Emma Victoria boiler end of the road
Home › Forums › Locomotives › Emma Victoria boiler end of the road
Viewing 14 posts - 26 through 39 (of 39 total)
  • #841048
    Bill Dawes
      @billdawes
      Good point Rick, I will check dimensions, maybe I used figures for a static seal rather than a moving one but I see the logic you make, I guess the compression from an O ring could be more than that from rings.
      Best regards
      Bill D.
      #841063
      Nigel Graham 2
        @nigelgraham2
        O-rings are made for sliding, rotating or static sealing and likely, never the trio may meet.
        So you need the appropriate type for the duty then make the groove to the recommended specifications for that. Not just pick up rings the right diameter and sort of guess the groove profile, or use specifications likely for a different task.
        #841065
        duncan webster 1
          @duncanwebster1
          There are also X rings
          https://eriks.com/en/know-how-hub/blogs/when-do-you-use-an-x-ring/
          Which are claimed to be better than O rings in piston sealing. Anyone tried them in a steam engine?
          #841116
          Rick Hann
            @rickhann79631
            If you want to go down this “rabbit hole”, I suggest you Google “HMEM Model Engine O-Ring”.  There are several lengthy threads where posters have discussed the pros and cons of using O-Rings for model engines, both steam and combustion as well as how they machine the grooves.  There are those who recommend following manufacturers specifications (I doubt that they have ever followed their own advice and successfully constructed an engine using published groove dimensions).  Most report success using a O-Ring “squeeze” of 5% or less.  I try for 2% to 3%.  I find it interesting that no-one has mentioned the importance of measuring (knowing) the actual bore dimension.  I guess that most of you are better machinists than me because my bores are often 2-3 Thousandths larger or smaller than planned when I get done boring and lapping the bore.  Knowing the actual bore diameter (piston diameter, not so much) when calculating the groove depth needed to get the required squeeze (compression).  I have also found that measuring the actual O-ring diameter is also helpful when calculating groove depth.  A few thou can make a difference!  Nuff said!  Rick
            #841210
            Bill Dawes
              @billdawes
              Talking to a guy the other day, he is an ex car mechanic and he asked why I cant use copper nickel brake piping for steam lines as it is so easy to bend, couldn’t think of a logical reason why not, it’s not strength presumably as it has to withstand much higher pressures than we are dealing with and presumably highly rust resistant. Any ideas guys?
              Bill D.
              #841218
              noel shelley
                @noelshelley55608
                He would be talking about Kunifer 10 in 4.75mm OD, there are other sizes. He has presumably not used copper pipe or he would know it is easier to bend copper. Kunifer 10 is resistant to corrosion and good for over 1000 PSI but will be more costly. Noel.
                #844615
                Bill Dawes
                  @billdawes
                  Hi guys, had exciting phone call today from Western Steam, my boiler is finished so raiding my Swiss bank account to pay for it and collect.
                  Now having to seriously sort out plumbing etc. Pondering on flexible pipe(s) from tender, any advice on tubing type and connectors, normal nut and cone with tail to fit tubing or some form of twist fit connector?
                  Bill D.
                  #844626
                  Nigel Graham 2
                    @nigelgraham2
                    Congratulations!
                    I’d  use a twist-fit connector designed for repeated connection and disconnection. A union is intended to be connected and stay connected.
                    I don’t know your particular locomotive but miniature locomotives typically have three connections from the tender:
                    1) To the axle-pump (if fitted. Some use two injectors instead.)
                    2) Injector(s)
                    3) Delivery from a hand-pump in the tank.
                    Of these only the hand-pump connection takes any significant pressure (above boiler pressure in fact), and that’s where you’d use the twist-fit or similar clip action.
                    Alerternatively, you can use a repeat-use type screwed connector, often one that seals by a small O-ring or flat rubber washer between two flat faces, the ring washer surrounding a hollow spigot on the upstream side that mates with a counterbore in the downstream flange. Rather as on small cartridge-gas tools like picnic-stoves. I have not seen connectors of this type made for model locomotives but there is no reason you could not design and make your own.
                    The axle-pump and injector feeds are partly gravity, partly suction. It is common to use here, simple silicon-rubber hose pushed onto smooth pipe stubs an inch or so long. Give the stubs nicely rounded end edges to avoid scraping the hose wall.
                    That feeding the injector does need be air-tight though, as even a tiny air-leak into the water line under the suction created by the injector, will prevent the device from working properly. The most likely place for such a leak is a push-on hose connection; but a silicone-rubber tube of appropriate size on a pipe tail of good cylindricity and surface finish is usually reliable.
                    Clues that air is being drawn into the injector are difficulty adjusting the water and steam valves to get it to work at all, and irregular running. Also, the injector may chirrup like an excited guinea-pig when it does manage to overcome the air-leak. It should be practically silent.
                    The first two can also inidcate over-warm feed-water, partial blockages including scale in the cones, or the injector’s internal, non-return, starting valve not seating fully.
