Alibre Atom3D – extended trial stops working
Home Forums CAD – Technical drawing & design Alibre Atom3D – extended trial stops working
Viewing 2 posts - 1 through 2 (of 2 total)
  • #842210
    David Jupp
      @davidjupp51506
      There have been a few reports of the 6 month trial stopping working after a month or two.  The issue seems to relate to an interrupted connection to the licensing server during routine validation check.
      If you suffer this problem – the quickest and easiest way to have it fixed is to contact Alibre support.  Either use the support ticket submission form  https://www.alibre.com/alibre-customer-support-ticket-entry/  or if that isn’t convenient, you can e-mail [email protected] – it’s a good idea to specifically mention the extended trial.
      Do NOT use any other alibre.com e-mail address to report problems.
      The fix is simple, it doesn’t need you to do anything beyond providing the e-mail address used to register the trial – the fix is all done on the licensing server end.
      #863420
      David Jupp
        @davidjupp51506
        A follow up to the above;  If the software doesn’t work at all, or you get ‘unknown error’ messages, this likely relates to the problem previously mentioned.  We now understand the cause much better and can offer a permanent fix (involves swapping out a dll file).
        If you suffer from this issue, contact Alibre Support or your reseller for assistance.
