Merry Christmas All
Well it’s been a while since I knocked anything up on the lathe so here’s a catch-up of the last few efforts. Snore away, don’t mind me (I’m hoping to be offered some guidance, correction and helpful tips here by anyone with a minute to spare, been lucky so far!).
PART ONE
First item is formed from a 75mm chunk off a 35mm stainless bar someone donated which I figured would make a decent holder for a small toolpost-mounted drill after seeing quite a few variations on the same theme on YouTube and this and other Forums.
I should straight away point out that the best examples I’ve seen are cut as integral tool holders themselves but I don’t have any dovetail cutters to marry blocks of hard stuff to my QCTP and also this item was my first attempt at milling something on the lathe anyway, so dovetailing is well down the learning list and high up the same curve.
Being somewhat wary of milling and having only the faintest clue how to go about it (quite aside from “her” abject refusal to let me buy a dedicated machine!) I decided to hack the bulk of the unwanted SS away with hand grinder and cutting disc first to save the load on the only decent-sized end mill I’d bought so far, from a cheap set of 8 from either Warco or Arc Euro Trade.
Next job, get it square in a spare tool holder and drill an 8mm hole centrally through it in expectation of a miniature 8mm drill chuck shaft coming along later. I used a magnetic clock on the cross slide for that. My Chinese cobalt drill bit was j-u-s-t long enough to poke out the far end, must get some long ones although they seem to be expensive.
That went reasonably well if not very accurately, then it was time to mount the vertical milling slide, base plate and milling slide vise gubbins (bought from Warco with the machine) to the cross slide via the holes vacated by the standard rear toolpost using two 8mm socket screws. That’s when I came across the first problem – this little 4” vise is not really man enough to securely grab anything not flat sided much over an inch in diameter due to its shallow jaws and only just had a decent hold on the outer circumference of the bar, so I pressed on very gingerly with the 12mm end mill (from Banggood) using super light passes and amazingly got some straight cuts. It seemed to take forever to get the face square on to my chuck and take these first very tentative steps into milling but that’s down to my lack of doing that, I suppose, and my fear of breaking something or someone. Also from Banggood is the hex ER32 collet block I used for the end mill. I’ve been happy with everything I’ve had from China so far, it may not be the best finished or most accurate kit although the finish looks great to me, but it’s meeting my meagre needs and even leaner budget.
When it came time to turn the workpiece over and mill the other side it took me even longer before I was satisfied I was getting parallel cuts, but perseverance seems to have paid off. So I now have a graspable tube with a hole through it awaiting a ship from China for the final touch, the drill chuck and arbor. Or the start of further head scratching, more likely.
