Posted by Dave Halford on 27/10/2020 10:57:07:
It's the reason for all the fire hazard warnings, they have to be shipped charged.
Never heard that one? In my experience most rechargable lithium cells come discharged. For shipping lithium batteries are divided into two basic categories. Those containing lithlum metal (non-rechargeable) and lithium ion (rechargeable). Both are capable of causing a fire if faulty or abused, but the regulations are much stricter for batteries containing lithium metal. Combustible electroyte is one thing, an alkali metal fire something else.
I'd concur that the electronics between battery and motor is for controlling the motor. The battery protection functions are normally built into the battery iteself and are not accessible. Otherwise some people would defeat them. The protection circuits normally protect against short-circuits and undervoltage, but not over-voltage.
Charging lithium ion batteries is somewhat involved. If the battery voltage is below a threshold (deep discharged) the charging cycle starts with a constant current charge at a reduced rate, often C/10. Once the battery voltage exceeds the threshold then charging switches to constant current at a higher rate, 1C or more. As the battery voltage nears full charge the charging switches to constant voltage so the charge current falls off as the battery voltage rises. At a set voltage charging is turned off. Lithium batteries don't like trickle charging as often used with lead acid batteries. The voltage thresholds are critical, they need to be better than 1%. There are some really nice linear and switcher based charging ICs available. The ones I've used seem to perform well over long periods without fudging the batteries.
There have been some reports in the press recently about fires caused by replacement batteries bought on the cheap. In general you get what you pay for but with batteries you may well get an additonal "bonus" surprise.
