJN on 03/04/2021 16:58:27:
                So I've repaired the rear toolpost as suggested with some S275 steel, and M8 capheads:
                Even though I can't tighten the M8s any more, a small gap appears when tightening the clamp screws – not unexpected I guess:
                It works OK, but again, not the night and day difference I was expecting having read various accounts of using a rear post. I tried it on some brass bar. The parted-off bits have a pip on them, even though the parting tool is tapered slightly to to bit that's being parted – presumably to avoid this:
                The centre height looks OK to me, and when I extend the tool to the centre, there;s no pip on the stock:
                So all in all it works, but I wouldn't bother again – I'd just stick with the conventional front mount.
                To be fair, a bit of brass bar is hardly any kind of test for parting off. The stuff machines so easily regardless of tool attitude or just about anything else. Try a comparison front/rear test on a piece of 1" STEEL bar and then a piece of 1.5" steel bar.
                You'll get a lot more swarf jamming and micro-welding and dig ins and other unpleasantness with steel, which the upside down tool may help to alleviate.
                Another thing is that when GH Thomas, Sparey, Duplex and co were extolling the virtues of rear toolposts, they had no choice but the old tapered profile HSS blades, which were prone to jamming on the sides of the groove with swarf. Your carbide insert is wider than the shank that holds it, providing that much needed clearance for swarf particles to pass through relatively unmolested. Also, it looks like it has a divot in the top cutting surface so curls the chip up narrower than the slot it cuts, thus avoiding more swarf jams.
                Like the Eccentric Engineering T section HSS blade I posted a thread about recently, your insert tooling will work much better right way up than the old tapered blades.
                One thing GHT and Co. got right was making their toolposts a heavy L section with two bolts through the foot of the L so the vertical body stuck out behind the cross slide, giving you an extra 1.5 inches of room there behind the job when not in use.
                You could use yours as a quick removeable single bolt rear toolpost and just whip it on and off as needed. That's what I do on the old Drummond. Has been working that way since World War 2 or a bit earlier as far as I know.
                PS
                Seems odd that you have that gap opening up when you clamp the tool on your modified post. Unless you are putting massive torque on those clamping screws that should not be happening. I'd check that the silver allen screws are not bottoming on their threads prematurely. Also make sure the bottoms of the countersunk holes they sit in are properly square shouldered, not drilled at an angle with standard pointed drill bit. And then torque those silver screws up with a 12" piece of pipe over the allen key. Dont strip them, but make them damn tight. (As they say in Harley Davidson circles, do 'em up til they strip, then back 'em off quarter of a turn. )
                #538344
                Zan
                  @zan
                  Slips are extremely useful and mine see a lot of use. Yesterday I was making a yoke for crankshaft to work in. The slips made it very very easy to get file the gauge plate material easily to a very smooth and polished finish. Yes the slot ended up 4 thou too small but I’ll make the split bearing to fit
                  mine are second hand, from two sets at a total cost of £35.. I can’t work to the limits which a new on spec set would “ measure” to. They just about stack, but I’m very pleased with the number of times I use them
                  heres the yoke clamped to align the cylinder bridge on the pump, but before finishing the 0.309” yoke  sorry it’s upside dow,  I switched it over before uploading, but still wrong!831388c4-e7f0-4417-8b7d-59e8a68bcbcf.jpeg
                  Edited By Zan on 06/04/2021 13:23:00
                  #538348
                  Dr_GMJN
                    @dr_gmjn
                    Thanks guys – a few points, which to be fair I did mention in various posts:
                    As I said, some types of PVA are water soluble, and again, I said I removed it from the slip gauges by soaking in warm water.
                    I did mention that the tool projection was excessive in the picture (can't remember why, but that's how I'd left it), but the tool post is often turned at an angle, so even with reduced overhang, the gap is representative – and it's not nice to be constrained between two immovable objects while machining.
                    I also mentioned that I'd used a socket wrench to re-tighten the M8 capheads, and that opening up isn't an issue now. Regarding parting off on brass – I figured that if it wasn't working properly on brass, it sure wouldn't on steel. I'd rather do the setting on easier to machine materials. I'm waiting for some longer M5 clamp bolts to arrive, on which I'll remove the end threads and face the ends.
                    And yes, the insert is profiled to curl the swarf with a central bulge – they work well, but because they are asymmetric, it's making height setting a bit more difficult. The blade holder also tends to spring away from the workpiece at the final bit of the cut, which itself leaves a pip. I'll sort it eventually.
                    Cheers.
                    #538427
                    Howard Lewis
                      @howardlewis46836
                      Use of slips depends on your background, and the standards you set, (Even, if my case there is great difficulty in working to them ).
                      Having spent the major part of my working life in Quality and therefor spending a lot of time with Inspection, Standards Room and Calibration Room, I am obviously biased.
                      Can anyone say why, if they are so useless, Industry uses slips?
                      If they wring together the condition is good enough to say that they are accurate. Even if they don't, but have no obvious damage, they can be used as standards which are far more accurate than anything else in the usual hobby workshop.
                      I last used mine (Which are old and some do not wring together ) to measure a lipseal OD and the bore for it, so that the right interference could be accurately achieved.
                      Before that, to ensure that a there would be the required interference on a "Heat and Freeze" assembly, when cold..
                      Each to his own.
                      #538439
                      not done it yet
                        @notdoneityet
                        I would guess that one of the most common practical uses in the workshop is to accurately gauge the width of a slot, to be able to finish it exactly on size – so that a standard key will fit tightly without clearance? Sine blocks and angles is another, I suppose?
                        I’ve several repairs to make where shrink fitting a piece of metal into a slot is required. I would make tight fitting ‘go’ plug on one edge of a strip and then use a piece machined just slightly bigger for the shrink fit. My slip gauges will most certainly hasten that job. These slots are only a very few mm wide in thinnish cast iron and really need to be invisible after repair.
                        What other regular uses do people use them for? Marking out?…? …?
                        #538450
                        Dr_GMJN
                          @dr_gmjn
                          Posted by Howard Lewis on 06/04/2021 21:34:24:
                          Each to his own.
                          Not sure anyone said they were useless. It's just that – for me – a second hand set of slip gauges bought off EBay is far more use for different sized, flat weights for model building, or packing pieces for setting up work, than for the high-accuracy metrology work they were intended for in industry.
                          It's nothing to do with the standards I set for myself, just that its not worth the bother of using them with the care they demand, in my workshop/garage. For example – is your workshop temperature controlled to 20 degrees C +/- 0.1 degree? Do you use chamois gloves to handle them?
                          It's not like I deliberately throw then on the floor or dip them in salt water, and I'm happy to use some odd ones to check that a micrometer or vernier is about right, but that's as far as it goes. The stuff I'm doing doesn't seem to require absolute precision, so long as things fit together nicely and don't rattle, I'm fairly happy.
                          Don't get me wrong – I'm not some caveman, and I do look after my tools as best I can, but when equipment starts to take more effort to use correctly in a home workshop than the results justify, frankly, what's the point?
