Deep drilling
Deep drilling
Home › Forums › Workshop Techniques › Deep drilling
Viewing 3 posts - 26 through 28 (of 28 total)
  • #858771
    Trevor Drabble 1
      @trevordrabble1
      When I worked at Ital in Sheffield we were part of the Clarkson group ) we made small diameter but long crankshaft drills ( minimum length 10x diameter ) that were purpose made for such tasks . In order  to minimise wander , they had thicker webs , worm type flutes and modified points to reduce size and angle of chisel points . The most common problem we encountered were the drills not being driven fast enough and also the application of excessive feed , resulting in the drill wandering and sometimes even breaking within the work .
      Assuming only standard HSS drills and limited facilities are available to OP , suggest using highest speed possible , the use of diligent thinning of the point to reduce chisel width and angle ( from 130° to around 115°) , copious use of paraffin to prevent the chips from binding to the lands ( since drilling aluminium) and also light , repeated pecking technique . Cumulative use of the above should minimise wander .
      Hope the OP finds the above of constructive use .
      #858874
      Speedy Builder5
        @speedybuilder5
        Pleased to say that the deep drilling following advice on here – Spot drill, jobber and extended drill gave perfect results.  Approx 3″ deep by 4mm diameter in Al Alloy using WD40 as lubricant, flush of debris.
        Thanks to all
        Bob
        #858949
        bernard towers
          @bernardtowers37738
          Most times with jobs like this its the attention to detail that sees you through not just wade in and hope for the best, glad it went well.
        Home › Forums › Workshop Techniques › Topics
