CLarke C430 lathe threading
Home › Forums › Help and Assistance! (Offered or Wanted) › CLarke C430 lathe threading
  • #864868
    tatler
      @tatler
      Clarke C430 lathe does not have a TDI.
      I seen some guys construct one and wonder if anyone can advise me about  how i go about making one for this machine.
      The leadscrew pitch is 2mm and what number of teeth on a gear should i use  and, do i need more than 1?}[most lathe i worked on have a number  of gears on the indicator].
      Thanks in advance
      Joe
      #864902
      bernard towers
        @bernardtowers37738
        depending on the amount of screw cutting you do why cant you just reverse the lathe?
        #864936
        Thor 🇳🇴
          @thor
          Hi Joe,
          May be this link can help you?
          Thor
          #865059
          DC31k
            @dc31k
            In addition to the link above, which gives you a fish, you can learn the art of fishing by reading Martin Cleeve’s book “Screwcutting in the lathe”. If time is pressing, you only need to read Section 5, starting on page 71.
            #865189
            Dave Halford
              @davehalford22513
              Using Thors link and ebay  buy one ready made for £19
              #865198
              DC31k
                @dc31k
                On Dave Halford Said:
                Using Thors link and ebay…
                Everything I can see there has a 16t gear and would only be suitable for a machine with an imperial leadscrew.
                Please review the original question. Please also review Cleeve’s book above if the challenges of metric leadscrew indicators are unfamiliar to you.
                #865220
                Dave Halford
                  @davehalford22513
                  I was forgetting these lathes are primarily made for America.
                  #865404
                  Howard Lewis
                    @howardlewis46836
                    One way to manage without a T I D is to withdraw the tool, and reverse the lathe, leaving the half nuts engaged. Having reversed well clear of the work, applying the incremental cut, and running forward will remove any half nut / leadscrew backlash and take the next incremental cut.
                    In this way, there will be no fear of losing the Thread / Leadscrew relationship.
                    Just ensure that any backlash is taken out before starting the next cut.
