Help for beginner
Help for beginner
Home › Forums › Beginners questions › Help for beginner
  • #105325
    Jarek Ziel
      @jarekziel28160
      Hi!
      I'm not englishman, and i have trouble with some sentce. Can you explain to me what does it mean the "turn for grind"? I will very grateful.
      Jarek
      #6474
      Jarek Ziel
        @jarekziel28160
        #105423
        Tony Ray
          @tonyray65007
          Jarek,
          'Turn for grind' does not make any sense on its own, perhaps you are reading something that was e.g. translated from e.g. Chinese ?
          Turn is probably from the verb turning ie. to remove metal using a lathe.
          Grind in this is probably from the verb grinding i.e to remove metal by ginding eg as done by a cylindical grinder.
          if you could reply with thefull paragraph from where you have taken 'turn for grind ' I might be able to work it out for you.
          Tony
          #105424
          Ady1
            @ady1
            "turn for grind"
            is bad english
            It has no meaning for us
            As mentioned, if you give us the entire sentence or paragraph then we should be able to help translate it into good english
            #105427
            Robert Dodds
              @robertdodds43397
              Jarek,
              Engineers have had a form of Text Speak for many years.
              You need to make clear where this statement is used but IMHO it is a short instruction to turn typically 0.5mm oversize to the dimension and then remove from the lathe and grind to finish size, maybe after hardening the part.
              Bob D
              #105434
              magpie
                @magpie
                Tony. if Jarek do'es not understand english very well he will have trouble with e.g. and i.e.
                Robert. He will also probably not understand IMOH. But i agree with you both that we need the full sentence in order to grasp the meaning.
                Cheers Derek.
                #105435
                Siddley
                  @siddley
                  Jarek – can you find a 'scientific and technical' dictionary in English and your own language ? That is what I had to do when I emigrated to Spain. It will help you a lot.
                  The modern technical dictionaries are very expensive, but older versions from the 1950's or 1960's are cheap and still contain all the engineering words you will need.
                  #105448
                  Split Pin
                    @splitpin
                    "turn for grind" is as described by Bob D, it is an instruction to a skilled operater in a machine shop to indicate that there is a need for further machining on that part of the job to complete it, either a particular surface finish is required or a more precision size than would be normally achieved from commercial turning i.e 0.0001" or 0.001mm, Depending upon heat treatment method different allowances would be added, the original drawing may have been produced for in house use where all the participants understand the process of manufacture, and no doubt contains more information than is being presented by the original poster
                    Steve G
                    #105451
                    Grizzly bear
                      @grizzlybear
                      Hi Jarek, Where are you from, Poland? Come back on the forum, you will get good help. (I have typed this slowly, so it will be easier to read).
                      Regards, Bear..
                      #105453
                      DMB
                        @dmb
                        Jarek,
                        Hope this might help –
                        i.e. = Latin abbreviation for id est, English = that is.
                        e.g. = Latin abbreviation, English = for example.
                        IMHO = modern computer abbreviation = In My Honest Opinion.
                        The two Latin abbreviations are commonly used.
                        GaryM
                          @garym
                          Posted by DMB on 04/12/2012 17:33:06:
                          <snip>……IMHO = modern computer abbreviation = In My Honest Opinion…..<snip>
                          I think IMHO is normally taken as In My Humble Opinion although David Cameron may disagree
                          #105595
                          Terryd
                            @terryd72465
                            Posted by Gary Marland on 05/12/2012 23:52:57:
                            LOL
                            #105605
                            Robert Dodds
                              @robertdodds43397
                              I KNOW I meant "humble" when I wrote the original.
                              I always try to be humble but I can't say I'm always honest. For the future I will resort to using full written English especially as all this banter seems to have scared off poor Jarek .
                              I think it was Grizzly's joke about slow reading that startred the rot….. Polish jokes are only for Americans to tell, the English tell jokes about the Irish and Germans lampoon the Bavarians. Cross the boundaries at your peril! devil
                              Bob D
                              #105607
                              FMES
                                @fmes
                                I would have thought it meant turn to a size leaving an allowance for grinding, i.e a couple of thouu oversize on a crank say, to allow for journal grinding.
                                and then as I read up the posts – exactly what Split pin said.
                                #105612
                                Sub Mandrel
                                  @submandrel
                                  I have enough Irish in me to tell Kerryman jokes (my bit is from Cork).
                                  "I My Hugs Often", perhaps? addressed to Ed Balls, no doubt…
                                  Takeaway
                                    @takeaway
                                    Turn to grind = cut (turn) metal part using lathe but leave + 0 .3 – 0.5mm on outside diameter and smaller same amount in holes. 0.3 – 0.5 is called "grinding allowance". Then grind part to finish size. I hope you understand. Stuart
