wiring my hoover motor
Home Forums General Questions wiring my hoover motor
  • #23663
    James Routledge 1
      @jamesroutledge1
      #175338
      James Routledge 1
        @jamesroutledge1
        hi everyone, im new to the forum and would like advice on how to wire my hoover motor on my myford lathe.
        cheers, james
        #175406
          Welcome James,
          I'm afraid that's got more terminals than mine, It could be 3-phase,. or it could be to allow reversing.
          Your insulation looks OK, but have a good look as older ones can have rubber insulated wires that perish and start fires.
          For anyone who finds a simpler arrangement of connections (just 3) my single phase one is (don't follow these connections James!):
          Live – 4
          Neutral – 3
          Earth – marked terminal on outside of case.
          Capacitor 2 & 3
          The red and green wires on mine go to the capacitor switch.
          #175436
          Les Jones 1
            @lesjones1
            Hi James,
            I may be able to help but you will need to do some tests to identify the winding and centrifugal switch contacts. Do you have a multimeter and know how to use it ? Do you have a way to spin the motor up to near its rated speed ? (A suitable electric drill for example.) Does the motor have connections to the back of the terminal plate ? (If so make a diagram of these.) Does the motor have one or two capacitors on it ? What is behind the lump on the terminal block between the middle two terminals on the bottom row ?
            Les.
            Edited By Les Jones 1 on 10/01/2015 08:33:14
            #175449
            Robbo
              @robbo
              James,
              A picture of the data plate on the side of the motor would probably help identify it.
              #175829
              James Routledge 1
                @jamesroutledge1
                #175832
                  How strange, your motor has the same serial number as mine, James.
                  Edited By Neil Wyatt on 13/01/2015 09:38:23
