End mill sharpening
End mill sharpening
Home › Forums › General Questions › End mill sharpening
Viewing 9 posts - 26 through 34 (of 34 total)
  • #865502
    Howard Lewis
      @howardlewis46836
      Nigel,
      That is a good idea.
      Thank You
      #865524
      old mart
        @oldmart
        I have bought small job lots of used solid carbide endmills on ebay and have been pleased with the sharpness. They probably are swapped out from CNC mills after a fixed time as a precaution rather than waiting for failure. I have also bought resharpened solid carbide endmills which may not be the original diameter and may have rads put on at the ends, neither of which shortcomings worry me at all, and they are recoated and sharp at good prices.
        Not being able to sharpen any type of endmills, the HSS ones are kept for aluminium and bronze, not steel.
        #865561
        Nigel Graham 2
          @nigelgraham2
          Thankyou for explaining it.
          The Kennet is simple but that’s its problem – a bit too simple! You have to take the tool-holder block off to index it.
          I’ve always been a wary of using an ER collet on a grinder. How do you avoid grit penetrating it and the collet chuck?
          #865603
          petro1head
            @petro1head
            Out of interest, where a people buying end mills now
            #865626
            Howard Lewis
              @howardlewis46836
              NG2
              On the Worden, another simple machine, the grit is driven downwards by the rotation of the wheel, and, so far, have not had any problem with grit entering the ER 20 collets.
              I added a screen to mine to keep any grit away from the sliding bars and the adjusting eccentrics, so nearly all the grit stays near to the wheel, which males cleaning easier.
              Now a job on the Round Tuit will be to make tool holder with equilateral 1″ triangular sides, in case I ever wish to sharpen three flute end mills.
              #865653
                See the recent thread “source of milling cutters after ARC” or something like that.
                #865717
                Nigel Graham 2
                  @nigelgraham2
                  Thankyou Howard.
                  It puzzled me for a while how to make a triangular (square or any polygonal) prism concentric with its bore, till I twigged you make it from round of circumscribing diameter, bore it through, then mount it on a mandrel between a suitable divider/ rotary-table and tailstock to mill the flats.
                  #866288
                  Andy Brocklehurst
                    @andybrocklehurst85292
                    I sent a couple of 12mm end mills away to be reground / sharpened in all honesty by the time you’ve paid for the job and postage both ways it’s not much different to buy new ones. Probably worth it if you’ve got something like 16 / 18/ 20mm end mills.
                    #866831
                    petro1head
                      @petro1head
                      Update
                      excellent service from Raynor Tools, highly recommended
