revolving chucks
revolving chucks
Home › Forums › Workshop Tools and Tooling › revolving chucks
  • #262309
    mick70
      @mick70
      just looking through arc catalogue and seen some revolving chucks and backplates.
      they are on mt2 to fit talstock.
      what are they used for?
      #18233
      mick70
        @mick70
        #262313
          Holding the other end of a thing which is not suited to a centre.
          mick70
            @mick70
            that simple?
            was overthinking it, thought it was going to be more complicated.
            are they worth having?
            Edited By naughtyboy on 22/10/2016 10:30:49
            #262322
            mechman48
              @mechman48
              I have the rotating 3 jaw drill chuck from the same supplier; can't recall what I used it for, some small but long length that was too small for a centre… 'does what it says on the tin' …
              George.
              #262327
                Posted by naughtyboy on 22/10/2016 10:30:21:
                that simple?
                I've never yet had the need for one … but it's nice to know they are available.
                NJH
                  @njh
                  Some years ago I purchased a No 2 MT revolving centre with a Myford headstock thread on it – hence headstock chucks can be mounted on the tailstock to support work. A well made item …………. I'm still waiting to find a use for it .
                  Of course I could get rid of it ……….. but then I would instantly find a desperate need for it !
                  Norman
                  #262337
                  Hopper
                    @hopper
                    The only thing I have ever seen them used for is for machining commutators on old car and motorbike generators and starter motors. Many don't have centre drill hole in that end of the spindle for some reason. And others that do have a centre drill hole, the OD of the spindle and the commutator are not concentric with the centre hole. Something to do with the way they are made in a rapid-fire production process. I had a 2001 Honda starter motor armature that was like this.
                    So, you grip one end of the spindle in the headstock chuck and the other end in a revolving tailstock chuck and take a fine cut over the commutator segments if they need cleaning up and thus get them concentric with teh spindle where it fits into its bearing during normal service.
                    I think they used to be called an armature chuck once upon a long time ago.
                    Are they worth having? Yes if you recondition DC generators, electric motors (brush type), magnetos, starter motors etc.  Otherwise? I can't think of any other time I needed one. Usually you can drill a centre hole and use a tailstock centre, even if you then cut the end off and face it to get rid of the centre hole afterwards. Or turn up a bushing to fit over the end of a shaft, with a centre hole drilled in the bushing.  Much easier to use a revolving chuck though I suppose.
                    Edited By Hopper on 22/10/2016 13:04:24
                    Edited By Hopper on 22/10/2016 13:08:37
                    #262509
                      Most times you can use an existing centre of a fixed steady, but a revolving chuck is less likely to mark the outer surface than a steady.
                      Howard Lewis
                        @howardlewis46836
                        Made myself a revolving drill chuck, and have used it to hold small parts without a centre, or sometimes as a small running centre, in the Tailstock . Not a n absolute essential, but occasionally a very useful tool to have.
