Flxispeed Meteor II – Centre Height in Gap
Home Forums Workshop Tools and Tooling Flxispeed Meteor II – Centre Height in Gap
  • #435884
    James A
      @jamesalford67616
      My lathe is currently packed away whilst I have a new garage put up, so I cannot measure for myself: does anyone know what the centre height is in the gap on a Flexispeed Meteor II? I have written down the centre height over the saddlle as 1 7/8", but I have no note of the gap size.
      Jamie.
      #19510
      James A
        @jamesalford67616
        #435892
          Lathes.co.uk is your friend. It appears, from a quick scan, that centre height was only 1 5/8”? SoI doubt the centre height over the saddle was that much – possibly the swing over the saddle, maybe? I might be wrong, of course.
          peak4
            @peak4
            I believe it's similar to my Simat 101
            Simat 101
            Bill
            #435906
            John Baguley
              @johnbaguley78655
              Bill is correct. I've just measured mine and the swing in the gap is 5-1/4"
              James A
                @jamesalford67616
                Thank you for the replies, which are a great help. I did have a look at the lathes.co.uk website, but I could not work out whether the dimensions given applied to the later models or just the earlier ones.
                James.
                #435918
                  Although not entirely clear when I had a quick look it did appear to be fairly indicative, from this section, that the information was there somewhere.
                  Quote: “ Although sold with the Flexispeed name cast into the bed the only advertisements seen for this later version show the "Meteor 11" model, but it is known that when the lathe was supplied with a single swivelling tool slide (as distinct from a compound slide) and without the automatic carriage traverse it was known as the "Meteor 1". The pitch of the leadscrew was coarsened from 12 to 8 t.p.i. with the fine feed rate of the carriage, using the original worm-and-wheel arrangement, set at 0.0015" per revolution of the spindle. Whilst the turning capacity of the lathe was unchanged the finish was improved by the use of chrome-plated handwheels and levers – and then promptly ruined by castings painted in a ghastly light-blue Hammerite.“ Unquote.
                  #436043
                  James A
                    @jamesalford67616
                    Posted by not done it yet on 04/11/2019 07:45:16:
                    I must have missed that part: thank you.
                    Does anyone know when the Meteor II was discontinued? From the lathes.co.uk website it suggests that it was in the mid 70s, but I am not sure.
                    James.
                    Edited By James Alford on 04/11/2019 22:31:36
                    #436054
                    peak4
                      @peak4
                      Posted by James Alford on 04/11/2019 22:22:08:
                      James.
                      Not sure James, but the receipt for my Simat is dated 1982 (£95)
                      Bill
                      #436171
                      James A
                        @jamesalford67616
                        Posted by peak4 on 04/11/2019 23:50:54:
                        James.
                        Bill
                        Thank you.
                        James.
