self catering v independent
Home › Forums › General Questions › self catering v independent
  • #556810
    Eric Cox
      @ericcox50497
      I've been turning (conquest super) some 1/2" square MS. down to 7/16" Dia. Each cut was 0.010 over a length of 2", supported by a centre in the tail stock and held in a 4 jaw self entering chuck. The intermittent cutting caused the chuck to open slightly and the job to come loose. Would I have been better using a 4 jaw independent chuck.
      #28287
      Eric Cox
        @ericcox50497
        #556813
        Martin Kyte
          @martinkyte99762
          Basically yes. More likely the square was slightly rectangular.
          regards Martin
          #556824
            I nominate your thread title for the Typo of the week, Eric
            devil
            But, yes … I agree with Martin.
            HOWARDT
              @howardt
              Agree. The continuous cyclic knock causes the scroll to loosen, had something similar recently.
              #556842
              Oldiron
                @oldiron
                Posted by Michael Gilligan on 03/08/2021 10:05:15:
                devil
                Oh the joys of predictive text.
                regards
                #556843
                Anonymous
                  It would be better to take one cut rather than lots of small cuts. The 2" bolts at the bottom of this photo were turned from 1/2" square steel down to 1/4" diameter in one pass with no tailstock support:
                  And the resultant swarf:
                  To be fair the work was held in a 1/2" square collet which doesn't work loose, but still no support needed.
                  #556845
                    How fast were you turning and how thick were those ‘curly band saw blades’, Andrew?
                    Between 230 thou. and 125thou deep, so an average cut of about 175 thou.
                    Apart from the catering aspect, using a ‘self entering’ chuck must save some time and effort? Does it tighten itself as well?
                    I don’t particularly like self centring 4 jaw chucks for that very reason – they can only work 100% on perfectly round or square work pieces.
                    #556855
                    Anonymous
                      Posted by not done it yet on 03/08/2021 14:02:42:
                      How fast were you turning and how thick were those ‘curly band saw blades’……….
                      Probably running at 1000rpm. I don't have any swarf left (that I can find) but thickess is likely around 8-10 thou. Without measuring I don't know the exact feedrate, as the lathe in question only has an uncalibrated hydraulic feed – you adjust it to give the required finish.
                      #556900
                        Thanks Andrew. A bit more than a 1/2HP myford could hope to cope with🙂
                        Too much for my lathe, too, but I might be able to avoid the intermittent cut with a bit of adjustment with feeds and speed – but possibly not without tailstock support.
                        #556916
                        old mart
                          @oldmart
                          The main shortcoming of a 4 jaw scroll chuck is that it requires perfect material to hold, and even if the material is perfect, there is always a large chance that all of the the jaws are not always the same distance from the spindle axis. A three jaw scroll always clamps on the workpiece even if not accurately. The 4 jaw independent takes more time and effort but can hold the work in any position you would desire.
                          #556925
                          roy entwistle
                            @royentwistle24699
                            I always thought that a 4 jaw self centring chuck was for woodwork
