How can I make my cutting mat have more friction? (cutting styrene sheet)
Home Forums Beginners questions How can I make my cutting mat have more friction? (cutting styrene sheet)
  • #7858
    John Smith 47
      @johnsmith47
      #211201
      John Smith 47
        @johnsmith47
        Hello
        1. I am finding it slightly irritating when cutting styrene sheet – particularly the smaller pieces of styrene – how they tend to slip around under the ruler when I try and cut or scribe over the styrene. Is there anything I can do to make my cutting mat a little bit more grabbing?
        Fwiw, my mat is a cheap one from Hobby craft…
        (This sort of thing
        http://www.hobbycraft.co.uk/hobbycraft-cutting-mat-3-ply-a2/572006-1000 )
        2. I have tried scoring using a sharp Xacto knife (#11 bade I think) but I have fine that using a heavy duty laminates cutter works quite well be cause it shaves a bit of plastic off rather than cuts it.
        http://www.amazon.co.uk/dp/B003UHUZ5U/ref=pe_385721_51767431_TE_dp_1
        Do you have any other tips for really accurate cutting of styrene (ABS) ?
        Background:
        I need to cut styrene very accurately for a functional mechanical model/prototype I am making out of styrene.
        Many thanks
        J
        #211208
          Use a rubber mat rather than a self healing one to stop the material moving on the mat. Also get a cutting rule, these have a rubber strip set into the back so they don't move so much and also have a steel insert on one edge so the knife will not wear the edge.
          A guillotene with stops may be a better bet than knife & rule if the sheet is not too thick.
          J
          Edited By JasonB on 09/11/2015 07:27:02
          #211217
          David Clark 13
            @davidclark13
            Double sided adhesive tape might help.
            #211266
            John Smith 47
              @johnsmith47
              > Use a rubber mat rather than a self healing one …
              The problem is that I rather need it to self-heal!
              Is it possible to get one that is both?
              I do have a cutting rule (with a rubber back to it), but it's measuring edge is aluminium and can easily be accidentally damaged by cutting blades.
              > Double sided adhesive tape …
              Seems rather extreme. As it would pick up dust & dirt. And would presumably tend to come away with the plastic after use… If all else fails I may try it though! Is that what you use?
              #211271
              Brian G
                @briang
                I use a cutting plotter (as used for vinyl signs) to cut styrene sheet accurately and use thin cutting mats like this **LINK** to support the sheets. They are not completely self-healing, but take a lot of damage before they need replacing. When new they hold the cut parts in place perfectly, but after while they lose their tackiness and need to be refreshed using repositionable spray mount.
                Alternately you could just try the repositionable spray mount on your existing mat. It is a bit of a so-and-so to clean off, but can be removed with soap and water.
                #211278
                  You don't need to cut right through styrene or ABS sheet just score it with the laninate cutter and then snap so no need for the mat to self heal. Cut plenty of plasticard for model making in my time that way.
                  #211325
                  John Smith 47
                    @johnsmith47
                    Yes, I get you – there is no need to cut all the way through the plastic sheet. It's just that it has a habit of moving and slipping during the scoring process – at least it does on mine.
                    The point about the mat is that I only want the one mat. And for some things I need it to heal. For plastic cutting I want it to have friction!
                    #211373
                    Hopper
                      @hopper
                      Blu-tac? (The putty like stuff for sticking posters to walls without peeling the paint on removal etc.)
                      #211387
                      Martin Kyte
                        @martinkyte99762
                        Treacle ?
