Boiler explosion on Guadeloupe.
Home › Forums › The Tea Room › Boiler explosion on Guadeloupe.
  • #857899
    howardb
      @howardb
      “A second person has died “from their injuries” following the explosion at a distillery in Guadeloupe on Friday, July 24, Alexandra Onfray, deputy prosecutor of Pointe-à-Pitre, told Agence France Presse on Sunday , confirming reports from local media.
      On Friday, the toll from the boiler explosion at the Montebello distillery in Petit-Bourg stood at one dead and two people whose lives were in danger.
      In Guadeloupe, this industrial accident has aroused much emotion and reaction among the population, elected officials and also the rum industry”
      In general,the boilers are fuelled by the “bagasse” which is the stalks and residue from the crushing process of the sugar cane which drives the rum industry.
      The image of the plant looks like a big steamer.
      https://www.ouest-france.fr/region-guadeloupe/guadeloupe-deces-dun-des-blesses-de-lexplosion-de-la-distillerie-e84a8462-8941-11f1-abec-0816624751ff
      #857914
        Certainly still using old steam engines out there and on other islands. Not sure about the boilers whether they are a similar vintage or newer.
        https://www.internationalsteam.co.uk/mills/guadeloupemill02.htm
        I have started to make a model of one of the French build Fives-Lille engines
        #857943
        Speedy Builder5
          @speedybuilder5
          Which bit exploded first, the bio Gas generator or the Boiler ?
          #857964
            I think they just burn the waste directly rather than turn it to gas first. Certainly the way it used to be done and just like the straw burning portables which just fed the stalks straight into teh firebox.
            #857974
            duncan webster 1
              @duncanwebster1
              When I worked at Greenwood&Batley we supplied steam turbines to the Caribbean. I think they had a need for process steam, so if you generate it at higher pressure and send it through a turbine first you get a very good payback.
              #858016
              noel shelley
                @noelshelley55608
                Rum distillery ! Was it a boiler explosion or did the alcohol vapour explode, Christmas pud with brandy burns well, even at 35%. A vapour leak would be highly inflammable. Noel.
                #858051
                howardb
                  @howardb
                  It seems that the Montebello distillery was being operated outside of the rules, formal notices about safety were ignored etc.
                  https://la1ere.franceinfo.fr/guadeloupe/explosion-a-la-distillerie-montebello-une-usine-visee-par-des-mises-en-demeure-non-suivies-d-effets-1723288.html
                  Use google translate if necessary.
                  #858122
                  vintagengineer
                    @vintagengineer
                    Begasse is a sawdust like material and is normally blown into the boiler. Most sugar mills run on steam as it is a free energy.
                    #858178
                    duncan webster 1
                      @duncanwebster1
                      According to Wikipedia it is possible to convert bagasse (and wood, grass etc) to ethanol, on which you could run your car, carbon neutral. Trouble is it’s expensive, but if the Hormuz issue isn’t resolved perhaps it is viable
                      #858182
                        Although blowing in the material may be a more efficient modern way and more suited to fixed boilers it was often made into bales and fed into the boiler. Usually a “colonial” one with longer fire box.
                        @bacolodtourguide
                        🚂 Did you know? The steam locomotive train here in Negros is powered by bagasse — a by-product of sugarcane after juice extraction! 💨🔥 This eco-friendly fuel keeps the heritage train running, giving you a nostalgic ride through our rich sugar history. 🍂🇵🇭 #BacolodTourGuide #SteamTrain #NegrosHeritage #BagassePowered #Sugarlandia #EcoTourism #HistoryOnTracks #TravelNegros #PhilippineHistory
                        ♬ Mechanic Shop – NaderGator