                    #844630
                    noel shelley
                      @noelshelley55608
                      Gates reinforced fuel hose will work for your water connections, it is available in 3-4-5-6-8-10 mm. There are stainless miniature jubilee type hose clips that will seal this type of pipe well or use O clips and close with wire cutters (carefully ). There is an MPD branch in Weymouth I believe. Make brass strainers for the intakes.   Noel.
                      #844639
                      duncan webster 1
                        @duncanwebster1
                        <p style=”text-align: left;”>If you have an axle pump you’ll need a bypass return as well. For the hand pump I used polyurethane pneumatic tube, 4mm OD,  plenty big enough for a hand pump, and a lot more flexible than the usual nylon stuff. Mine is yellow, but it looks as though it comes in a range of colours.</p>
                        #844710
                        Nigel Graham 2
                          @nigelgraham2
                          Noel –
                          The important point here is easy connection and disconnection, and reliable connections, on two vehicles usually separated for transport between track and home.
                          Worm-drive or crimped clips are fine on one end, but are “permanent” so not best on both ends when the hoses are connecting a tender and locomotive to be separable for transport.
                          To give our own club’s example:
                          Our 7¼” g. “Wren” is operated with a driving-truck holding a water-tank to augment the engine’s own saddle-tank and to feed the injector. (Water in a saddle-tank on a hot Summer’s day can become too warm for a small injector.)
                          It has a polythene or silicone hose for the 3/16″ o.d. pipe used for the vacuum-brake connection. The train vacuum-connectors are push-fit clip types.
                          The injector connection is as I described above: silicone-rubber hose pushed onto a pipe end. The pipe has a smoothly-rounded end. It seems to work fine, but injectors appear to be able to draw air through a leak-path that won’t admit water under only a few inches of head, when the water-valve is opened.
                          This is where rubber is better than polythene because it closes onto the metal tube a lot more reliably, repeatably – we did find this by experience.
                          Polythene seems to become more rigid and to lose its already low elasticity over time, and takes on a set that is inimical to reliable connection by simply pushing onto a pipe stub.
                          I would suggest reinforced polythene tube is potentially the worst choice for a repeated re-connection by merely pushing onto a metal pipe. Even new, it is not very flexible and elastic: it is intended for permanently fitting a closely-matched diameter. It can be used if the connector itself is of a union or clip type.
                          I am presently moving the hand-pump from the loco to the driving-truck and its tank, and that will use one of the push-fit hoses supplied by Blackgates.
                          #844723
                          Dave Halford
                            @davehalford22513
                            What about using small airline connectors?
                            #844785
                            Nigel Graham 2
                              @nigelgraham2
                              That’s a thought. We use something like that as vacuum-brake connectors on our passenger-truck. Are they rustless though?
                              #863557
                              Bill Dawes
                                @billdawes
                                Emma Victoria build progressing albeit painfully slowly (familiar story no doubt) when I got my shiny new boiler off Western Steam I thought, right all plain sailing now, slap on all the fittings i have made (turns out I hadn’t made them all) bend up some piping connect it all up and fire it up.. no chance.
                                After a frustrating start I think I have cracked the pipe bend problem, found an old article that showed experiments with various small pipe benders. I have an assortment of these and some springs, the problem with all the proprietary ones I have is they won’t allow a bend very close to the end of the pipe or repeat bends very close to each other. In the end I made a very simple one as shown in the article, just a piece of round bar with a groove in one end for very small pipes and a spigot machined the other end, the width determined by pipe diameter, closed off with a plate held by a screw into the end of the bar. Annealing the pipe is essential (of course you know that) I found the pipe can be bent quite nicely with hand pressure keeping it in the groove. Having completed all the piping in the cab I took it all apart to remove boiler to comfortably get to the axle pump water connections. Before I did that I thought I would try the saddle tank over the boiler, it didn’t go, even without insulation or cladding, I knew with my old boiler the tank was very tight, the new boiler is very slightly larger but as we all know there is not much diiference between ‘GO’ and ‘NO GO’.
                                Measuring my tank it was about 4 3/16″, should be 4 3/8″, I knew it was smaller than it should be, put that down to my sheet metal skills, or lack of. A saddle tank I found is quite a complicated thing to make accurately and looking nicely made, even so I was quite pleased with my efforts.
                                Pondered how I could get out of yet another hole I had made for myself, despaired at the thought of starting again, wondered if I could dismantle it all and fettle it, it is part rivetted, part screws and soft soldered.
                                I then thought, on the basis of nothing ventured nothing gained, could I stretch it out by some means.  A trolley jack was too big. In the end with the aid of a couple of bits of steel tube, M8 screws and nuts and two strips of wood for protection wound them out with bated breath, nothing cracked so left it rest for a day, went back and retightened a couple of times and left for about three days.
                                Took it all apart this morning and it now measures 4 1/2″, slips over nicely now, sealed all apertures and filled with water, a small leak around part of where the inner wrapper joins the end plate on one end which hopefully I can soft solder. Incidentally the tank is brass wrappers and copper end plates. Quite chuffed with that effort (at the moment)
                                Onwards and upwards.
                                Bill D.
                              Home › Forums › Locomotives › Topics
