Machin guards
Machin guards
Home Forums General Questions Machin guards
  • #549629
    Jonathon Bywater
      @jonathonbywater45041
      Wondering what clear plastic to use as machine guards. Acrylic shatters I believe so something bendable ! Thanks.
      #28215
      Jonathon Bywater
        Material
        #549632
        Russell Eberhardt
          @russelleberhardt48058
          Polycarbonate.
          Russell
          #549633
          Jonathon Bywater
            Thank you Russel
            #549636
            Rod Renshaw
              @rodrenshaw28584
              Acrylic is said to go opaque after some years of contact with cutting fluids.
              #549646
              Jonathon Bywater
                I think acrylic shatters to . Nice!
                #549680
                Bill Pudney
                  @billpudney37759
                  Polycarbonate a.k.a. Lexan is what you want. Acrylic a.k.a. Perspex or Plexiglass does shatter, Polycarbonate doesn't.
                  Polycarbonate is used on industrial machines when a cheap transparent guard is required. Armoured glass is possibly more resistant to impact but more expensive.
                  cheers
                  Bill
                  #549683
                  Jeff Dayman
                    @jeffdayman43397
                    Lexan is Sabic's brand of polycarbonate ( Used to be GE Lexan, but General Electric Plastics was bought by Sabic in about 2007 as I recall)
                    Makrolon is Covestro's brand of polycarbonate (Used to be BASF Makrolon, but BASF became Covestro in about 2011 as I recall)
                    Local to me, Makrolon sheet is much cheaper to buy than Lexan. May be wise to shop a bit where you are, when buying polycarbonate sheet.
                    #549770
                    old mart
                      @oldmart
                      I made some guards out of 6mm polycarbonate sheet for the museum's mills simply because it was available laying around. Slightly overkill, as 3mm would have been easier to work. The arm holding the screens is a cheap adjustable arm stand for flat screen monitors up to about 19".
                      #549824
                      Jonathon Bywater
                        Interesting. Thank you
                        #549835
                          Doesn’t it depend on what one is guarding against? Guarding against splashes, physical contact with moving parts, or prevention of projectiles escaping into the main workshop need different approaches.
                          #549837
                          David Jupp
                            @davidjupp51506
                            If using Polycarbonate for guards, never use acetone for cleaning. It leads to severe stress cracking.
                            #549839
                            Ex contributor
                              @mgnbuk
                              No, not really.
                              The OP requirement was for a clear plastic material & for a machine tool application polycarbonate sheet covers all bases, so why consider anything else ?
                              The only real disadvantage to it is that it scratches if you are not careful cleaning it. Some polycarbonate is available with a scratch resistant coating & industrial machines sometimes use a safety glass / polycarbonate / safety glass sandwich to give more resistance to scratching, but the downside to that solution is that an impact from a broken tool or job coming out on a lathe cracks the glass & replacements are expensive. And heavy.
                              Nigel B.
                              #549855
                              noel shelley
                                @noelshelley55608
                                A good cheap sorce would be to try a sign maker , I once came home with a large amount for a £5 in colours as well, some was 12mm thick. For off cuts try AMARI PLASTICS, in the UK. Good Luck, Noel.
                                #549887
                                old mart
                                  @oldmart
                                  To bend polycarbonate, a hot air gun will do, my efforts with the 6mm were not very good, but thinner material should be easier. I tended to overheat the bend line, the picture of the guard with bent ends does not really show the poor bends. Practice with a small offcut would help a lot.
                                  #550385
                                  Jonathon Bywater
                                    Sorry ,had no signal for 2 days!msinly to stop oil and swarf flying at me. Most things I do a pretty small so polycarbonate would probably stop it. Never happened yet.I still wear face protection too,!
