Brass Hexagon Sizes
Brass Hexagon Sizes
Home Forums Beginners questions Brass Hexagon Sizes
  • #179789
    David Cambridge
      @davidcambridge45658
      Hi All
      A very basic question this time – if I bought some 10 mm brass hexagon, which dimension does the 10 mm in the below diagram refer to (red, green, blue or none of them ?)
      David
      #7475
      David Cambridge
        Brass Hexagon Sizes
        #179790
        Tim Stevens
          @timstevens64731
          Green – the size for M6 screws and nuts. And, incidentally, the easiest of the three to measure.
          Cheers, Tim
          #179791
          mechman48
            @mechman48
            I've always measured AF ..across flats.. Green
            George
            #179792
            David Cambridge
              Thanks Tim – much appreciated (this forum is fantastic, less than five minutes to get an answer!)
              #179793
              David Cambridge
                And thanks to George as well!
                #179863
                  You know David, that was a really good question to ask. I like the diagram.
                  Another JohnS
                    @anotherjohns
                    It is a good question, as Neil says.
                    I remember wondering what "AF" meant – as England and Canada (and…) speak different versions of the same language – many of the technical designations for materials are different.
                    It was one of those forehead-slappingly obvious ones when I realized that it meant "Across the Flats" – at least, I think that's what it means!
                    John.
