Hi Ady
I had one of these before upgrading to separate mill / lathe. they a realy solid piece of kid but very hefty weightwise so before you lift it onto your bench I would remove the mill head & just lift the lathe section first, unless you have an engine hoist, remember to balance it out if you lift it all in one. It does have four lifting bars that slide in/out of the lathe bed casting so use these.
If you have got it from Machine Mart then they supply a MT3 milling cutter (indexible type,4 cutters- optional extra) I suggest you get this, it is ideal as a fly cutter. another item I suggest is the cast iron riser block that fastens to the cross slide as this will keep your mill/drill spindle at its shortest extension, otherwise you may have to lower your spindle to reach the vice/job which will reduce rigidity even though there is a spindle lock. M/Mart do sell a collet set – optional extra again but if you can afford it I would go for a ER32 collet system, max' cutter 20mm, the ER 25 max' cutter is 16mm. IIRC the draw bar is 10/12mm but, sometimes comes with a 3/8 BSW bar so double check..
It should come with a 3 jaw chuck, but you will need to purchase a 4 jaw as well (extra again), fixed head & tailstock centres, MT4 & 3 plus a basic kit of carbide tipped brazed lathe tools (Chinese quality… ??? replace these with decent indexible tip tool asap), rotating centre, faceplate,fixed & travelling steadies etc. …all extras! See Machine Marts web site under ‘Metalworking’ for all the extras you may (will eventually) need, plus other buyers reviews.
A good solid starter’s machine which I had for a few years, & you will enjoy using it, just make sure all your fastenings are secure before using it. One point I found, although I had mine mounted on a solid wooden bench, so it was quite rigid, if you get the base, this is made from sheet metal so with all that weight up top, & if you’re milling/drilling, you will get vibration, which won’t do any of your finishes/cutters/drills a lot of good, also I suggest when you do lathe work you swing your mill head around so it lines up axially with the lathe bed & lock it up, not behind, this will help to eliminate any off balance/ vibration problems.
A decent machine that will give you what you ask it to do…, If I can help any further drop me a pm. … enjoy
George
Edited By mechman48 on 02/09/2013 09:40:08
