Posted by Andrew Tinsley on 04/10/2019 16:23:07:
I have read, or been told that if one uses a toothed belt for the final drive to the lathe mandrel, then you are likely to get a "pattern" on the turned surface. Is this fact or fable?
Andrew.
Only if you have a lathe with a single-phase motor and/or damaged bearings! Single phase motors vibrate much more than any other, and a springy belt would help hide the defect. But if a plain belt is slack enough to absorb single phase vibration, it can't deliver power consistently to the cutter. That's another way of creating an unwanted pattern.
With all the fuss about levelling and Rollies Dad, I'm surprised more interest isn't taken in stopping lathes from vibrating.
