If I take a look at the local recycling centre. They have a cage full vacuum cleaners. At a rough count, well over half of these cleaners are Dyson. Draw your own conclusions.
Andrew.
The evidence is insufficient. Assuming Andrew’s observation is typical, and he’s not simply noticed a random build up at one recycling centre, I can suggest a few hypotheses. Probably more, and they might overlap:
- Dyson vacuum cleaners fail more often than other makes.
- All vacuum cleaners cleaners fail at about the same rate but Dysons are much more popular than other makes. More being recycled because more of them exist.
- Dysons are bought as bling, causing old models to be replaced prematurely by the latest showpiece.
Before coming to a conclusion it’s necessary to investigate further.
As we know, an engineer is defined as man who does for a quid what any fool can do for a guinea. Vacuum cleaners, and many other domestic products, include planned obsolescence. They are designed to fail after ‘n’ years and to be difficult to repair so that the maker doesn’t go bankrupt. The outlook for a manufacturer producing an immortal product is grim; once the market is saturated they cannot make a profit. Arguably Myford the manufacturer would still be with us if their lathes weren’t so hard wearing!
The original vacuum cleaner worked very well. A motor drove a fan that pushed dirty air into a paper filter bag that exhausted via a cloth cover. Main problem was emptying and replacing the paper bag, and a tendency for the outer cloth cover to slowly choke up. Later designs looked fancy and were lighter, but – in my experience – were built in a way that allowed leaks to develop. So they work well for a year, and then gradually lose suck, until the owner gets fed up and buys a new one.
Dyson eliminated the paper bag filter, making emptying the machine easier and cleaner. He also improved the suck. Cyclone dust extractors date back well over a century, but scaling them down from a diameter of few metres into a domestic appliance requires very careful optimisation. For example, dust extraction works more efficiently with increasing vortex speed, making it desirable to drive the fan very fast, say 100,000rpm. And having done that, the air-flow has to be managed so the dust drops out in the container, not in the pipework or motor.
My vacuum is a cyclone based VAX about 5 years old. Time revealed room for improvement! Dust collects in the wrong places and the seals are leaking. It’s imperfect cyclone extractor is backed up by a pair of paper filters needing regular maintenance. Scored 8/10 when new, down to 4/10 now. I’m close to replacing it, and might try a Commercial Cleaner. These are made for hard work in hotels etc. and might last forever doing light duty in my home. But be careful: initial research found a number of cleaners described as “commercial” on the web that are suspiciously cheap. In contrast my ancient Aquavax is still going strong. The design is very simple and I’ve repaired it twice. Sadly, though brilliant in the workshop, it’s too cumbersome in the house. It’s much the same as a Henry.
Like Richard I don’t need LEDs, but my mum does. She’s too fragile to have her cataracts fixed…
