Dimond wheel dressing.
Home Forums General Questions Dimond wheel dressing.
  • #24507
    Alan .204
      @alan-204
      #236335
      Alan .204
        @alan-204
        Very simple question can it be done if so how?
        Alan.
        #236346
        Chris Evans 6
          @chrisevans6
          I used to do a simple dress on a cup wheel to remove the wear, (single lip Deckel type cutter grinder) With the wheel off the machine it was rubbed on a cast iron lapping plate with a little paraffin. Crude but did the job.
          #236349
          Ex contributor
            @mgnbuk
            The company we used to use to regrind beds at my last employment (R Skinner Engineering) did so on planers fitted with grinding heads & used diamond cup wheels. They used special sharpening stones on the wheels – about 12mm square by 100 mm long, white abrasive sticks with an open texture. A bit like a white grinding wheel in stick form, but light weight & quite friable.
            Bob had a box full of these sticks & used them sparingly if the wheel wasn't cutting to his satisfaction (which was probably by how it sounded, or how the surface looked). Bob sold his business 10 years or more ago & I have not been in contact since, and I can find no reference to the chap who bought him out, so can't ask directly what these sticks were called. But I would expect that an industrial diamond wheel supplier would know.
            On a slightly similar note, I once had problems drilling a floor for holding down bolts using a Hilti rig. The going was extremely slow (I was sent on site to find out why the job was taking so long), so I called in the Hilti rep. His opinion was that the concrete had a large proportion of very hard quartz aggregate & he gave me a "sharpening stone" to regularly dress the core drill when it stopped cutting freely. This was about 300mm square by 25 or so thick & looked like an un-glazed terracota floor tile. It was not very hard & cut easily with the core drill – cutting a couple of 6mm deep grooves was enough to expose fresh diamonds & get the drill cutting again.
            HTH
            Nigel B
            #236366
            Roger Head
              @rogerhead16992
              According to ArcEuroTrade resin-bonded diamond wheels are dressed using a fine aluminium oxide stick.
              See http://www.arceurotrade.co.uk/projects/d_wheels/dwdoc.html
              Roger
              #236371
              Roger Head
                @rogerhead16992
                From the Norton website:
                Aluminum Oxide (White)
                For dressing and cleaning cBN wheels; these sticks also work well for
                diamond wheels.
                http://www.nortonindustrial.com/uploadedFiles/SGindnortonabrasives/Documents/Catalog_PDFs/NortonSuperabrasives-DressingSticks.pdf
                See the TECHtip at the bottom of the first page regarding selection.
                Roger
                Edited By Roger Head on 27/04/2016 01:49:34
                #236373
                jimmy b
                  @jimmyb
                  I use a white Norton stick, about an inch square, "220", I think.
                  Just press it into the wheel as it runs and it cleans it.
                  #236378
                  Chris Evans 6
                    @chrisevans6
                    I have used the white sticks but think they are more for cleaning/preventing clogging than dressing. I will be eager to learn more as I run a diamond wheel on one end of my bench grinder.
                    #236392
                    Dusty
                      @dusty
                      I have heard that York stone works, never tried it, never needed to. It has got to be worth a try.
