Hot chucks and cold spindles – caution
Home › Forums › General Questions › Hot chucks and cold spindles – caution
Viewing 3 posts - 26 through 28 (of 28 total)
  • #854026
    Macolm
      @macolm
      Most steels have a coefficient of thermal expansion of 12 parts per million per degree C. So a difference in temperature of 80C will result in a change of clearance of one part in one thousand – 1 thou per inch. On a 10 TPI thread fitting chuck, this might typically be equivalent to an extra tightening of 3.6 degrees. So would even that excessive temperature difference be sufficient to prevent easy removal?
      Obviously the diametric clearance is unaffected once the temperatures equalise, unless the fitting is a taper only.
      #854081
      not done it yet
        @notdoneityet
        Just remember that old saying of “It’s the last straw that breaks the camel’s back”.
        #854090
        Macolm
          @macolm
          I seem to remember from when I had a lathe with a screw mounted chuck, that there is a potential large bale of straw for the camel. If you temporally screw on the chuck a couple of turns, then mistakenly started the motor, the camel can be squashed flat!
