Softening/Hardening/Tempering 30 thou feeler gauge
Home › Forums › Help and Assistance! (Offered or Wanted) › Softening/Hardening/Tempering 30 thou feeler gauge
  • #496150
    Alan Wood 4
      @alanwood4
      I have a strip of 30 thou feeler gauge, 1/2" x 2", that I need to drill 2 x1.5mm holes at one end and 2 x 3mm holes at the other end. (Apologies for the mixed units).
      The 1.5mm holes are proving difficult so I heated the feeler to cherry heat and slowly backed off the heat and this has softened it sufficient to drill all the holes.
      Question – what temperature profile to now harden and temper the feeler back to its former springy self ? I have a small kiln style oven so I can control the temperature fairly closely.
      I have four such strips to make so would like an easy life and not too many broken drills.
      Edited By Alan Wood 4 on 16/09/2020 17:05:57
      Edited By Alan Wood 4 on 16/09/2020 17:06:26
      #33678
      Alan Wood 4
        @alanwood4
        #496291
        mechman48
          @mechman48
          Type in the 'Search' box, 'Tempering ' will bring up a few threads for perusal. Just for interest…
          George.
          #496295
          Circlip
            @circlip
            Punching holes in existing "H & T" strip works.
            Regards Ian.
            #496300
            peak4
              @peak4
              Maybe use tungsten carbide PCB drills, available quite cheaply from ebay and other sources in sets of 10 in 0.1mm increments.
              Make sure you clamp well, and use a sacrificial steel backing plate, to save the drill breaking through and chipping its cutting edges.
              I've just been using one to drill holes in "all hard" hacksaw blades to shorten them for a 9" frame.
              Alternatively, if the hole sizes aren't absolutely critical, a new(ish) centre drill works OK, again with suitable close clamping and a backing plate.
              Bill
              #496308
              Vic
                @vic
                Yes I was thinking carbide drills. Much easier than messing with heat treat. Although carbide drills are easy to break in that size! Good luck with the project.
                #496310
                Martin Kyte
                  @martinkyte99762
                  You get my vote for punching. Clock suspension springs are done that way. Nothing fancy is required just a couple of short peices of strip with two locating pins to align them. Drill and ream through both for the hole dia required and turn up a couple of silver steel punches the corect dia. Harden if you feel like it but for a couple of holes you don't need to.
                  regards Martin
                  #496361
                  Alan Wood 4
                    @alanwood4
                    Thanks for all the helpful support on this. I have made one attempt at heat treatment which helped but wasn't perfect and was a real pain.
                    Working on a Plan B.
                    Thanks again
                    Alan
                    #496380
                    Ian P
                      @ianp
                      I have used diamond burrs to make holes in shim stock.
                      I bought a cheap set of burrs (about two dozen of all shapes and sizes) that have 1/*2 diameter shanks, I usually start the hole with a ball shaped one and then change to conical. Square or other shaped holes are possible too.
                      Ian P
