graphite rod
graphite rod
  • #509654
    bricky
      @bricky
      What grade of graphite is required to make a piston rod and piston for a Jan Ridders coffee cup engine.Also is it easy to machine and thread.Whiich supplier is the best to get it from.
      Frank
      #33731
      bricky
        @bricky
        #509659
        pgk pgk
          @pgkpgk17461
          When i made my Ridders heat engine I just bought a graphite rod from ebay. It worked fine rom the viewpoint fo threading and turning – just very messy (tape the vacuum hose near the cutter)
          pgk
          #509660
          Roderick Jenkins
            @roderickjenkins93242
            From my experience, if you are going to thread then dense, fine grain is best. Noggin End have a good selection:
            HTH,
            Rod
            #509683
            bricky
              @bricky
              Thank you both for the information ,I now know what to order and do.
              Frank
              #509695
              mgnbuk
                @mgnbuk
                Drop me a pm with your address & an idea of what size lump you need & I'll have a word with my MD. (I work for his graphite supply & machining company).
                He has been amenable in the past to me raiding the oddments box for a suitable piece of fine grained isostatic graphite for this purpose. All that has been asked in return is that the recipent sends in a picture of the finished product.
                He provides the graphite & I pay the postage – make a donation to charity if you would like, but not compulsory !
                Nigel B.
                #509702
                Mike Poole
                  @mikepoole82104
                  The filthiest workshop I have ever been in was our EDM department, everything was covered in black dust and combined with the foul smelling oil from the EDM machines it made a hellhole, I have never missed repairing those machines. I hope you and your workshop recover from the graphite experience.
                  Edited By Mike Poole on 24/11/2020 22:56:51
                  #509768
                  Mike Poole
                    @mikepoole82104
                    Many vacuum cleaners pull the air through the motor so be sure that the very fine dust will stay in the bag and not get deposited in the motor, I doubt a one off job will cause a problem but if you use a lot of graphite then it might be worth checking the motor for any deposits.
