Anyone familiar with Myford 254s ?
Home Forums General Questions Anyone familiar with Myford 254s ?
  • #23599
    Bob Unitt 1
      @bobunitt1
      #170748
      Bob Unitt 1
        @bobunitt1
        I'm servicing my Myford 254s and I've found an adjuster which isn't described in the service manual, and the guy at Myford doesn't know what it is either. Is there anyone on this forum who might be able to help ?
        #170752
        Nick_G
          @nick_g
          Posted by Bob Unitt 1 on 26/11/2014 17:34:37:
          A picture of the item and it's location would assist greatly I would imagine. smiley
          Nick
          #170820
          Bob Unitt 1
            @bobunitt1
            This is all I have – I know it's a stop-crew, but not what it stops (Excuseme if I get it wrong, this is the first time I've posted an image here) :-
            #170821
              As a guess, it may adjust the degree of engagement of the half nut.
              Swarf, Mostly!
                @swarfmostly
                Hi there, Bob,
                You've cropped your third photo. What's on the lower end of the leader line whose upper end is at the bottom left-hand corner of the front of the gearbox?
                Best regards,
                Swarf, Mostly!
                #170825
                Nick_G
                  @nick_g
                  I cannot assist you in it's purpose.
                  But I can say that some of the brethren here will be mortified to the degree of having to go to see their doctor tomorrow due to seeing a Myford so oily and dirty. cryingwinkwinkwink
                  Nick angel
                  #170826
                  Bob Unitt 1
                    @bobunitt1
                    Posted by Swarf, Mostly! on 27/11/2014 20:11:39:
                    Oil drain plug.
                    #170827
                    Bob Unitt 1
                      @bobunitt1
                      Posted by Nick_G on 27/11/2014 20:15:01:I cannot assist you in it's purpose.
                      A clean lathe is the sign of a sick mind… cheeky
                      #170830
                      Nick_G
                        @nick_g
                        Posted by Bob Unitt 1 on 27/11/2014 20:17:55:
                        laugh
                        Nick
                        #170833
                            Yep, it has to be the halfnut engagement stop.
                            Bob Unitt 1
                              @bobunitt1
                              Posted by JasonB on 27/11/2014 20:56:34:
                              Full drawing and parts list
                              I have those thanks, I didn't want to reproduce them in full in case there was a copyright issue.
                              #170849
                              Bob Unitt 1
                                @bobunitt1
                                Posted by Neil Wyatt on 27/11/2014 21:04:16:
                                Thanks. I wonder how it's supposed to be set …
                                #170852
                                John Stevenson 1
                                  @johnstevenson1
                                  Slack it off, close 1/2 nuts and keep pressure on to keep closed.
                                  Then tighten the screw until it just takes over from the hand pressure. This means that it has the slightest clearance.
                                  Job done, off down the pub.
                                  #170868
                                  Bob Unitt 1
                                    @bobunitt1
                                    Posted by John Stevenson on 27/11/2014 22:39:51:
                                    Thanks John, enjoy your pint.
                                    #170987
                                    Bob Unitt 1
                                      @bobunitt1
                                      As suggested it controls the clearance on the engaged half-nuts. Someone on another list dug out the S7 manual page for me, and based on John's post and on that page I :-
                                      Unscrewed the Stop-screw.
                                      Engaged the leadscrew nuts.
                                      Put a DTI probe on the Engagement lever.
                                      Wound the Stop-screw up until the DTI indicated movement.
                                      Removed the DTI.
                                      Wound the Stop-screw up a further 1/4-turn.
                                      Thank you all for your replies.
                                      I'll now print this sequence off, along with my pictures, and put it in the manual – for the next time I can't remember what that screw does…
                                      #170990
                                      David Jupp
                                        @davidjupp51506
                                        The drawing for the 254R on Myford site matches the equipment shown better than the 254S drawing.
